Do it yourself A/C recharge.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TXpro4X4, Oct 25, 2017.
A/C recharge kit
  1. It worked
    75.0%
  2. It didn't work
    25.0%
  1. Oct 25, 2017 at 12:21 PM
    TXpro4X4
    TXpro4X4 [OP] Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    Anyone had luck doing the DIYS
    A/C recharge kit from Vato Zone or other?
    No, It kinda worked answers.
    Would like to know if it! did or not plz!
    Thx in advance!
  2. Oct 25, 2017 at 12:36 PM
    wheeliest
    wheeliest ///////////////////
    Json
    TMPE AZ
    05-SWB-DCSB-4X4-V6-SR5-SPORT
    NO SWAYBAR, Spacer lift with dirty4's
    First of all, there's no such thing as a "Recharge". AC systems are SEALED. If it is not working properly it more than likely has a LEAK or failing component.
    I suggest staying away from the "Autozone AC Recharge" crap as it has sealants in it that will cause Black death to your AC system
    ElBlancoTaco and TXpro4X4[OP] like this.
  3. Oct 25, 2017 at 12:44 PM
    ElTacom
    ElTacom Member
    Brandon
    2000 4X4
    All Pro Coilovers & Leafs. Bilsteins. CBI Sliders
    I used the one from AutoZone in my 1st Gen. Pretty easy application. The AC was blowing outside temp before and after the charge (or whatever) it cooled down considerably. Not as good as new though. Kept me and the family cool when we went out to Joshua Tree a couple months back and it still blows cold when I sat at the border for 2 hours last Sunday.
    Don't know if it's good for the system or not but it worked for me.
  4. Oct 25, 2017 at 12:55 PM
    Snotrocket
    Snotrocket Well-Known Member
    Maine
    2022 TRD OR DCLB
    It's just a band aid. It will leak out again eventually.
    Should have added some dye to it to find the leak.
    TXpro4X4[OP] likes this.
  5. Oct 25, 2017 at 1:03 PM
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    After about 5 years almost every AC needs a recharge unless you don't use it but here in SoCal I've been using it quite a bit so I believe it needs a "fill"
    Also if you look under your hood you'll find specifications for a type of recharge/ fill and oil.
    I will post a pic later
  6. Oct 25, 2017 at 1:06 PM
    wheeliest
    Json
    TMPE AZ
    Its called system maintenance as there is a small amount of oil in the system to keep the compressor lubed. So yes an oil change (Re-charge) is a wrongful used term. Do you recharge your refrigerator every 5 years? Freon/refrigerant is never suppose to be exposed to the atmosphere.
  7. Oct 25, 2017 at 1:12 PM
    wheeliest
    Json
    TMPE AZ
  8. Oct 25, 2017 at 1:28 PM
    Falconsfan
    Falconsfan Well-Known Member
    2017 sr dcsb v6 4x4 black
    Just buy a hose with gauge that goes on the 134-a cans and charge it when it leaks off, did that for like 3 years in a Saturn I had as a work car, didn't feel like fixing it right and bought cheap 134-a at Walmart cheap so the three years cost me like $30 and would blow ice cold most of the summer, it starts not being as cold, top it off.
  9. Oct 25, 2017 at 1:56 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Take it to a damn mechanic and have it evacuated and recharged!!! Don't use those suicide cans!!!!!!!!
    ElBlancoTaco and wheeliest like this.
  10. Oct 25, 2017 at 2:11 PM
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    No.
    But you throw the Refrigerator away after it stops blowing cold.
    I'll have to do some real research.
    Thanks for your responses that we're not helpful
  11. Oct 25, 2017 at 2:22 PM
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
  12. Oct 25, 2017 at 2:24 PM
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    It still get cold just not as coldas it did maybe.....
    Or maybe it's just been too hot:notsure:
  13. Oct 25, 2017 at 2:29 PM
    Bebop
    Nick
    Get it properly evacuated, deep vacuum and recharged. And a shot of dye. The dye will show a leak if there is one. Take it to a mechanic. Ac is something the average joe shouldn't mess with.
    Fridgey and ElBlancoTaco like this.
  14. Oct 25, 2017 at 2:40 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    You throw the fridge away because the cost for the parts to fix it is not far off from getting a brand new fridge.
    Fridgey likes this.
  15. Oct 25, 2017 at 2:53 PM
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    I actually just replaced the compressor in my father's 1996 Dodge Ram. I checked for leaks with a vacuum pump and recharged the system with an appropriate manifold set. I also used it on my 1991 Toyota pickup. Worked great and got the A.C. blowing cold again.
    OP, If you're adding more refrigerant to your system because it got low, then there's a leak. The store bought recharge cans will only work temporarily. You need to find the leak with a dye, address it, and recharge it.
    wheeliest and Drew793 like this.
  16. Oct 25, 2017 at 3:07 PM
    Drew793
    Drew793 Well-Known Member
    New Jersey
    08 TRD Off-Road V6 Auto
    Weather Tech window shades, Roll-N-Lock cover with cargo manager, Led interior bed lights, EZ down tailgate strut, SpiderTrax1.25" wheel spacers, tinted windows, second filter removed, Grillcraft Mesh upper and lower grill, Castrol Syntec.
    Make sure you have a clean cabin air filter and a clean condenser coil.
  17. Oct 25, 2017 at 4:18 PM
    Fridgey
    Fridgey Active Member
    Vancouver
    2006 Tacoma
    Plain and simple, if you have to recharge the system with more refrigerant, you have a leak. If you use those recharge cans they will work but you have not addressed the moisture that has been introduced into the system. Pulling a vacuum then recharging by weight with dye is the proper way to do it. If not you are shortening the life of the compressor and not actually fixing the problem.
    I am only a Refrigeration/AC mechanic, what would I know? :D
  18. Oct 25, 2017 at 4:35 PM
    Bebop
    Nick
    Mechanic here as well. If the OP doesn't want to listen to a pro then he will pay some guy like us to fix his fuck up. It will end up costing him more than the original evac and recharge.
    TXpro4X4[OP] and bogginator like this.
