Do or don't do K & N Drop In Air Filter Replacement??
Discussion in 'Performance and Tuning' started by khfactor, Dec 14, 2007.
  1. Dec 14, 2007 at 6:41 PM
    khfactor
    khfactor [OP] Well-Known Member
    Philadelphia, PA
    07 White TRD Sport
    Pop N Lock + Hose Clamp. DTRL, AFE drop-In Dry filter, 6-1/2" Replacement Speakers, JVC HD Radio, Sam's club variety Floor mats (cheap but effective), Chrome Exhaust tip, Bed Mat from ol' Ford Ranger. As of 3/25/2020, the Odometer just turned 70K.
    I am considering replacing the factory installed air filter with the drop-in type of K & N air filter for my 2007 V-6 4x4 Sport pkg. I have had a K & N drop in type filter for my ol' 2002 Ford Ranger 4.0 FX4 and it gave me a couple of more horses.
    Any of you have had this installed and experience any enhancement? Would you consider this a "waste" for a meager enhancement?
  2. Dec 14, 2007 at 6:43 PM
    SLOTaco
    SLOTaco Ultimate Member
    Central Coast, California
    06 TRD Sport
    '06 TRD Sport 4x4 AC, K&N drop in air filter, Magnaflow cat back, Bilstein 5100's with Toytec adjustable front coil over 3" lift, rear TSB, AllPro UCA's.
    My butt dyno tells me I got more power when I put mine in, but I think its worth it if not just that It will last the life of the truck, and all I've got to do is clean and oil it.
  3. Dec 14, 2007 at 6:53 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    its not bad...but if i'd have read up on things, i'd have gone w/ the AFE dry filter instead...also, read up on the removing the secondary air filter post to open it up a lil more
  4. Dec 14, 2007 at 7:26 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    I used them for years and I believe (can't prove it) that K&N filters destroyed MAF's on two different vehicles. I personally wouldn't use them again. I also don't believe that a drop in filter will make much of a difference with these vehicles considering they basically already have a CAI as it is.
    Like above, remove the secondary filter and you'll notice a definite improvement. I shot some air through it with my compressor and you can barely feel it on the other side.
  5. Dec 15, 2007 at 5:42 AM
    maverick491
    maverick491 Towing Guru
    South Jersey
    07 4x4 Access Cab, TRD off road, 6 cyl, 6 spd
    Activator III brake controller, Extang Fulltilt toneau, Factory bed mat, Extra D-rings in the bed, 2ndary air filter removed, Garmin Ique GPS, Eco-2, AFE Pro Dry-s filter, USASPEC PA12-toy, Pioneer 3-way speakers, SG II on Blendmount, Gulf States Alarm added.
    Remove the secondary air filter, and then go with the AFE Pro dry-s drop in. That is what I am using now the the VPE test concluded, and while I have only preliminary observations from it and no hard solid confirmed numbers yet. I can say that there was a butt dyno improvement, and for a tank that has been mostly just around town driving I am still looking at an average of 17.7 MPG according to the scangauge right now, and that is pretty close to my mixed highway and city tanks before this filter went in.
    Check this link for the particulars.
  6. Dec 15, 2007 at 6:00 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Same here... Clean it regularly (once-twice a year) and do not over-oil it and you should be fine.
    I've had K&N's in multiple vehicles for years.
  7. Dec 15, 2007 at 6:36 AM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    Where did you get yours? I've been looking and unable to find it.
    Honestly, when you can use a dry filter, like the AEM Dryflow (no drop in for ours yet), I don't know why anyone would actually take a chance using a K&N. Technology has advanced and so should K&N. We don't use 8 tracks anymore so why use ancient filter tech?
  8. Dec 15, 2007 at 9:41 AM
    maverick491
    South Jersey
    http://www.ultimatetruck.com/products/afe_pro_dry_s_oil_free_performance_oe_replacement.aspx?year=2006&make=1093&model=21226
    You may have to re-enter your vehicle information, as it doesn't seem that that info holds when it is linked, *shrug*
    Remember to use 2006 as your model year as their database is not updated to include 07 or 08, but i've got mine in an 07 and have no problems.
  9. Dec 15, 2007 at 10:01 AM
    Bill in Ky
    Bill in Ky Well-Known Member
    Bright White 08 Reg 4X4 2.7 5spd SR5
    I got my first 4x4 in 1972...haven't been without one! I still like Chrome!
