Do I need wheel spacers?
Discussion in 'Wheels & Tires' started by Cwright, Feb 20, 2014.
  1. Feb 20, 2014 at 4:07 PM
    Cwright
    Cwright [OP] Well-Known Member
    Arkansas
    2012 TRD Sport Double Cab 4X4, Super white
    3" OME lift, Light Racing UCAs, NFab bars, 275/70/17 KO2s
    Just received the OME 3" lift for my 2012 DC TRD Sport and I'm just about settled on Nitto Terra Grapplers. If I go with 285/70/17s will I need wheel spacers/adapters? This truck is a daily driver and will see little to no off-roading. If spacers are required how thick? I've been back and forth on 265-285 but the 265/70s just seem a little small with the lift.
    BTW if anyone has pics with this tire (both sizes) on factory sport wheels and 3" lift please post.
    Thanks
  2. Feb 20, 2014 at 5:08 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    Yes, you will need to use adapters to run 285s on the stock wheels otherwise the tires will rub on the UCA. A min. of 1" will cure it. Just decide how wide of stance you prefer. 1.25-1.5" adapters are more common to find.
  3. Feb 20, 2014 at 5:57 PM
    Cwright
    Arkansas
    Thanks. I failed to mention that I also bought the LR UCAs from Toytec. Will that make any difference?
  4. Feb 20, 2014 at 6:48 PM
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    The stock wheels have too much backspacing. If i remember correctly, I believe the LR UCA actually provide less clearance than the stockers. Although I'm not 100% sure, but that's what I remember.
    You have 3 choices
    - run adapters
    - buy new wheels with less bs
    - run 265s or look into 255/80/17 for a 33" tall and skinny
