Do it yourself catalytic converter? 2nd gen
Discussion in '2nd Gen. Tacomas (2005-2015)' started by joew94th, Jan 29, 2012.
  1. May 12, 2014 at 7:38 PM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
  2. May 12, 2014 at 9:41 PM
    MarkH
    MarkH Well-Known Member
    Mark
    San Jose, CA
    13 PreRunner TRD Off Road
    California emissions regs require that the Catalytic Converter be CARB (California Air Resources Board) Approved. All OEM Cats are automatically approved as the car was tested to comply with CA Regs before it was approved for sale, but pretty much all the aftermarket Cats do not have this approval and are illegal to sell or even ship into the state.
    Now that does not mean that you will fail your smog test for emissions reasons. But you could fail the visual inspection should the tester actually look closely at the Cat under the vehicle. Not likely on a car, but trucks and SUVs it is a little easier. I know a number of people that had friends buy them a new Cat out of state and ship it to them, none has ever failed a smog test. I have also never seen anyone look closely at the Cat, they just look to see it is there. And that includes the one time I had to go to the State Referee station for a retest.
    You should change the O2 sensors periodically as a failed O2 sensor can cause the engine to run rich which can damage the Cat.
  3. May 12, 2014 at 9:46 PM
    vbibi
    vbibi Well-Known Member
    san fransisco bay area
    2009 4door long bed
    You must have a friend somewhere to have it delivered out there..... and then UPS them to CA.
  4. May 13, 2014 at 2:16 PM
    joew94th
    joew94th [OP] Member
    Cameron Park, CA
    06 PreRunner TRD offroad
    I had to get it at the Toyota dealer. That's why it cost so much. California won't allow anything but OEM cats on vehicles. As for removal, the cat is welded to the exhaust manifold, so it all has to come off. The head bolts came off ok. The bolts on the rear of the cat where it bolts to the exhaust pipe (and 2nd cat) were a nightmare. Because of the heat and rust, I had to cut two of the bolts of with a air chisel. I got the new bolts from the dealer also.
  5. Oct 13, 2015 at 5:38 PM
    Bhwang
    Bhwang Well-Known Member
    Josh
    Canada
    Tacoma
    Working on it. Never Ending :)
    Trying to bring back an old thread here, but I seem to have the same problem but only with my driver side cat it sounds like a tin can and rattling, but only when it is less than 10 degrees out (in Canada), in the summer it makes no sounds at all, any ideas if this could be the cat ?
  6. Oct 13, 2015 at 7:15 PM
    RBaptist
    RBaptist Well-Known Member
    Newnan, Ga
    2017 TRD Sport - Magnetic Grey
    I did mine last year on my 2007. I have the 2.7l prerunner. Toyota of Olathe Ks online had the Cat/O2/fuel mix sensors for $1350. My local dealer matched it. It was pretty easy to do - maybe 2 hrs of work? Spray the bolts with PB blaster and let it sit for 24 hrs. If you have an electric impact wrench (Ryobi is about 100 bucks) the bolts come off really easy. Shop wanted $2000 for mine (no O2 or air/fuel sensors. Save nearly 1K and do it yourself (and get the right parts).
  7. Oct 13, 2015 at 7:20 PM
    DukesTaco
    DukesTaco Well-Known Member
    AZ
    2nd Gen Double cab Pre Runner
    Got to love the nany state.
    thewarriordinghy likes this.
  8. Oct 14, 2015 at 7:37 AM
    Bhwang
    Josh
    Canada
    Tacoma
    So what your telling me is to find a good used set to install as the regular price is insane !
    Or option B is to just live with it as it's not hurting anyone and no codes are being thrown and it runs great !
  9. Oct 14, 2015 at 8:33 AM
    TacoRob08
    TacoRob08 Well-Known Member
    Rob
    Fredericton, NB, Canada
    17 Sport DCLB
    gibson exhaust, OVTuned base 91, AFE intake
    Go with option B until it throws a code. Then try to clean it. The replaced it with aftermarket manifolds. Well that's my plan so far, my rattles in the winter too (New Brunswick, Canada)
  10. Oct 14, 2015 at 8:39 AM
    Bhwang
    Josh
    Canada
    Tacoma
    How would i go about cleaning it ?
  11. Oct 14, 2015 at 8:42 AM
    TacoRob08
    Rob
    17 Sport DCLB
    Can try running a can of Seafoam through the system.
  12. Oct 14, 2015 at 8:43 AM
    Bhwang
    Josh
    Canada
    Tacoma
    I did that a few years ago and could do another run and smoke out the neighbourhood, always had good results wiht seafoam !!!!
  13. Oct 14, 2015 at 8:49 AM
    Bhwang
    Josh
    Canada
    Tacoma
    you have a 4.0 L engine too ?
  14. Oct 14, 2015 at 8:50 AM
    TacoRob08
    Rob
    17 Sport DCLB
    Sure do
  15. Oct 14, 2015 at 9:12 AM
    #35
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    anyone reading this
    unless you obviously have a blown or damaged cat and physically looked through it
    --suspect the sensors first, o2 sensors (ones behind the cat) all tend to go off between 120,000-170,000 miles
    I have a 4runner whose a/f sensor went at 130,000 (heater circuit malfunction), o2 at 136,000 (bad cat) and o2 again (bad cat) at 211,000
    I replaced sensors only. was not really a bad cat at all, just old worn sensors
    the dual CA cats are original and run fine, emissions is clean (tailpipe testing) , t'was only the sensors getting old
    236,000+ now, still runs clean no codes and toyota oem sensors [denso]
    sensors -will- always fail, the cats might actually last a long time
  16. Oct 14, 2015 at 9:25 AM
    #36
    SH7mi
    SH7mi Elite Performance Tune PA MD DE NJ
    Kevin
    West Grove, Pa.
    2021 Tacoma DCLB OR Black Performance Elite Tune
    AE manifold spacer Bed lights Seat Jackers Blackvue Dashcam Elite Performance Tuned Fumoto Oil Pan Valve
    X2
    The cat converter should not go bad. If it is bad replace only the bad one, the other should last.
    Like 127.0.0.1 said, exhaust all other possible problems first.
    pretacomikev6 likes this.
  17. Jan 30, 2016 at 6:21 PM
    #37
    NBFJCruz
    NBFJCruz Well-Known Member
    Brian
    Saint John, New Brunswick, Canada
    2007 FJ Cruiser 5AT, lifted, 285's, black-out
    lifted, 285s, black out, Defiant lightbar, triple Hella 100w
  18. Feb 7, 2016 at 7:55 AM
    #38
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices. Also installed a new external TPMS monitor for all 4 tires.
    Sub'd
  19. Feb 7, 2016 at 9:10 AM
    #39
    YotaDriver631
    YotaDriver631 Well-Known Member
    '18 Taco
    How many miles? Government mandated emissions 8years/82,000 miles warranty?
