Do the 4 cyl motors outlast the 6?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MLB007, Mar 16, 2013.
  1. Mar 16, 2013 at 3:11 PM
    MLB007
    MLB007 [OP] Active Member
    NE Indiana
    06 PreRunner SR5 TRD offroad
    Seems like most of the HIGH mileage I see are 4 cyl.
    Seems like most of the used trucks with rebuilt or "new" motors are 6's.
    And then I see the 4 holds 5+ quarts of oil vs 4 for the much larger 6.
    hmmm
  2. Mar 16, 2013 at 3:25 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    i think that is a fair assumption. a v6, although it only has two more cylinders, needs twice the valvetrain, and is a bit harder to cool and lubricate.
    i have great faith in the 1gr though versus the 3vze and 5vze. i think this latest v6 will add to the reputation of bullet-proof motors, which i think is now all 4 cylinders. starting with the 20r
  3. Mar 16, 2013 at 3:34 PM
    Dwill817
    Dwill817 Well-Known Member
    Drew
    Alabama
    1981 Toyota Pickup 4x4
    ^ Ditto!
  4. Mar 16, 2013 at 3:46 PM
    92dlxman
    Kevin
    Visalia, CA
    well, enjoy that timing belt. :rolleyes:
  5. Mar 16, 2013 at 3:49 PM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    Damn timing belt... Dealer is saying I gotta replace it but I don't wanna! Lol so expensive
  6. Mar 16, 2013 at 4:00 PM
    92dlxman
    Kevin
    Visalia, CA
    point being simply that the 1gr only requires the easy maintenance items, like oil changes, oil filters, air filters, etc.
    i better stop before i break a chain or something:(
  7. Mar 16, 2013 at 4:08 PM
    mick478
    mick478 He is The STig
    Bott
    Stockton, CACA
    2011 White TRD Sport, 4x4 doublemint cab
    Ome 885 coils Ome n9000 front shocks Ome n182 rear shocks K&n drop in filter Duratracs Kenwood kac 90210d Kicker 12" Alpine 800 watt 4 channel Pioneer 430w 6x9 Firestone ride rite air springs
    89-95 3.0 v6 had a real bad problem of blowing head gaskets every 70-90000 miles, hence the unreliable rep, where as the 4s were still the reliable choice once the v6 had a bad rep. In 95.5 the Tacoma came out with a 3.4 and that one was a lot better and longer lasting, and would consider it par with the 4s ever since, depending on how it was taken care of...
  8. Mar 16, 2013 at 4:15 PM
    vbibi
    vbibi Well-Known Member
    san fransisco bay area
    2009 4door long bed
    NO, and straight six last even longer than v 6. lower rpms always make an engine last longer. as well as weight to torque ratios. the littlier the motor, the harder it has to work to do the same thing.
  9. Mar 16, 2013 at 4:17 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Until your throttle cable rusts and seizes. :p
  10. Mar 16, 2013 at 4:20 PM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    Cant say it would matter to me even if the 4 banger did last longer. I could not tow what I need with it and I like having some extra HP on tap.
    I think either will last to 200K with proper maint, which is more most will keep the vehicle for.
    The frame on the other hand is only good to 125K in my area.
  11. Mar 16, 2013 at 4:26 PM
    KenLyns
    Belly of the Beast
    ^I think "rust life" should be measured in years. Our Caravan lasted 13 years before chunks started falling off from the pinch weld and rocker panels; one jacking pad fell off completely.
  12. Mar 16, 2013 at 5:07 PM
    4x4Taco2012
    4x4Taco2012 Well-Known Member
    Tim
    Huntingdon Valley, PA
    2022 DCSB Limited 4x4
    TRD lift, TRD SEMA wheels, TRD skid plate, TRD Pro fog lights, TRD Heritage Grill, OEM bed cover, LT275/70/17 Falken Wildpeak AT3Ws, OEM bed lights, OEM all weather floor mats, OEM door skid plates, OEM mud guards, OEM bed mat, Black lug nuts
    The 4.0L V6 holds 5.5 qts of oil.
  13. Mar 16, 2013 at 5:12 PM
    Sohum63
    Sohum63 Member
    Nor Cal
    97 tacoma 2wd and 02 tundra 4wd
    More 4 cyl with very high mileage is probably a lot due to people expecting to drive enough to rack up that many miles will likely pick something more economical. More 6cyl with rebuilt/ replaced motors not sure what would account for that.
  14. Mar 16, 2013 at 6:26 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I would say maintenance being equal I would give the 4 banger the edge.
    My wife had the 98 Sienna Van that is still going strong after > 200K miles, it was the 6 banger that was supposed to be " Sludge Prone ". I replaced a valve cover gasket at 150K miles and it looked shiny and clean as a whistle inside... That was with 3K - 4K mile dino oil changes using 4 oz Seafoam in the oil.
    Benny123 likes this.
  15. Mar 16, 2013 at 6:35 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    I had a 96 2.7 4cyl and now I have an 03 3.4 V6. I think the 4 cyl was a better motor. Felt like it had way more torque and just felt stronger. But having the extra 2 cylinders now is nice when driving around.
  16. Mar 16, 2013 at 6:38 PM
    PcBuilder14
    Brent
    Nor Cal
    Haha didn't mean "way more torque" in a literal manner. Just felt like it! ;)
  17. Mar 16, 2013 at 6:45 PM
    oldblue1968chevy
    oldblue1968chevy Well-Known Member
    Spokane WA/Viola TN
    2000 Toyota Tacoma V6 TRD
    Stock
    My dads tundra 3.4 has much more power than my 2.7
    You smoking crack brent lol
    *or mines just a dog :(
  18. Mar 16, 2013 at 6:47 PM
    kcbmx
    kcbmx doing my thing.
    Marco
    Bakersfield CaLiFoRnIa
    2tr-fe 4wd
    spit cup, weathertech floor mats, riffle rack, and bilsteins.
    5 speeds make you feel like you can go fast:burnrubber:
  19. Mar 16, 2013 at 6:51 PM
    PcBuilder14
    Brent
    Nor Cal
    Haha acceleration wise my 3.4 is great in comparison. It just seems like when my 2.7 was in 4lo in 1st gear it could pull anything! My 3.4 has a lot of torque too, it just doesn't feel like as much. :notsure:
  20. Mar 16, 2013 at 6:59 PM
    TexasCub
    TexasCub Well-Known Member
    2013 PreRunner
    My neighbor has a 2nd gen DC with a 4.0 and he has over 200,000 miles on it, still runs like a top. Cant imagine how you could say one motor is better than the other in longevity, lots of 3.4 and 4.0 V-6's as well as 2.7's out there with over 200,000
