Do the 4cyl 2nd gen. trucks have the head gasket problem?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kidthatsirish, Nov 7, 2017.
  1. Nov 7, 2017 at 6:17 PM
    kidthatsirish
    kidthatsirish [OP] Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    Well....has anyone with the 4cyl in a 2nd gen had this issue?
  2. Nov 7, 2017 at 6:28 PM
    Clearwater Bill
    Billy
    Largo Florida
    You mean failure 'just because'?
    Any will fail if abused by overheating.
    I've been around here a while and don't recall reading about this as a recurring issue.
    Suggest running some searches in the 4 cyl forum.
  3. Nov 7, 2017 at 6:31 PM
    kidthatsirish
    Yes as in just because. I have never taken my truck beyond 4500 rpms (maybe not even 4000 rpms) and I have rarely towed.
  4. Nov 7, 2017 at 6:36 PM
    Clearwater Bill
    Billy
    Largo Florida
    So you have a failure?
    As a side note, neither RPM nor towing should have anything to do with it unless they contributed to overheating. And while that is the most common reason for failure, sometimes stuff just happens.
  5. Nov 7, 2017 at 6:40 PM
    kidthatsirish
    No...I dont have a failure...I just want to know so I can prepare ahead of time if its prone to the 2nd gen 2.7l engine.
  6. Nov 7, 2017 at 6:48 PM
    Clearwater Bill
    Billy
    Largo Florida
    Keep the cooling system healthy and odds are you'll never have a problem.
    blu92in99 and Jimmyh like this.
  7. Nov 7, 2017 at 8:02 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Usually when a head gasket blows with normal usage and not over heated it is either a bad designed gasket or the coolant is old and has gone acidic which will eat the gasket.
  8. Nov 9, 2017 at 8:35 AM
    kidthatsirish
    Ok...I think my question must be worded poorly.
    The 4.0L v6 is supposedly known for a bad head gasket design that fails premature and without hard stress on the engine. Is the 2nd gen. 2.7L engine also known to have this issue? Nothing is wrong with my trucks head gasket. I am just wondering if the problem is tacamo wide or just specific to the 4.0
  9. Nov 9, 2017 at 10:17 AM
    Clearwater Bill
    Billy
    Largo Florida
    4.0, solved sometime during the '06 production run IIRC.