    I just called and ordered one. Thanks for the link Maverick491
  10. Dec 15, 2007 at 10:16 AM
    AZsurfer13
    AZsurfer13 Well-Known Member
    Houston, Texas
    07 Regular Cab Tacoma
    Total Chaos 3" Coil Over and Control Arms, 15" American Racing Mojave's, 31" BFG A/T, Doug Thorley Ceramic Coated Header, Magnaflow Cat Back Exhaust, AFE Stage 2 Cold Air Intake, 20% Tint. (All work done by SDHQ Offroad, www.sdhqoffroad.com)
    Dont bother with K&N. Get an AFE (Advanced Flow Engineering) Filter. Cost Less and most of the time give more horse power.
  11. Dec 15, 2007 at 11:07 AM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    Thanks, Maverick. Much appreciated.
    And get out of South Jersey quick. I did. ;)
  12. Dec 15, 2007 at 8:47 PM
    rick
    rick `
    thanx for the link maverick
  13. Dec 16, 2007 at 5:13 AM
    khfactor
    Philadelphia, PA
    07 White TRD Sport
    Hello Mav491,
    Is this also a life time filter with no oiling and stuff? As you said a few weeks back when I was getting my Taco truck, I am sucked in now. Like the Borgs in Startrek next generation TV series, "Resistance is futile, you will be assimilated," I am hopelessly sucked into this MOD disease... It's all your fault (my wife says all the time :D). She says, Mod here Mod there, then what ?
    Well, I am not telling her some of the secret mods I am cooking up, so let the MOD disease spread like the California wild fire, I say !! :D
  14. Dec 16, 2007 at 6:06 AM
    maverick491
    South Jersey
    WAIT A MINUTE!!!
    YOUR wife says it's MY fault?????? Now that's not cool, I get enough blame from my own wife. :pout: LOL.
    To answer your question.
    Yes, this is a lifetime filter as well. When it gets dirty, they say you can bang it out to restore 50% of its flow ability, vaccume it out for 75% of it's flow ability, or hose it out to restore it to 100% of it's flow ability, but if you hose it out it needs to dry for about 5 hours before you put it back in the truck, which I guess is why hey give you the other two methods.
  15. Dec 16, 2007 at 7:43 AM
    NVR_QUIT
    NVR_QUIT My goodness, my Guinness!
    Lloyd Christmas
    USA!!!!
    08' TRD Sport, 11' TRD Sport
    Toytec 3" lift...
    Don't swap out your air filter for a K&N...
    K&N filters claim to add more horsepower by letting in more air to your engine... This IS true
    But how? You ask yourself do they let in more air than other filters. Well, the answer is very simple... They let in more air because they are more porous thus while they let in more air they also let in twice as much dust.
    Now, I don't think you race your truck and that you need the 1/100's worth of a second differance to beat someone. If you think you need it just remember that you're going to ruin your truck in the long run.
    My father works for NAPA and I've gone to some of this company demonstrations where they show the pro's and con's of all competitive filters (air and oil) and K&N has given the most power, but at a very high cost (your engine).
    Just my .02 ;)
  16. Dec 16, 2007 at 7:49 AM
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    NVR quit said it best, too much investment for too little return. :boom:
  17. Dec 16, 2007 at 7:55 AM
    willard417
    willard417 Yeah
    Luke
    beaver county, PA
    06' access cab. 2.7L
    alpine head unit, removed secondary air filter, 18" XD Rockstars. 285/60/R18, 3" OME 884/AAL OME shocks all around.
    and the AEM Dryflow won't do the same thing?
  18. Dec 16, 2007 at 10:37 AM
    NVR_QUIT
    Lloyd Christmas
    USA!!!!
    Toytec 3" lift...
    I'm saying, your OEM filter is just fine...
  19. Dec 16, 2007 at 2:52 PM
    ellsworth
    ellsworth Well-Known Member
    Buffalo
    08' off rd 6 speed
    6 inch Fabtech, st stabilizers, 18x9 DC -1s 305/65/18 bfg at's
    CORRECT, YOUR RELYING ON THE OIL TO TRAP PARTICULATES...ON MY MOTOCROSS BIKE THERES A PREFILTER FOR A REASON...ALSO, OIL ON THE THROTTLE PLATE THAT GETS DRAWN IN TURNS TO CARBON ON THE BLADE AND BORE FAST..DONT OVER OIL IF YOU RUN AN OILED AIR FILTER
  20. Dec 16, 2007 at 3:17 PM
    BlueTaco
    BlueTaco Well-Known Member
    Long Beach, CA
    08 Tacoma Speedwayblue
    dang, wish I would have read this first before I bought my K&N filter, waste of $50 =( oh well, least i have a chance to fix this problem
