Do I really need Fluid Film?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by sammyt38, Nov 7, 2022.
  1. Nov 11, 2022 at 8:29 AM
    #61
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    I only coat mine once a year, in the fall but, I coat it EXTREMELY HEAVILY. yes it is a lot of work, even 1 time a year, for this 55 year old but,... I KNOW it was done to my liking, and my standard of quality. In reality, it is so thick on two of the 4 vehicles I have, I probably could have skipped the application this year. but, I wanted to try out the newest lanolin version by PB Blaster, called Surface Shield. it seems like a thicker, longer lasting version of FF, and WW. time will tell. Ski
  2. Nov 11, 2022 at 9:13 AM
    #62
    IrishRed
    IrishRed Appalachian Ridgerunner
    Central PA
    2017 TRDOR DCSB 4x4 MGM Prem&Tech Auto
    Eibach Suspension, JBA UCA’s, 16” SCS Ray 10s, BFG KO3s, ECGS Bushing, Pro Skid Plate, Fumoto Valve, Pro Grille, Opt7 Tailgate Light Bar, AVS Window In-Channel Vents, Roknlokz XL Mud Flaps, Husky Floor Mats, Bed Mat, Tailgate & Glovebox Letter Inserts, TRD Grille Badge, Exhaust Tip, Toyota Hitch Plug.
    My truck is 5 years old. I live in central PA where they salt & use other nasty stuff on the roads. I’ve never used any rust preventative products, but have been considering it.
    I’ve had no issues with serious rust. This past summer, I did slide under it and give everything a new coat of black paint to freshen it up. Looks like new again.
    I’ve been contemplating using Fluid Film or something similar, but I live down a mile long stone & dirt lane. I’ve been told everything sticks to this stuff. So, I’ve been reluctant to use any out of fear my undercarriage will be caked in mud, stones, pebbles, & grit making it miserable to work on, unsightly, and possibly causing other problems.
    I think I’m going to grab a can or two and do the inside of my rockers just to be safe.
  3. Nov 11, 2022 at 11:22 AM
    #63
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I'd be careful if mixing brands of these rust inhibiters over each other. Believe me you don't want what happened to a buddies trd when he did this.
  4. Nov 11, 2022 at 12:51 PM
    #64
    sajer
    sajer Member
    2006 black 4runner limited
    Go on?
    skidooboy likes this.
  5. Nov 11, 2022 at 2:14 PM
    #65
    skidooboy
    central lower mich
    Expand please...
    The first year I sprayed on FF, the next year I sprayed a mix of FF and WW. this year, I sprayed Surface Shield. All products I applied are in the lanolin line. I havent saw any issues after any of the applications, at this time. I would like to hear, about what you heard/saw. Ski
    tonered likes this.
  6. Nov 11, 2022 at 4:02 PM
    #66
    zoo truck
    None
    A buddy of mine sprayed cosmoline over fluid flim done a week before thinking he'd have double the protection. Some sort of reaction took place where the cosmoline wouldn't cure, but just kept dripping all over his driveway, and garage floor making a mess. He ended up having to power wash the chassis well to remove it all so he could re-cosmoline it a day later.
  7. Nov 11, 2022 at 4:05 PM
    #67
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Gulf Coast, salt water??? (I'm just guessing here, as I come from the land of snow & salt)
    I would do it, just to have it penetrate between the cracks and welding joints of the frame. Also can't hurt to do the whole vehicle as the inside of your body panels could use a little penetration.
    Good preventative maintenance regardless of where you live.
  8. Nov 11, 2022 at 4:06 PM
    #68
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    Do vehicles rust there?
    If they do, yes. if they don’t, no.
  9. Nov 11, 2022 at 4:24 PM
    #69
    skidooboy
    central lower mich
    I could see a problem doing that. Doing the reverse, especially as a touch up, I would see no issues. the Cosmoline wants to dry, and cure. the fluid film (all lanolin base products) will want to stay soft (fluid).
    placing a product wanting to dry over one that doesnt, wont end well.
    placing a fluid (wet) product, over a cured dried product might result in a softening of the first applied product but, I dont think it would have as bad as a reaction, as the prior example. (but, I could be mistaken).
    best advice, pick a product and stay with it, if it works for you, and your application. Ski
    zoo truck[QUOTED] likes this.
  10. Jun 10, 2024 at 1:55 PM
    #70
    IA DIY
    IA DIY Well-Known Member
    Iowa
    2008 DCLB 4x4
    I talked w/ this guy in Omaha.
    https://www.gottschsgoo.com/omaha-undercoating
    He said he switched from Fluid Film to Woolwax after reading about rubber deterioration from the former. I had already put Fluid Film on, but next year I’ll switch over to Woolwax just to be safe.
    SilverBulletII likes this.
