Do I purchase axle shim before installing Dakar leaf ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by martthewhite, May 11, 2015.
  1. Sep 14, 2015 at 6:09 PM
    #41
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    http://youtu.be/f1m-Fh5kiRU
    pidgeball likes this.
  2. Sep 14, 2015 at 8:55 PM
    #42
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Lol.. thanks OZ!
    Ive seen that video and did get the 2 rear ujoints equal with 3 degree shims but i still had vibes. The take off shudder never went away. So it my be bacause the 3 degree shims were too much. Not sure.
  3. Sep 14, 2015 at 8:56 PM
    #43
    ETaco23
    Evan
    PNW
    I may try 2 degree or 2.5 degree shims.
  4. Sep 15, 2015 at 6:08 PM
    #44
    ETaco23
    Evan
    PNW
    just ordered 2.5 degree shims to try out. should be here by Friday, hopefully.
    hope it works and I can rid my truck of vibes.
  5. Sep 18, 2015 at 9:18 PM
    #45
    ETaco23
    Evan
    PNW
    Well the 2.5° shims are in and i ldft the 3/8" CB drop spacer in, and most all my vibes are gone.
    Still have a slight take off shudder. I can hardly feel.
    Im stoked, finally got my vibes under control
    DoorDing likes this.
  6. Sep 18, 2015 at 9:22 PM
    #46
    ETaco23
    Evan
    PNW
    With my canopy, i have about 1.5" rake. Front has 885's and 1/4" top spacer. It sits at 23" front and 24.5" rear. Its alittle much but not bad. It kinda looks good with the canopy and having alittle rake.
  7. Sep 19, 2015 at 10:52 AM
    #47
    TAJJI
    TAJJI Active Member
    Tanner
    N. Colorado
    2015 Tacoma DCSB TRD Offroad - White
    OME Lift with Dakar Leafs Bug Chucker Bedside decals
    I had the OME with Dakars done last week and came back with the Taco lean on both front an rear on drivers side - shims are in and mine goes back on Tuesday to have em installed.
  8. Sep 19, 2015 at 11:17 AM
    #48
    OZ-T
    Peter North
    British Columbia
    You do the drivers side trim packer and were your Dakars a mixed +/- set ?
  9. Sep 19, 2015 at 11:31 AM
    #49
    TAJJI
    TAJJI Active Member
    Tanner
    N. Colorado
    Not sure what a mixed set is - i had the Dakars with the extra leaf installed.I assume its the Packers that are going in since its an ome kit
  10. Sep 19, 2015 at 11:34 AM
    #50
    OZ-T
    Peter North
    British Columbia
    The 5mm trim packer goes on the front drivers side coil
    Dakars can come as + , 0 , or - , 0 is on spec , + or - are above and below spec respectively . If you get a mixed set , putting the higher spec leaf pack on the drivers side helps combat Taco Lean
    EDIT : this info is assuming you have a 2nd Gen
  11. Sep 19, 2015 at 11:37 AM
    #51
    TAJJI
    TAJJI Active Member
    Tanner
    N. Colorado
    I guess I assume that theyre both 0s since it leaned. Im not super knowledgeable on suspensions so I left it to the best offroad shop in town
  12. Sep 19, 2015 at 11:40 AM
    #52
    OZ-T
    Peter North
    British Columbia
    Point is, without knowing it would make any difference , they could have put the higher spec pack on the passenger side if you do in fact have a mixed set which would make the lean worse
  13. Sep 19, 2015 at 11:42 AM
    #53
    TAJJI
    TAJJI Active Member
    Tanner
    N. Colorado
    Ill have to ask on Tuesday. Thanks for the heads up
  14. Sep 19, 2015 at 11:42 AM
    #54
    OZ-T
    Peter North
    British Columbia
    You're welcome , good luck
  15. Sep 20, 2015 at 9:13 AM
    #55
    ETaco23
    Evan
    PNW
    Just so you guys know, both my Leaf packs are + and I had the Taco lean. About 5/8" and never went away.
    Until yesterday when I took out the top overloads on both sides, and then installed a 1/2" spacer on the driver's side leaf pack. No more taco lean and now my rake isn't as bad as before. It brought it down about 1/2".
    Shims are still in and I took out the CB drop spacer and put in about 1/8"-3/16" spacer to get my drive line angles right.
    haven't test drove yet but hoping my vibes are still gone.
  16. Sep 20, 2015 at 11:36 AM
    #56
    OZ-T
    Peter North
    British Columbia
    Some people get lean , some people don't
  17. Sep 24, 2015 at 10:02 AM
    #57
    TAJJI
    TAJJI Active Member
    Tanner
    N. Colorado
    Had the spacers installed earlier this week - no more lean, looks way better!
  18. Mar 3, 2016 at 3:17 PM
    #58
    ETaco23
    Evan
    PNW
    I just rescently put me 2nd overload back in to hrlp with sag when loaded. And my vibes are back. Took out the 2.5 degree shims and put in 3 degree. Nope, still got vibes. Tryed to drop my carrier bearing from 0 to 5/8" sesmed like 1/2" help some, but still there.
    Geuss its time for a 1 piece driveline.
  19. Mar 3, 2016 at 4:23 PM
    #59
    mts
    mts Well-Known Member
    Lexington, KY
    2007 TRD Sport-TRD Supercharger
    Where are you guys getting your shims? I have the cb drop with the dakars and still get a slight vibration between 30-45mph. It's much worse without the cb drop though.
  20. Mar 3, 2016 at 5:28 PM
    #60
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    Toytec / Wheelers off road
