Do Tacomas Like the Cold?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Flo_TRD07, Nov 6, 2022.
  1. Nov 6, 2022 at 8:59 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Don't try to do Jeep things with your truck
  2. Nov 7, 2022 at 3:38 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    Welcome to the world of ice fishing. Start shopping for a ice auger, fish finder, shelter. I would definitely get a 4x4 before leaving CA. More of a choice not getting a truck all rusty, if you buy used.
    Flo_TRD07[OP] likes this.
  3. Nov 7, 2022 at 3:44 AM
    G2.M6
    G2.M6 Well-Known Member
    Fort Collins CO
    1980 Toyota Truck MT "shifty" 1981 Toyota Truck "little orange" 2023 Solar Octane MT "Solaris"
    A few, mainly added skids. I like leaving the suspension alone. I drive forest service dirt roafs in the desert west extremely extremely too fast. Toyota nailed this suspension going 65 across desert terrain. Changing it is dumb unless you have a specific need like crawling or mud.
    Just a thought about your 2x4. I grew up in Nome Alaska. We know snow. 2x4 is fine. We are taught as kids "you never drive in 4x4" you save your ass with 4x4 after you get stuck in 2x4.... seldom do you "unstuck" a truck from 4x4 without another truck or serious digging.
  4. Nov 7, 2022 at 4:13 AM
    AKBorealis
    AKBorealis Active Member
    22 MG Taco OR DCLB
    44 years in Alaska:
    Get the 4x4, dedicated snow/ice tires, block heater...undercoating is a good preventative measure.
    Flo_TRD07[OP] and jackn7 like this.
  5. Nov 7, 2022 at 4:17 AM
    pearing
    pearing Well-Known Member
    Wisconsin
    2015 SR5 quadcab
    True that-the VW undercoating will keep it together long after the metal is gone...
  6. Nov 7, 2022 at 4:28 AM
    EdgemanVA
    EdgemanVA Well-Known Member
    Virginia Beach
    2008 X-Runner
    Several
    What if he doesn't want to break down every other week?
    bebo_junker likes this.
  7. Nov 7, 2022 at 4:29 AM
    EdgemanVA
    Virginia Beach
    2008 X-Runner
    Several
    Might want to install "tow hooks" on both ends for the times you do get stuck.
  8. Nov 7, 2022 at 6:16 AM
    lost
    lost Member
    Josh
    Flagstaff
    ASU Stickers
    I moved to MN last year and brought my 2014 TRD OR. A few things that I've noticed during the winter; The truck simply runs best if given time to warm up on the really cold mornings. Its sucks to just let it run 20+ mins just to drive around a few miles at a time. I started to look into block heaters because it seem to be such a hassle to let it run so much in the driveway. On the really cold days, when the high is in the single digits or lower, driving it anywhere without being able to let it warm up really sucks. I have a 6 speed manual and the clutch will actually just stick when depressed and hardly move at all to get moving. I really didn't have the luxury to let my truck warm up right after work on those really cold days and trying to drive anywhere for a few miles while it warmed up was never ideal. I'm sure the rest of the drivers on the road are dealing with the same thing regardless of make and model.
  9. Nov 7, 2022 at 6:45 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    Imo, it depends what you plan to do w/ the truck. If you're going to be in the twin cities and really only planning to stay on maintained roads, I don't see why rwd would be a problem. Some winter tires and undercoating would likely be cheaper than another truck.
    However, If you think the truck has a soul and want it to live a care free life, then maybe sell it before you leave the dry, sunny south:p :burnrubber:
  10. Nov 7, 2022 at 7:57 AM
    MSgt O
    MSgt O Well-Known Member
    2013 Tacoma
    I was born and raised in MN, first duty station was Travis...Stationed at Herbie...were like distant cousins. IF youre going to live in the cities, 2wd is fine. If not, and youre planning on staying in MN for the foreseeable future, a 4x4 will be a better fit for the long term. and you may want to consider swapping to the reserve unit in MN (ugh C-130s) unless you like the UTA weekends in sunny florida, but man what a PITA to do that every month. Maybe your unit will consolidate your UTAs into like a 2 week thing...but truck wise..a 2wd around the cities will work fine, they keep the roads almost clear. Good luck on your move and setting up a new life in MN!
