Do Pro Comp 7069 rims fit with no issues?
Discussion in 'Wheels & Tires' started by nat, May 4, 2014.
  1. May 4, 2014 at 9:35 PM
    nat
    nat [OP] Well-Known Member
    South San Francisco Bay Area
    2007 DC SB Tacoma
    Bestop, MP3 Aux Input
  2. May 5, 2014 at 6:52 AM
    nat
    2007 DC SB Tacoma
    Nobody with a second gen is running these in 16"?
  3. May 5, 2014 at 7:28 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    they fit, but i had a very small gap between the backside of the wheel and the caliper near the lugs.
    EDIT: same with my 16x8 kmc enduros w/ 4.5" BS and 0 offset
  4. May 5, 2014 at 7:36 AM
    nat
    2007 DC SB Tacoma
    Cool, I need to get them ordered. I saw a review that said it cleared as well. What lug nuts did you use?
    Slvr14tacoma likes this.
  5. May 5, 2014 at 7:52 AM
    The_Hodge
    SC
    gorilla extended thread acorn style
  6. May 5, 2014 at 8:06 AM
    nat
    2007 DC SB Tacoma
    Do you have a link by chance?
  7. May 5, 2014 at 9:05 AM
    Supashawn
    Supashawn Well-Known Member
    Canada
    09 tacoma trd
    I have pro comp rims not the same as theses they fit fine but the center cap would not work....make sure the center cap matches the bore!
  8. May 5, 2014 at 9:06 AM
    The_Hodge
    SC
  9. May 5, 2014 at 9:14 AM
    nat
    2007 DC SB Tacoma
    That's right, I had seen those on Wheelers.
    Thanks!
  10. Oct 22, 2017 at 4:44 PM
    Drew12
    Drew12 Well-Known Member
    Andrew
    Sisters, Oregon
    2005 4x4 TRD OR Access Cab
    Bilstein 5100's/Toytec 620 coils, rear AAL, Camburg UCA's, Pro Comp 7069, AFE stage 2 CAI, Blacked Depo Headlights
    I know this is an old post, but have you had balancing issues with these wheels? I have the 7069 (16 inch) and have had tons of issues balancing with the KO2s. Techs seem to think it’s the wheels and not the tires.
  11. Oct 26, 2017 at 9:58 PM
    FarNorthTaco14
    FarNorthTaco14 James 2:18
    Jeremiah
    Anchorage, AK
    2012 SR5 6-Speed Manual
    Soft topper, Kings, Total Chaos and stuff!
    I am actually looking at these as well, let me know if you get it figured out.
  12. Oct 27, 2017 at 7:10 PM
    Drew12
    Andrew
    Sisters, Oregon
    Will do. Techs just seem to think its a rim issue. Some sort of slight bend that cant be seen by the naked eye possibly. Super hard to tell. I guess Pro Comp may just be a brand to stay away from all together. Some people have problems, some dont... But, It may be worth looking into a different brand. Its really too bad because I love the look of these rims and look exactly like they do the first day they were installed 3 years ago.
  13. Oct 28, 2017 at 3:54 PM
    FarNorthTaco14
    Jeremiah
    Anchorage, AK
    Yeah I’m just looking for something cheap that I can spend around $400 for aluminum wheels. And cheap to replace if needed. In Alaska wheels get torn up so it’s pointless to get nice wheels. Look forward to hearing more info from you though!
  14. Oct 31, 2017 at 10:50 AM
    Drew12
    Andrew
    Sisters, Oregon
    I really want to get some matte black TRD Pro wheels. You want to buy my Pro Comps? Ill give ya a smokin deal haha
  15. Mar 21, 2018 at 7:59 AM
    Slvr14tacoma
    Slvr14tacoma Well-Known Member
    Mid travel
    You ever mount these wheels? Ive heard about the 16x8” contacting calipers. Well some say yes some say no. If so do you have any pictures with the 255s by chance? Thanks for any help
  16. Mar 26, 2018 at 1:06 PM
    Drew12
    Andrew
    Sisters, Oregon
    Ive had no problems with caliper clearance with my 16x8 pro comps. You could always measure your caliper diameter to make sure they clear. Just eye balled mine on the truck (didnt want to take my wheels off) and the inside rim diameter is about16-17 inches. You should have plenty of caliper clearance no matter what model you have.
    Suicyco likes this.
  17. Mar 26, 2018 at 6:36 PM
    Slvr14tacoma
    Mid travel
    Right on thanks. Those are the -12 or 4” backspace right? Truck looks good
  18. Mar 31, 2018 at 2:18 PM
    Drew12
    Andrew
    Sisters, Oregon
    I believe they are actually 4.5" BS. So if you go with 4's they should clear even better... If I am understanding BS correctly haha. You could always order one rim and just dry fit it on your truck before mounting up the tires. If they are good to go, then buy the other 3. Might be more of a PITA than that's worth, though.
    Suicyco likes this.
  19. Nov 11, 2018 at 6:47 PM
    WSMFP
    WSMFP Well-Known Member
    Dylan
    2006 Tacoma 4x4 v6 6-speed
    I’m about to get some of these on Wednesday. Got an 06 with heavy OME lift, lr ucas and arb up front. 4wheel parts is doing the install since I got them through them. Will update if balancing issues. They showed me work logs from several trucks here in Texas who had these installed with no issues, fingers crossed!
    Klondike Kid likes this.
