Do Tacoma’s Have Issues With New Tires?
Discussion in 'Wheels & Tires' started by e_engstro, Nov 15, 2023.
  1. Nov 16, 2023 at 6:09 PM
    Scott W
    Scott W Well-Known Member
    Scott
    Saranac Lake, NY
    2018 Tacoma TRD PRO. Calvary Blue.
    TRD Performance Air Intake. TRD Shift Knob. KTJO 4X4 Red TRD Push Button Start/Stop. Calvary Blue FOBIK by AJT Design. 12volt Solutions Remote Start with CAR:LINK Smartphone Remote Start and GPS app. Sprint Booster V3 Throttle Response Enhancer. AFE Silver Bullet Throttle Body Spacer 46-38010. 2" Supreme Suspension Lift Kit. TOYO 265/75R16 Open Country A/T2. EGR Matte Black In-Channel Vent Visors. REK GEN Offroad Mud Guards. AMP RESEARCH Power Steps. JDMastar 10000lumes LED Low Beam Lighting T1. JD Mastar Raptor LED Lighting. TRUXEDO Tonneau Cover.
    I have run Geolanders on two previous trucks and one car. I never had any issues. They are a good tire. I presently have been running TOYO's the last couple sets and am real happy with them also. Good Luck
    e_engstro[QUOTED][OP] likes this.
  2. Nov 16, 2023 at 6:15 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Maybe Toyotas are harder to balance for, but I doubt it. My truck came with KO2s on it, I swapped those to Toyo ATIIIs, no issues. Swapped the wheels from Semas to Sport wheels while reusing the Toyos, still no issues. Swapped the first set of Toyos for a second larger set of Toyos, again, no issues.
    So either the Discount I go to is really good (or Toyos just balance super well or both), or the statement about Toyotas being harder to balance tires for might just be crap. Or maybe all the above.
  3. Nov 16, 2023 at 6:16 PM
    e_engstro
    e_engstro [OP] Well-Known Member
    Eric
    Arizona
    2019 Tacoma TRD Off-Road 4x2
    Yeah he’s probably a Toyota hater lol
    SH10151[QUOTED] likes this.
  4. Nov 16, 2023 at 6:20 PM
    Xero
    Xero Well-Known Member
    18 Tacoma TRD Off Road, 22 4R, 08 4R
    18 Tacoma TRD off road OME BP51 front Fox 2.0 Resi rear OME Dakar Meduim Yoko G006 325/75r16 Black Rhino stadium wheels Cali raised ditch light brackets Baja Designs S1 pods Baja Designs Squadron SAE fogs Prinsu Cab rack TRD Pro grille AVS rain guards Backwoods adventure mods hi-lite bumper BL Apex 12k winch Dobinsons 4x4 snorkel Sy-clone prefilter ARB rear diff breather relocation RRW rock sliders RCI full skids At the helm bed stiffeners lil b LCA skids Warfab Phantom rear bumper Warfab tie rod sleeves C4 fender liners Dirt king UCA Duro bump stops
    2x KO2, KM3 and now Gelandar G003 all have balanced fine on my truck.
    SH10151 and e_engstro[OP] like this.
  5. Nov 16, 2023 at 7:25 PM
    Admiral Snackbar
    Admiral Snackbar Well-Known Member
    I have the Geolandars and have been very pleased. And the vibration if it wasn't there before wouldn't be the truck. It would be a tire defect. A vehicle brand wouldn't be a reason for a vibration. Tire defect or bent wheel would be the most common, if the tech did his part correctly
  6. Nov 17, 2023 at 7:32 AM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    I do think Tacoma's have a smaller window of acceptable balance. If you check on the 4runners forums, they have the same issues, actually worse. Hence why a road force balance seems to fix the issue for many.
    There are hundreds of posts on here about balancing issues. There has to be some truth to it.
  7. Nov 17, 2023 at 8:07 AM
    Admiral Snackbar
    A road force balance helps because its the weight of the chosen vehicle on the wheel/tire. It's not balancing the vehicle, its balancing the wheel/tire. The larger the tire, the more you are moving weight away from the lip of the wheel, the more noticeable a balance issue will become. It happens all the time in car sizes as well, it's just less noticeable until its really bad. Fords, Dodges, Chevys, Nissans, Rivians etc will all be affected by tire irregularities. The tire tech plays a big tole here as well, understanding what needs to happen to ensure the best possible outcome, and understanding that some new tires are just too bad to balance and should be replaced
    Brianz1001 likes this.
  8. Nov 17, 2023 at 8:11 AM
    BLtheP
    Plano, TX
    Tire balance issues seem to be from the same brands and tires every time. Meanwhile there are other tires that are successful every time. I don’t think it’s the truck.
  9. Nov 17, 2023 at 8:15 AM
    fourfourone
    Most the issues seem to stem from KO2s and wildpeaks which are prob the 2 most popular tires people run on Tacoma's.
    Both my 2nd and 3rd gen were difficult to get rid of highway shake from the tires. A set of wildpeaks and a set of ridge grapplers.
    Both were remedied with a road force balance at the dealer.
    Never had balance issues like this with any other of the vehicles I've owned. Everything from sports cars to HD trucks.
    Plenty of posts on here too from the trucks shaking brand new right off the lot. Same issues with 4runner which have almost an identical front suspension set up.
  10. Dec 13, 2023 at 5:24 PM
    PTSDTherapy
    PTSDTherapy Well-Known Member
    22 SR5 DCSB
    My two peso bet is they didn’t use the adapter.
  11. Dec 13, 2023 at 5:39 PM
    LanceRN
    LanceRN Well-Known Member
    Lance
    1998 Purple Tacoma TRD
    First off, I was a manager for an automotive performance shop, we did tires all the time. Toyotas were easy to balance for, no vehicle is "pickier" than another. I did Porsches, BMWs, Mercedes, etc with zero issues. It's all about doing the balance right. It is true that some tires ride better than others, just depends on the tire. I never had a bad ride with Hankooks though, and we sold a bunch of them of all types. I can definitely tell you it wasn't the truck, and them moving the tire around is just bullsh*t. What are you supposed to do when you rotate your tires, keep that one there? If the steering wheel is vibrating, it's the front. If you feel it in your butt, it's the rear. Ultimately, a Road Force balance will tell the tech if the tire is bad, or if it just needs a better balance. When it's on the balancer you can see if the tire is out of round, but Road Force is more accurate.
  12. Dec 29, 2023 at 2:14 PM
    Sunstroke#65
    Sunstroke#65 New Member
    Arizona
    2022 Toyota Tacoma TRD 4x4
    I bought Yokohama Geolandar A/T tires for my 1949 Willys wagon 4x4 a year ago stock wheels for 4x4 mostly & they work fine from Discount Tire. No balancing issues.
    Thinking about replacing my stock Goodyear Wrangers A/T tires with the same for my 2022 Tacoma. The stock Goodyears seem to wander or squishy sidewalls on the freeway. . .
    Update - last week, Discount Tire boosted my tires PSI to 36 on all four. Rides a bit better now on the stock Goodyears . . . we will see. 10.5K miles.
    Discount Tire likes this.
