do I really need an alignment?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by takaya49, Dec 14, 2010.
  1. Dec 14, 2010 at 8:04 PM
    takaya49
    takaya49 [OP] Pacific Rim Mushrooms
    Brent
    Vancouver BC
    tacos
    Fox C/O long travel shox with resi, piggy back fox rears, TC UCA's, ICON AAL, Addicts/17 toyo MT, Mr. Marv set up,
    just had coil overs and shox put on the back and front and the truck drives great... no pulling, shaking etc.. do i still need an alignment?
  2. Dec 14, 2010 at 8:06 PM
    S.B.
    S.B. Well-Known Member
    Sean
    Colorado Springs, CO
    08 Taco 4x4 TRD OffRoad Rugged Trail
    Fox 2.5, Built right UCAs, CBI Front bumper, NWTI Rear bumper, 35s
    yes
  3. Dec 14, 2010 at 8:09 PM
    Matic
    Matic Locked and Lifted "02" DC TRD.
    Rich
    Greenville,sc
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate.
    Absolutely. I thought the same thing. Truck tracked sweet after my lift. Eventually ruined my fronts because they were toed in so bad. Rest of the tire had 50%, both liters were bald.
  4. Dec 14, 2010 at 8:10 PM
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    yes. and if you cant get correct alignment get new ucas. otherwise youll wind up like me looking for new tires.
  5. Dec 14, 2010 at 8:15 PM
    takaya49
    Brent
    Vancouver BC
    tacos
    thanks guys! will get one asap
  6. Dec 14, 2010 at 8:23 PM
    MrGrimm
    MrGrimm Mall Crawler
    Dean
    Wisconsin
    2006 Toyota Tacoma 4WD w/TRD Sport Package
    See build page
    No if you like to replace parts that otherwise wouldn't need replacing or like to replace tires more often than you should.
  7. Dec 14, 2010 at 8:29 PM
    S.S.T.
    S.S.T. Well-Known Member
    Torrance, CA
    07 TRD Off Road Access Cab
    Icon 2.5 Extended Travel Coilovers, 5100 rears, Icon Progressive 3 leaf AAL, Hankook Dynapro ATM 265/75R16, 16x8 Renegade 6 wheels, AFE Pro Dry S air filter, BHLM.
    Make sure when you go, you ask them to get the numbers as close to perfect as you can, otherwise, they'll get them into the green spec range, and call it good. Toe and camber as close to 0 as possible, with a high caster.
