DO NOT accidentally turn on you truck without the air intake and MAF sensor connected
Discussion in '1st Gen. Tacomas (1995-2004)' started by crazytacoman, Mar 25, 2021.
  1. Mar 25, 2021 at 7:32 PM
    crazytacoman
    crazytacoman [OP] Well-Known Member
    Tacoman
    Taco World
    02 2.7 doublecab & 07 4.0 doublecab
    Color Wheels
    Accidentally did this. Was the most minor-heart attack moment I've had in a long while. I felt so bad for my engine and truck for doing so. It felt like if I would have kicked an old dog of mines or something similar.
    Turned on the truck and it ran for like 2 seconds before it let out a nasty sounding whimper and shutting down. Connected everything back, and now runs as fine as it did before. I would not recommend doing this.
  2. Mar 25, 2021 at 8:08 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Not going to hurt anything as long as no dirt or debris gets sucked in.
    The engine will not run very well if at all with the hose disconnected because the MAF sensor in the airbox lid tells the PCM how much air is entering the engine so it can deliver the appropriate amount of fuel, if it sees no reading from the MAF it's going to cut all the fuel. If you keep trying it will eventually flag a trouble code for the MAF and substitute a default value for it to allow the engine to run as a "limp home" strategy.
  3. Mar 25, 2021 at 8:36 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    It will shut down from lack of a MAF signal
  4. Mar 25, 2021 at 8:42 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Jojee117 and Tacoma’20 like this.
  5. Mar 25, 2021 at 9:11 PM
    Nano909
    Nano909 Stirrer Of Pots
    Xcab 3.4 4wd 5MT
    Do this in a turbo Audi and watch the cluster light up.
  6. Mar 26, 2021 at 9:03 AM
    AmherstAndy
    AmherstAndy Well-Known Member
    Andy
    Masshole
    2003 2.7L 5 speed, 4x4 J shift, Xtracab
    As far as I know, it should start and run fine, just in open loop. This can be a useful way to diagnose a faulty MAF: if the engine runs better with the MAF unplugged, then the MAF may need replacement.
    Disclaimer: I have left the MAF unplugged on OBDII cars in the past without realizing until the CEL lit up. Haven't tried on the Tacoma.
    For your viewing pleasure:
  7. Mar 26, 2021 at 10:21 AM
    AmherstAndy
    Andy
    Masshole
    Yep, it's a factory-installed "feature".
    Rachelsdaddy likes this.
  8. Mar 26, 2021 at 11:51 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Interesting all 3 of my3.4 Engines will shut off with the MAF disconnected
    crazytacoman[OP] likes this.
  9. Mar 26, 2021 at 12:07 PM
    Nano909
    Xcab 3.4 4wd 5MT
    Kind of like how these trucks come with rusted frames straight from factory.
  10. Mar 26, 2021 at 12:14 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    I don't see how this would be a bad thing other than if you sucked in a bunch of dirt without the air filter in there.
    No worse than stalling the engine, thats basically all that happened :notsure:
  11. Mar 26, 2021 at 12:49 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    It will not shut down, it will go into limp mode and run rich.
  12. Mar 26, 2021 at 3:34 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    No need to argue the engines all shut off.
    Will not even start with the MAF disconnected does this mean all three are bad?
    With them plugged in no lights
    Maybe I wired something wrong in all the Engine swaps.
    Since all three pretty much came in a box
  13. Mar 26, 2021 at 3:51 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    I'm not arguing. I just know that I unplugged the MAF on my 96 to solve an idle issue to get me to work.
  14. Mar 27, 2021 at 11:21 AM
    crazytacoman
    Tacoman
    Taco World
    Color Wheels
    Agreed. Just felt a nasty feeling doing that to the old engine
