DO NOT TIGHTEN YOUR DIFF BOLTS TO 33 LB FT (READ THIS FIRST)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Nitori, Apr 27, 2017.
  1. May 4, 2017 at 6:31 PM
    #61
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    2005 Tacoma Specifications (Source: 2005 Toyota Tacoma Repair Manual, Pub. No. RM1162U, Pages 29-43 and 29-68):
    Without Differential Lock (33 ft-lb, M10 thread):
    With Differential Lock (18 ft-lb, M8 thread):
    2015 Tacoma Specifications (Source: 2015 Toyota Tacoma Repair Manual, Online Pub. No. RM25Y0U, Doc. IDs RM0000016GJ00AX and RM0000016GG00VX):
    2016-2017 Tacoma Specifications (Soruce: 2016-2017 Toyota Tacoma Repair Manual, Online Pub. No. RM26L0U, Doc. IDs RM100000000VEDI, RM100000000VECO, and RM100000000VECI):
    Automatic Transmission without Differential Lock, 8.0-inch (18 ft-lb, M8 thread):
    Manual Transmission without Differential Lock, 8.8-inch (33 ft-lb, M10 thread):
    With Differential Lock, 8.8-inch (33 ft-lb, M10 thread):
    Jeff
    shakerhood and jonnyozero3 like this.
  2. May 5, 2017 at 7:24 AM
    #62
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    so by the looks of that the 3rd gen TRD OR diff with its larger studs get 33ftlbs then.
    Jeff Lange likes this.
  3. May 10, 2017 at 2:35 PM
    #63
    Hiluxski
    Hiluxski Well-Known Member
    Ventura California
    2022 Lime green TRD Pro
    Do you exploded view of that with part numbers I can find no information on the studs just threading in. I need to change a few . Thanks
  4. May 10, 2017 at 7:02 PM
    #64
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
  5. May 10, 2017 at 7:52 PM
    #65
    Nitori
    Nitori [OP] Well-Known Member
    Maricopa AZ
    2021 T4R SR5
    Jeff this is spooky, look at this:
    This is a screencap from my particular FSM copy I used to start this thread originally. I notice the rev numbers are different, and my copy does not specify stud size.
  6. May 10, 2017 at 8:46 PM
    #66
    Jeff Lange
    Calgary, Canada
    Yeah, they updated/corrected the repair manual at the end of April from what I can tell.
    Jeff
  7. May 11, 2017 at 9:43 PM
    #67
    Mark_R
    Mark_R Well-Known Member
    Mark
    2016 Toyota Tacoma TRD Off-Road
    So 33ft lbs for my 2016 auto TRD OR is correct, yes? I didn't see you mention the Auto with locker.
  8. May 11, 2017 at 9:59 PM
    #68
    ChrisK7UND
    ChrisK7UND Well-Known Member
    Colorado
    2017 Tacoma TRD Sport Double-Cab
    LED Interior Bulbs, Hondo Garage Phone Mount, Tacoma Bed Mat
    Man. Wish we could get a positive number. I have a 2017 TRD Sport and is listed as part of the recall and no signs of leaks so far. I am more than capable of torquing them down if I know for sure the spec. I have had my torque wrench calibrated and certified so no fear there.
  9. May 11, 2017 at 11:41 PM
    #69
    tedburgundy
    tedburgundy Well-Known Member
    If it's not a defective stud problem, I would also like to torque my own.
  10. May 12, 2017 at 1:02 AM
    #70
    duckytw
    duckytw Well-Known Member
    From what's been posted and as confirmed updated:
    14 mm socket => 33 ft lb
    12 mm socket => 18 ft lb
    Garyji and The hammer like this.
  11. May 12, 2017 at 5:29 AM
    #71
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    ^^This ^^
    When all else fails, common sense prevails. Larger bolt larger torque number, smaller bolt smaller torque.
    shakerhood likes this.
  12. May 12, 2017 at 7:07 AM
    #72
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    Do you have quality control documents from the manufacturer of the studs that prove your statement.
    There are several people on here that have snapped their studs at way less than the recommended torque.
  13. May 12, 2017 at 8:55 AM
    #73
    tedburgundy
    ? It's not a statement. After reading many threads on the possibility of defective studs I'm asking the question. English comprehension.
    Ted
  14. May 12, 2017 at 8:59 AM
    #74
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    Stock
    I owe you an apology, I didn't read the "If" at the beginning of your post. Damn Ca public school system!
  15. May 12, 2017 at 9:04 AM
    #75
    tedburgundy
    It's all good.
  16. May 12, 2017 at 9:41 AM
    #76
    Jeff Lange
    Calgary, Canada
    Toyota's instructions for the recall state if there is no leak, retorque the bolts. Recall done.
    If you want to do that yourself, it doesn't seem like a bad idea. Next time you're at the dealership they will likely still want to check the torque on them to complete the recall in the system, but that is all that is happening.
    Recall only applies to trucks with the smaller studs, 18 ft-lb. If you have the larger differential, the recall does not apply to you, but by all means, torque away. 33 ft-lb.
    Jeff
  17. May 12, 2017 at 9:41 AM
    #77
    Y2kbaja
    Y2kbaja Well-Known Member
    Sacramento
    05 Total Chaos Tacoma
    Total Chaos
    Coming from the dealer side of this, DO NOT TOUCH YOUR DIFF BOLTS!! OMG, if they break because you torque them they are NOT warranty and I doubt the campaign will cover this. THERE IS NO REMEDY AT THIS TIME IF THE DIFF IS LEAKING!!! If your diff is leaking the remedy right now is to down the vehicle and wait for a solution/repair.
    From a personal standpoint, if your diff isn't leaking I would NOT take it in for the recall. Wait until it leaks.
    The hammer likes this.
  18. May 12, 2017 at 9:44 AM
    #78
    Jeff Lange
    Calgary, Canada
    I can also see the wisdom here as well. If it's not leaking, don't worry about it. He's also right, if you break a stud, you'll probably need to replace the stud yourself, which could be a bit of a pain depending on where it snaps.
    Jeff
  19. May 12, 2017 at 11:55 AM
    #79
    zackst
    zackst Well-Known Member
    What's confusing and misleading is the announcement of the recall stated what the remedy is but now they're saying the remedy hasn't been determined yet.
  20. May 12, 2017 at 2:45 PM
    #80
    Hiluxski
    Ventura California
    If your truck is stock and you go to a dealer with a broken stud , and just play dumb . "I only brought it in for recall I know nothing" Then the tech comes out and says no warranty on broken bolt that just happens to be the area of recall ? Owner says" I don't know what your talking about , I just brought it in for recall" Toyota would never , ever deny the service . First they would have to prove you broke it and it did not come that way Good Luck. What if was done during the pdi check who knows. It's cheaper and easier and safer for Toyota to just fix it. It's a 2.00 part .
    Note: common sence Unless you modify the whole truck did a suspension lift, larger tires , gears , then that's a different situation altogether
