DO NOT TIGHTEN YOUR DIFF BOLTS TO 33 LB FT (READ THIS FIRST)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Nitori, Apr 27, 2017.
  1. Apr 27, 2017 at 4:33 PM
    Taco Caliente
    Taco Caliente WTF?
    San Antonio, TX
    2019 TRD OR DCSB
    That's a bummer.
    It almost looks like if you removed the flat washer that there might be enough to grab on to the end of the stud with a pair of vice grips, and maybe be able to get it out, but you will want to first heat up the end of the bolt enough with a propane torch to loosen any thread locker that on the threads.
    If that doesn't work, sand the end of the stud flat and drill it for an easy out and try that along with heating up the stud to soften any thread locker, and lucking it looks like it's one of the studs that you can get to with a hand drill.[/QUOTE]
    DON'T DESTROY THE EVIDENCE!!!
    Try to get as close a magnified shot of the broken surface of that bolt, or even better the other half that came off with the nut. Clean it real good without scratching the surface, such as soaking in solvent and using a fiber or soft plastic brush (NOT a wire brush). Then dry any oil or solvent off it with alcohol or air duster before shooting the pics. If part of the surface appears flatter than the rest, and also has markings resembling curved lines, then it's a FATIGUE CRACK. Thread roots in a bolt are great stress concentrators. Cyclic stresses can build up there to the point where the material starts to yield on a microscopic level and form a tiny crack. As the stresses continue, the crack continues to grow larger as the cycles increase. When the crack reaches a "critical" size, the material can no longer hold itself together, and FAST FRACTURE happens. That's when it breaks. My guess is that bolt was already cracked and near it critical size when you attempted to check its torque. If so, then Toyota cannot blame you for the broken stud, as it was already cracked. My other concern would be WHY did it crack in the first place. Those bolts should be designed for the application (proper material and hardness/heat treat). They should never break like that if the specs are correct, and should be able to withstand any cyclic loading (where ever that may be coming from). It's also very possible that when assembled, it was over-torqued and pre-cracked and continued to grow by fatigue. But I'd still be suspicious of the materials hardness. Hold on to the broken parts and try to get good pics for your defense if Toyota tries to blame you. FYI: I've been in the metallurgy/failure analysis field for 40 years, and have seen countless broken bolts from all industries.
    tcjacado and ImpulseRed008 like this.
  2. Apr 27, 2017 at 5:06 PM
    MetrickMetal
    MetrickMetal Praise the Lowered
    Scott
    Yerington NV
    2017 Super White SR5 Access Cab / 4WD, AT / TP
    See my sig for mods
    Try to get as close a magnified shot of the broken surface of that bolt, or even better the other half that came off with the nut. Clean it real good without scratching the surface, such as soaking in solvent and using a fiber or soft plastic brush (NOT a wire brush). Then dry any oil or solvent off it with alcohol or air duster before shooting the pics. If part of the surface appears flatter than the rest, and also has markings resembling curved lines, then it's a FATIGUE CRACK. Thread roots in a bolt are great stress concentrators. Cyclic stresses can build up there to the point where the material starts to yield on a microscopic level and form a tiny crack. As the stresses continue, the crack continues to grow larger as the cycles increase. When the crack reaches a "critical" size, the material can no longer hold itself together, and FAST FRACTURE happens. That's when it breaks. My guess is that bolt was already cracked and near it critical size when you attempted to check its torque. If so, then Toyota cannot blame you for the broken stud, as it was already cracked. My other concern would be WHY did it crack in the first place. Those bolts should be designed for the application (proper material and hardness/heat treat). They should never break like that if the specs are correct, and should be able to withstand any cyclic loading (where ever that may be coming from). It's also very possible that when assembled, it was over-torqued and pre-cracked and continued to grow by fatigue. But I'd still be suspicious of the materials hardness. Hold on to the broken parts and try to get good pics for your defense if Toyota tries to blame you. FYI: I've been in the metallurgy/failure analysis field for 40 years, and have seen countless broken bolts from all industries.[/QUOTE]
    Yes, when a bolt or stud has been in the process of failing for a long enough time, when it finally does fail you will usually will be able to see a larger area of older looking discolored metal as well as a smaller area of fresh bright looking metal where it finally separates.
    We would see this on studs on large productions machines where I worked, and from what I can see of the end of the broken stud, the material all has the same fresh looking color, and being in a location on the truck where its going to water and dirt, it shows no sign of corrosion if in fact this the stud had started to fracture over a period of time, but then again it's hard to tell for sure by not being able to see it in person.
    Blazingbluesport likes this.
  3. Apr 27, 2017 at 5:23 PM
    Taco Caliente
    Taco Caliente WTF?
