Do I really need an alignment after new coilovers?
Discussion in 'Suspension' started by glock24, Sep 13, 2015.
  1. Sep 13, 2015 at 10:59 AM
    glock24
    glock24 [OP] Well-Known Member
    I just installed a set of 6112s up front. It went very smooth thanks to the wealth of info on this site.
    One question; I can confirm that I have returned the LCA cams in 99.99% of the original spot they were before I started the upgrade. And the truck tracks exactly the same as yesterday.
    So . . . how many of you would still drop the coin on an alignment check?
    Thank you
  2. Sep 13, 2015 at 11:01 AM
    At The Helm
    At The Helm ATH Fab Vendor
    Morgan
    Gardnerville, NV
    2015 AC 4x4 TRD OR & 2019 T4R
    Kings, TC UCAS, SCS SR8's, ATH bumpers
    Yes you will need an alignment. In fact I'd get one now, then another after it all settles in.
  3. Sep 13, 2015 at 11:02 AM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    Actually putting the cams back in the same spot after any lift is the exact incorrect thing to do amigo. The only way that would be correct is if your truck was sitting at the exact same height as your old CO's. If the truck is not at the same height your alignment will be incorrect.
    YotaDan likes this.
  4. Sep 13, 2015 at 11:07 AM
    TeamSarcasm
    TeamSarcasm Flawless Escalation to the Ludicrous
    The better coast
    See if any of the places offer lifetime alignments on the vehicle. Adjust bring it back adjust bring it back etc.
    YotaDan likes this.
  5. Sep 13, 2015 at 12:14 PM
    glock24
    Understood
    Thanks guys
  6. Sep 13, 2015 at 2:17 PM
    At The Helm
    Morgan
    Gardnerville, NV
    X2 on the lifetime alignment..
    Also tell them you want 0 camber, 0 toe, and as much caster as possible. Whether you have aftermarket UCA's or not will play a role in that.
    YotaDan and MGtaco2.7 like this.
  7. Sep 14, 2015 at 9:56 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    This & I'll add that just by the very nature of loosening the cams has most likely thrown it out of it's "norm" settings, even if no struts were changed or even if the OEM's were taken out & put back in... they are fussy little bastards...
  8. Sep 14, 2015 at 12:23 PM
    glock24
    Just got back from the tire shop. How'd they do?
    I asked for zero Toe, zero Camber, and as much Caster as possible with the stock UCAs. I'm also running 265/75/R16s
    It drives very nice to me. Tight and responsive.
  9. Sep 14, 2015 at 12:55 PM
    zimmmtaco
    zimmmtaco Better than it was before it got like it is
    Northwestern PA
    15 DCSB Blue Ribbon Met 4x4 OR, 6MT
    TRD Pro susp kit 265/75R16 BFG K02's Husky Floormats Vent visors Hella 500 on custom mount
    Which notch/setting did you use on the 6112s?
  10. Sep 14, 2015 at 12:57 PM
    glock24
    I'm running the 2nd notch from the lowest.
    Right now my measurements conclude I'm at a +2.0" lift up front, but I'm pretty sure I read that it will settle back down to +1.75" soon.
