Do it myself or have local mechanic or dealership replace water pump
Discussion in '2nd Gen. Tacomas (2005-2015)' started by leosantamana, Jul 20, 2018.
  1. Jul 20, 2018 at 12:35 PM
    leosantamana
    leosantamana [OP] Member
    I have an 06 2.7 liter 5 lugger Taco, extended cab.
    It's got 70k on the odometer (bought used last year). Coolant is dripping from water pump. Based on what I've read here, sounds like a water pump.
    I have done a few in my life on older cars. I see the part is only about $50 on Amazon (Aisin WPT-044).
    What should I expect to pay at dealership? What about private mechanic?
    How tough is this? What else to do while in there (thermostat, idlers, serpentine, etc)?
    I just don't have a lot of time and don't wanna mess it up and do it twice if cost is not too bad.
    Thoughts?
  2. Jul 20, 2018 at 12:42 PM
    Clearwater Bill
    Billy
    Largo Florida
    If you've done it before you can do it again.
    A lot cheaper.
    blu92in99 likes this.
  3. Jul 20, 2018 at 12:46 PM
    Nomad_Pilot
    Nomad_Pilot I need to pewp
    Clay
    Ft Collins
    Dude I mean absolutely no disrespect to you, but if you don't have enough time to take it slow and do it the right way....better take it to someone else. The fact that your posting this lets me know your not 100% sure what your doing, and that could lead to failure when rushed. Again I don't mean any disrespect.
    jpmorrisvb likes this.
  4. Jul 20, 2018 at 12:47 PM
    Johnders
    Johnders Spacer Lift Survivor
    2010 Black Access Cab Tacoma Base
    2" Lift , 265/75R16 tires, K& N filter, MBRP Exhaust
    I replaced mine last year (same issue of leaking) first time doing a water pump for me. There was some good write ups on this Forum somewhere, but its really not to bad. It took me several hours mostly because it was the first time and some of the bolts are a little tricky to get to.. I replaced the thermostat while I was doing it, probably should have replaced the belt seeing as I was in there already.. Definitely a do it yourself job if you got half a day (or less) to spare..Mine was just over 150k on the clock at the time.
  5. Jul 20, 2018 at 1:28 PM
    leosantamana
    Thanks everyone. No disrespect taken, I understand. I have no fear of doing it, but if the parts are $100, and a shop would charge $400, I'd go that route, as my time is valuable.
    However, if there were some "gotchas" in doing it, I wanted to know in advance.
    Anything else to check / replace while in there? (Other than placing thermostat right way:eek:) I believe the timing is a chain, so nothing to see there..
  6. Jul 20, 2018 at 1:37 PM
    Toy Yo
    Toy Yo Well-Known Member
    Middletown N.Y. upstate
    2017 tacoma TRD Sport
    2 inch front and rear lift kit, Rough country nerf step bars, Ultra Mongoose 17x9 wheels BF Goodrich M/T 285/70-17
    4 banger water pumps are easy to do if ya know what your doing. You can do the job with just hand tools.
  7. Jul 20, 2018 at 1:42 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
  8. Jul 20, 2018 at 1:46 PM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    if asking that question, have some one else do it
  9. Jul 20, 2018 at 2:40 PM
    leosantamana
    @BillsSR5 - great write up/specs. Thanks for your support.
    BillsSR5 likes this.
