Do rear driveshaft lengths differ between models of same gen?
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacomabilly, Jul 18, 2014.
  1. Jul 18, 2014 at 11:15 AM
    tacomabilly
    tacomabilly [OP] Well-Known Member
    Doing the prerunner to 4wd 5sp. And wanted to double check on driveshaft lengths. My truck is a 99 with a 99 tranny. I've got front and rear driveshafts off of a 97 regular cab. My truck is an 99 extended cab, will these be the right length?
  2. Jul 18, 2014 at 11:55 AM
    Mr. Biscuits
    Mr. Biscuits gentleman and a scholar
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    - OME 881s, Dakars + D43XL - Custom front tube bumper - 33x10.5R15 BFG KO2s - Deckplate mod + Airaid intake tube + AFE reusable air filter - Aero Turbine 2525 exhaust, chopped before leaf spring - Toyota Horns emblem by Diaz Fabrication - BOSS CarPlay head unit, 500W amp + 12" Pioneer in ported box - camper shell
    the front should be ok but the rear won't.
  3. Jul 18, 2014 at 6:48 PM
    taco terror
    taco terror 1st gen = best gen
    USA
    1996 Black Tacoma, 3.4L
    4.56 ECGS regear, Wheelers 6 leaf pack, Eibach coils, Bilstein 5100s, AR Baja wheels, 33 BFG ATs, Line-x
    Your stock driveshaft should work fine for the rear
  4. Jul 19, 2014 at 9:49 AM
    tacomabilly
    So will the rear driveshaft work or not? I doubt the stock prerunner driveshaft would work on a longer tranny
  5. Jul 19, 2014 at 12:41 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Did you crawl under your truck and take some measurements??
    Your truck is a 99 EXTENDED CAB. The 97 is a regular cab. The only other difference is the lack of a transfer case in your 99. Plus....if you don't have the same engine or tranmission.....can also change the size of the rear shaft.
    Get under there and take measurements....
  6. Jul 19, 2014 at 2:27 PM
    Andy.G
    Andy.G Well-Known Member
    Andy
    Virginia
    96 tacoma sx 4x4 2.7 5 speed
    Started automatic. Swapped to manual
    Transmissions can dictate driveshaft lenghths. Same engine,same transfer.5 sp vs auto is what made my swap diff. What you are doing I know 0 about. I do have front and back from 96 2.7 4x4 auto trans if in need. Both my trucks were reg cabs.GL
  7. Jul 29, 2014 at 8:36 AM
    tacomabilly
    ANSWER: Ext. cabs have to have the intermediate shaft shortened about 3" to accommodate the longer 5sp/4wd tranny. Auto trannies are shorter and require a different cross member mount. Crossmember mounts between 5sp and auto's (in regard to mount holes and bolts on the frame) are identical and inter-changable. Finishing my swap today!
  8. Jul 29, 2014 at 9:19 AM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    You'll be happy with the swap ;)
  9. Jul 30, 2014 at 6:16 AM
    Andy.G
    Andy
    Virginia
    I had two identical trucks except transmissions. Swapped 5 sp into truck that was auto. Crossmember was to far back by a few inches to mount. Took extra crossmember and bolted to side of the other, worked. Than welded extra support. Think I could have found support to mount from tundra or diff yr taco though.
  10. Aug 5, 2014 at 5:28 AM
    BamaToy1997
    Bill
    Navarre, FL
    And how do we know that answer? :D:D:D:D We sure tried to get different ones to fit! At least we have you an acceptable temporary transmission mount set up until you can get a more permanent solution.
  11. Aug 5, 2014 at 8:16 AM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    They sure can. Not familiar with that on our trucks, but my 84 Camaro came with 2 different lengths. Depended if you had the 700R4 or the 200 metric auto transmission. Might have even been a 3rd one for a 5 speed manual
  12. Aug 6, 2014 at 11:11 AM
    tacomabilly
    This might have worked if the frame mounting brackets were in the same spot but they are in different places on a tacoma. Therefore, cross members are not interchangeable but they are compatible. I hacked the center section, took a 1/2" piece of steel and put as a spacer between the two mounts, lined everything up, clamped it and welded it together. Almost factory like….As for driveshaft lengths, this is what I followed and their measurements were dead-on accurate. For me, I shortened to 31" on intermediate shaft and walla, she fit perfectly. Prerunner is now rolling all four thanks to Bamatoy's help!
  13. Aug 6, 2014 at 11:45 AM
    Andy.G
    Andy
    Virginia
    Glad you finished your swap. Mine was much easier. I just sistered mine grade 8 stainless bolts and welded plates to frame and crossmember. Used stock holes and drilled threw 2nd crossmember. Moved trans mount forward to new crossmember and used 5 sp driveshaft.
