Do I really have to chop my frame?!
Discussion in 'Suspension' started by jbizzlebev, Oct 27, 2020.
  1. Oct 27, 2020 at 6:43 PM
    jbizzlebev
    jbizzlebev [OP] Member
    Jimmy
    2020 Silver Tacoma TRD Off-Road
    I'm looking to get some bigger tires on my tacoma. I'm currently thinking about 33's but every time I see people putting these big tires on a tacoma they cut into the cab mount. Is it possible to have no rubbing tire rubbing and 33s without chopping my frame? If anyone is pulling this off let me know what tires and suspension you're running. Any help would be appreciated. Thanks guys!
  2. Oct 27, 2020 at 6:44 PM
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    Do you plan on going Offroad or staying on pavement ?
    El Duderino likes this.
  3. Oct 27, 2020 at 6:44 PM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
  4. Oct 27, 2020 at 6:46 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    A cab mount chop really isn’t a big deal and you’ll only benefit from it. Plenty of fill plates available and any decent shop can do the job for a couple hundred or so.
  5. Oct 27, 2020 at 6:51 PM
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    You can go skinny with 255/80/17 to get 33” with no rub. But 285 gonna need to cut. It’s not a big deal at all an I am sure there is someone in your local area on TW that does them in their garage.
  6. Oct 27, 2020 at 6:52 PM
    Clearwater Bill
    Billy
    Largo Florida
    255 85 16 or 255 80 17 are 33" (which there is nothing really magical about.)
    On OE wheels, no lift, rub, chop or trim.
    Budget friendly. No future maintenance funk. No warranty grief.
  7. Oct 27, 2020 at 7:04 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    CUT IT!!!:sawzall:
    It's really not that big of a deal, you're not cutting the structural ladder frame in two, you're cutting a dust cover that was cheaply made from stamped steel that's oversized for assembly convenience at the factory.
    Trim it up, run the 33's and be happy.
  8. Nov 3, 2020 at 2:37 PM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    www.jdfabrication.com
  9. Nov 3, 2020 at 7:58 PM
    subieweapon
    subieweapon Active Member
    Drew
    Central Indiana
    2019 magnetic gray OR m/t
    I’m not rubbing with 285x70x17.. but I put fox shocks on, aligned it with more caster and cut lots of plastic out.
    noco_taco likes this.
  10. Nov 5, 2020 at 12:36 PM
    state48offroad
    state48offroad Well-Known Member
    you can run 33(285s) without rubbing if you are at or above 2" of lift and run the stock UCA. just keep any aftermarket wheels you buy below 6mm offset and you will be clear of the cab mount.
    i run a 295/70R17 with stock UCA, King coilovers at 2.3" and have a 0mm offset wheel and i am clear at full turn even over obstacles
    we also install tons of similar lifts and wheel/tire combos on Tacoma and 4runners here at Westcott Designs in Phoenix and have little to no issue with cab mount rubbing unless an aftermarket UCA gets installed or wheel offset is high
  11. Nov 8, 2020 at 1:48 PM
    2000prerunner23
    2000prerunner23 Well-Known Member
    steve
    Ya, they have new subframe which can move the entire front lower arm mounts forward 1".
    You could also install new LT (push the tire outwards) or custom suspension which moves the tire forward 1" (built into the lower control arms lower uniball/ BJ location).
  12. Nov 16, 2020 at 11:29 PM
    kevinlambchops
    kevinlambchops Well-Known Member
    I have 285/70/17 on method 17" wheels. Haven't rubbed on my body mount yet