    San Antonio, TX
    2019 TRD OR DCSB
    I'd also venture a guess that one or more of the remaining bolts are also cracked to some extent. Especially if they don't meet hardness specs. It's a scary thought that perhaps tens of thousands of bolts in our tacos are cracked because of out of spec hardness. Lets hope not.
  4. Apr 27, 2017 at 6:41 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    Bro, it's Newtons Meters, not ft lbs.
    18 N m = 13.3 ft lb
    angrysam likes this.
  5. Apr 27, 2017 at 6:45 PM
    Nitori
    Nitori [OP] Well-Known Member
    Maricopa AZ
    2021 T4R SR5
    Most assuredly not brother, that's the first column. 25 N m = 17.7 ft lb (call it 18). ;)
  6. Apr 27, 2017 at 6:52 PM
    ToyoMann
    ToyoMann Well-Known Member
    2017 Tacoma TRD Off Road
    A lot of Aisian bolts are garbage.
    jetfishn likes this.
  7. Apr 27, 2017 at 7:05 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    Stock
    Better tell the dealer you saw the recall on the news and were worried about your families safety and you couldn't wait for the recall notice. Cause that looks like a big warranty claim refusal.
    Regardless, that stud should never of failed at that low of torque.
  8. Apr 27, 2017 at 7:27 PM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    Not necessarily bolt strength issue. Could have been cross threaded at factory and forced on and left just before breakage. I have had wheel studs do that after inspection stations air wrench lugs back on before.
  9. Apr 27, 2017 at 7:31 PM
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
    Well, I guess ^that explains this:
  10. Apr 27, 2017 at 8:26 PM
    erictheblonde
    erictheblonde Well-Known Member
    eric
    TRD Pro
    Manual
    Are all the affected trucks the Mexican built ones? I'm guessing yes. Then the bolts are likely sourced from Mexico.
  11. Apr 27, 2017 at 8:29 PM
    Scooby24
    Scooby24 Well-Known Member
    Greg
    2017 DCSB OR 4X4
    No.
  12. Apr 27, 2017 at 9:17 PM
    BeaverNation
    BeaverNation Well-Known Member
    How about no one touches their diffs except Toyota.
    Y2kbaja, Nfarrall, LoMa and 7 others like this.
  13. Apr 28, 2017 at 10:03 AM
    Mark_R
    Mark_R Well-Known Member
    Mark
    2016 Toyota Tacoma TRD Off-Road
    I don't know if this makes any difference, but I recently took my truck in about 3 weeks ago letting them know that I was experiencing a bit of seeping from my third-member. On the work order they put that they tightened the bolts to the factory spec of 33ft lbs and it should be good to go. Now with this recall that just came out, I will keep an eye on it and see if it persists. If it does I will take it back in and have them figure this out once and for all. BTW - My truck was not on the VIN list of affected trucks.
  14. Apr 28, 2017 at 11:13 AM
    Simpleton
    Simpleton Well-Known Member
    Orange County
    2017 DCSBOR
    None as of yet
    off-roads torque spec is 18ft lbs :bananadead:
    Mark_R[QUOTED] likes this.
  15. Apr 28, 2017 at 11:23 AM
    #35
    Mark_R
    Mark
    Yup. They tightened them to 33ft lbs on my TRD OR. So if there is a bolt stretching issue, I'm definitely not asking them to loosen them to 18ft lbs. I'll just keep an eye on it and see what happens. It's all documented so I am good with it.
    2016Tacoman likes this.
  16. Apr 28, 2017 at 11:34 AM
    #36
    EPH
    EPH Well-Known Member
    Mission Viejo, Ca
    16' TRD Sport 4x4
    2016 TRD 4x4 sport on the recall list.... out of town for work but will look at this as soon as I get home.
  17. Apr 28, 2017 at 2:25 PM
    #37
    FreshMexicanTaco
    FreshMexicanTaco The Taco Garage
    AJ
    San Diego
    2019 spiced up Taco with guac, no onions.
    Dashtop Multi-Mount!, Pro grille, snug top, Kings BFGs, Front and rear view camera anytime, CMC, prinsu and more to come!
  18. Apr 30, 2017 at 3:00 PM
    #38
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    That's nuts. I'll be mortified if all of this stems from poor quality metal resulting in fatigue cracking or failure due too inconsistent elasticity yield.
    If Toyota cut costs and can't even get their hardware right....
    Guess we will just have to wait and see. And I'll be watching the highest milage thread like a hawk. Haha. Hope everyone's issues get remedied as pain free as possible!
  19. Apr 30, 2017 at 3:03 PM
    #39
    TheCookieMonster
    TheCookieMonster cookies!!!!!!!!!!!
    North East
    1995 Hi Lux 22re 4x4 5speed
    Michelin MS2 K&N drop in filter
  20. Apr 30, 2017 at 3:42 PM
    #40
    ToyoMann
