Do or Dont do???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by akwagon, Oct 23, 2009.
Should I put on rear 1" blocks?
Poll closed Nov 22, 2009.
  1. Yes do it!
    11 vote(s)
    33.3%
  2. WTF no freakin way!
    22 vote(s)
    66.7%
  1. Oct 23, 2009 at 5:20 PM
    akwagon
    akwagon [OP] Alaska Dude
    chris
    alaska
    08 Access 5spd 4x4
    5100, kazktin leather, truxedo
    My truck is sitting exactly level front and rear, but a little weight in the back and I have saggy butt. I have 1" rear blocks sitting in my garage, put them on or not??
  2. Oct 23, 2009 at 5:20 PM
    NraFan
    NraFan Join the NRA! Protect your freedom!
    JT
    SoCal
    2011 Sienna LE, rockin the mini van!
    Power sliding doors baby! WooHoo!
    Blocks suck. If anything, do an AAL. Best of luck!
  3. Oct 23, 2009 at 5:22 PM
    akwagon
    chris
    alaska
    08 Access 5spd 4x4
    Its only a 1" block, so dont think it will do much. Plus they are in my garage.... (Free)...
  4. Oct 23, 2009 at 5:29 PM
    gupster88
    gupster88 Well-Known Member
    Brett
    Almost Heaven, WV
    2021 Cement Grey Off Road
    Stock
    true, a 1" block shouldn't hurt. personally id get a custom 1" aal made to increase load capacity and it will just be a better bet to do. but a block of that size should be too bad. i say do it if you dont wanna get an aal
  5. Oct 23, 2009 at 5:31 PM
    akwagon
    chris
    alaska
    08 Access 5spd 4x4
    I have had the TSB done to.
  6. Oct 23, 2009 at 5:37 PM
    CanadianGuy
    CanadianGuy Well-Known Member
    Vancouver, BC
    08 Access Cab 4x4 TRD
    toytec aal!
  7. Oct 23, 2009 at 5:43 PM
    kilo
    kilo Solo Member
    San Antonio, Texas
    2007 Dbl cab long bed TRD Sport
    custom sliders, 3" Old Man Emu lift, onboard air, custom surf-rod mount, custom bed rack, ARB bumper, Budbuilt fuel tank skid-plate
    Go with FREE first!!
  8. Oct 23, 2009 at 5:57 PM
    flyingface
    flyingface Well-Known Member
    Zach
    Auburn, AL
    2013 MGM DCLB TRD Sport 4x4
    Soon....
    Sell the blocks and get a $80 toytec aal.
  9. Oct 23, 2009 at 6:05 PM
    frankrizzo1
    frankrizzo1 Well-Known Member
    San Diego
    05 Access Cab TRD Prerunner
    5100's at 1.75, Firestone Destination AT 265/75/16
    I also want to lift the back end 1" maximum. I heard pro comp makes a short aal that should get the job done. Also considering the 1" block as well. Anyone have the toytec 1.5 aal....... does it settle at all?
  10. Oct 24, 2009 at 6:48 AM
    stephen417
    stephen417 Member
    ny
    tacoma
    K&N intake bassani exhaust,alpine deck and amp ,10 in subs,pioneer all around led interior belstein aftermarket shocks
    With a block only 1 inch is not so bad.With blocks you can get wraping or weel hop on a hard take off,But with the add aleaf the rear end will make the ride realy stiff !rougher ride
  11. Oct 24, 2009 at 6:55 AM
    JeffRock
    JeffRock Well-Known Member
    Capital region, NY
    09 Tacoma accesscab 4x4 SR5 2.7L
    Toyota all weather floor mats. Mag light that clunks around in the jack compartment. Dog hair. Dog drool on the windows.
    I will vote no.
  12. Oct 24, 2009 at 7:08 AM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    I vote no as well. Blocks increase axle wrap like mentioned before, and they don't increase load capacity so your springs with still sag just as much as they do now. Blocks go under the springs so they won't even increase the gap between the bump stops so you'll still bottom out under the same amount of weight.
  13. Oct 24, 2009 at 7:26 AM
    Capita
    Capita Well-Known Member
    Corner Brook, Newfoundland, Canada
    09 TRD Sport Double Cab
    another vote for no
  14. Oct 24, 2009 at 7:34 AM
    mike s
    mike s Well-Known Member
    South Carolina
    2019 TRD OR
    What is the worst that could happen? I say put them on, and if you don't like the result, then go with the AAL
  15. Oct 24, 2009 at 7:44 AM
    piercedtiger
    Jon
    Southern Tier, NY
    Well for one, he'll be taking the time to rip apart the suspension an extra time if he doesn't like it. :D Personally, I hate having to redo work because I didn't do it right the first time.
    I wanted the TSB done, but I wasn't motivated enough to take my AAL out, go to the dealership, get it done, and then put the AAL back. But maybe he likes suspension work. :laugh:
  16. Oct 24, 2009 at 8:14 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    What this guy said ^^^^
  17. Oct 24, 2009 at 9:24 AM
    stephen417
    stephen417 Member
    ny
    tacoma
    hey what about those air ride coil packs by fire stone, they bolt in you adjust the hight and load cap with air andthere about $200 bucks
  18. Oct 24, 2009 at 9:54 AM
    Anathollo
    Anathollo www.saveadane.org
    Houston
    07 Tacoma TRD Sport
    Icon coilovers, Rear Fox Resi-shocks, 285/70/17 Toyo A/T's, Touchscreen JVC Headunit, Custom Rhino-lined sub box, Rocksford Fosgate components and Dual Rockford Fosgate 10" shallow subs, Pioneer and Rocksford Fosgate amps, 1250 watts total, Autometer Volt and Trans gauges with Lotek A-pillar, K&N Drop-in filter, WO Seat covers, Tint, NST WP pulley, Hi-lift jack, Diff breather mod, horn relocation mod, extra "D" rings, de-pinstriped, carrier bearing drop, Rear backup 886 bulbs, Camburg UCA's, AMW Catch can, BHLM, OME Dakars with AAL, Procomp 7089's, Front single hoop Demello bumper, Superwinch Tiger Shark 9500, Amsteel 3/8th synthetic line
    Sell those and do an AAL!
  19. Oct 24, 2009 at 9:56 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    hey Ive got a pair of toytec AALs sitting in my garage, they are used but in good shape. PM me if your interested
  20. Oct 24, 2009 at 10:03 AM
    Snyperx
    Snyperx Seniore Marcos
    No vote here. Like everyone else said go with an AAL. I got mine from Wheelers Offroad, but Toytec also offers one. Make sure it is the longer AAL, not the short ass one that Pro Comp makes. Also make sure it comes with anti-friction pads. Good luck.