  11. Nov 7, 2022 at 9:40 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    As some have already said, sell your truck and get a 4WD version. I tried the whole 2WD truck with sand bags in the back and it did not work. The people who say you'll be fine with 2WD and sandbags are lying to themselves and others.
    But, try and find a 4WD while you're still in California. Minnesota 2nd gens will be pretty damn rusty already. Had to get rid of my 2009 due to rust. Get a rust free example and coat the underside how you see fit.
    Flo_TRD07[OP] and Hercanstein like this.
  12. Nov 7, 2022 at 4:42 PM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    Fluid Film, Woolwax, Blaster Surface Sheild, or Cosmoline on the underside. I even spray in the weep holes of the rocker panels and doors. Wash often, at least once a week.
    I've been driving in Minnesota winters for over 50 years and only had a 4x4 for about 5 years. All my trucks were 2 wheel drive and I kept good tires on them, and I survived the winters with them, but the 4x4 sure is nice. Most of the time I went without sandbags. It is a little more complicated, you have to plan your starts better, have a light right foot, and hope you don't get stopped on an incline at a light or stop sign when the roads are iced or snow-covered. It will test your driving skills. The downside of a 4x4 or all-wheel drive is you can get overconfident on take-offs or starts when the roads are iced or snowcovered. You just can not stop any faster.
    I haven't checked for a long time but I don't think Minnesota allows studded tires and I can't say I've seen chains used.
    I'm not advocating this or advising anyone to perform this method, but one trick my brother used on snowy icy roads while he was driving a bread delivery truck with a Cummins in it was while applying the brakes for stop lights or stop signs he would shift it in to neutral. It seems some engines with rear-wheel drive can overpower brakes and icy roads. I've tried it in my 4x4 and it does seem to come to a stop sooner on snow/icy roads. I don't think it will save your bu@@ in an emergency though, just smarter driving habits.
    GilbertOz and Flo_TRD07[OP] like this.
  13. Nov 7, 2022 at 5:35 PM
    Monkeybutt2000
    Monkeybutt2000 Well-Known Member
    I was stationed there 89-93:thumbsup:
    Flo_TRD07[QUOTED][OP] likes this.
  14. Nov 7, 2022 at 6:08 PM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Sand bags are good but I use 11”x11” concrete pavers about 60 lbs a piece. I use six over the axle. My truck is 2WD and believe it or not we get ice mostly in north Texas…even snow on occasion. Good set of tires and don’t drive like a dick.
  15. Nov 7, 2022 at 6:24 PM
    #35
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Do those not slide around and scratch the shit out of the bed?
  16. Nov 7, 2022 at 7:01 PM
    #36
    Flo_TRD07
    Flo_TRD07 [OP] Well-Known Member
    Ben
    2007 Tacoma TRD Sport Prerunner
    Truck things
    That’s what my Grandpa taught me!
  17. Nov 7, 2022 at 7:07 PM
    #37
    Flo_TRD07
    Ben
    Truck things
    Yup I’ll be close to the cities. I have a feeling I’ll be getting some sort of 4x4 anyways it was just in reference to the truck for right now. Didn’t know they could do that… I’m possibly going to be working on a base change anyways so hopefully the once a month thing won’t be too much of an issue!
  18. Nov 7, 2022 at 7:09 PM
    #38
    Flo_TRD07
    Ben
    Truck things
    Thanks for the input! My dad was stationed in fairbanks in the early 80s and he said the most cars he saw spin out or crash, was overconfident 4wd vehicles!
  19. Nov 7, 2022 at 7:10 PM
    #39
    Flo_TRD07
    Ben
    Truck things
    I wasn’t even a twinkle in my parents eyes!:rofl:
  20. Nov 7, 2022 at 8:41 PM
    #40
    Williston
    Williston Unknown Member
    2014 Tacoma DC 4x4 V6 040 [SL] SR5 4x4 [ED] Entune Audio Plus [TO] V6 Tow Package
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and Outside Temperature Display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) MSRP: $27,885 Retail Price As Equipped: $31,845
    Your choices are simple: 1: Stay in California. 2: Get a Humvee: The real Army version :thumbsup: ;)
    Flo_TRD07[OP] and G2.M6 like this.
