Do the monthly 4 wheel drive 10 mile exercise?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Char666, Jul 28, 2012.
  1. Jul 28, 2012 at 5:22 PM
    Tacoma Mike
    Southern Maine
    Yeup....
  2. Jul 28, 2012 at 9:13 PM
    DR Da_da
    DR Da_da Infrequent Member
    Alabama
    '06 4x4 V6 TRD Offroad auto access cab
    ToyTec ultimate lift, LR UCAs, TRD gen 1 CAI, TRD cat-back, bull bar, anytime fog lights, lighted 4x4 switch, factory SS step tubes, factory interior lighting package, factory VIP 3200 alarm, FJ TRD center caps, rear diff breather relocate, tint, bug deflector, Weather Tech liners
    I've heard that engaging 4x4 on pavement is something to NEVER EVER EVER EVER EVER do because the front and rear wheels and/or diffs and/or drive axles may be rotating at different speeds. I've also heard that it's okay to do, as long as you don't turn.
    So what's the troof? :notsure:
  3. Jul 28, 2012 at 9:15 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Straight line is fine
  4. Jul 28, 2012 at 9:25 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    I do about 140/ month...lol
  5. Jul 28, 2012 at 9:35 PM
    joes06tacoma
    Joe
    Central Coast, CA
    This.
    I just engage the four wheel drive and locker on the side of the road, off the pavement. Last time my locker wouldn't disengage right away. They definitely get sticky.
  6. Jul 28, 2012 at 9:37 PM
    OffroadToy
    OffroadToy kokanee smoker
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Read the links below and you be the judge...
  7. Jul 28, 2012 at 9:42 PM
    Goflight2
    Goflight2 Well-Known Member
    Southern Cal
    Supercharged 2011 4x4 LB
    TRD Supercharger Snug top SL Window Tint 5% rear, 35% front, 40% windshield Avid Off Road bolt on sliders Andres Toyota Horns Hard-wired Garmin Nav Weather Techs 5100's in front Rear TSB Bed Extender OEM Roofrack TRD Exhaust Ultra gauge 18" Monster XD's on Nitto Terra Grapplers
    I engage once a month.
  8. Jul 28, 2012 at 9:49 PM
    DR Da_da
    Alabama
    Ha, ha! At first, I thought "Crap. I couldn't just get the CliffsNotes version. I actually have to do some researching." Once I clicked on one of the links the first line read: "Here is why part time 4WD should not be used on pavement:" I stopped reading right there (kidding, I read a couple more sentences :D).
    Here's another qoute from the link: "Part time 4WD should not be used on high traction surfaces! Even when going straight most of the time, slight differences in tire pressure front to rear or vehicle load resulting in different axle speeds will cause 'wind up' and eventually damage."
    Thanks!
  9. Jul 29, 2012 at 5:21 AM
    Tacoma Mike
    Southern Maine
    Straight is fine however one item lots of people don't understand or think about is when people don't rotate tires or replace only 2 on the same axle. New and used tires can have a big difference in circumference. This alone causes hard or non engagement of a 4wd system in ANY MAKE. Once engaged though there can be added stress on the drive line as the tires are trying to equalize each other.
    So basically, of you keep your eye in your tires wear pattern and keep them relatively even there is no reason not to worry about straight line engagement.
    On another note. These trucks are not made out of paper. When your off roading and your climbing rocks , hills, stumps etc, you are winding up the drivetrain to a certain extent. Just use common sense. Keep your toy in good shape and learn how it feels.
  10. Jul 29, 2012 at 5:50 AM
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    Front diff is always spinning unless you have manual hubs.
    Auto hubs is vacuum and as others stated simply actuates the actuators.
    Drive shaft would benefit more from utilizingthose zerks.
    Also important is elocker if applicable. They do get stuck open.
  11. Jul 29, 2012 at 5:51 AM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    Also, wheels would only spin different speeds if different gearing between two diffs, lockers is different.
  12. Jul 29, 2012 at 8:37 AM
    OffroadToy
    You done good grasshopper. There's different views on this....you be the judge. Personally, I'd much rather engage 4wd down a dirt/gravel road than on pavement...period.
  13. Jul 29, 2012 at 11:17 AM
    Silver Streak
    Silver Streak Well-Known Member
    Westin Bull Bar
    I do it on a straight road a couple times a month.
    It cycles the oil pump and oil in the transfer case, and keeps the gears and parts inside the transfer case lubricated. It is an important part of 4x4 maintenance i believe.
  14. Jul 29, 2012 at 2:51 PM
    Silver Streak
    Westin Bull Bar
    I learned something toady :)
  15. Jul 29, 2012 at 6:12 PM
    #35
    jtgroce
    jtgroce Got R Did
    In the Foothills, NC
    '12 Taco MGM TRD Off Road
    K&N Air Filter Husky Floor Liners Weathertech Vent Visors LED Map/Dome Light Mod Chrome Door Handles AVS Bugshield Bed Mat Fog Light Anytime Mod DTRL LED's Flowmaster Super 40
    I reckon I'll be doing this soon
  16. Jul 29, 2012 at 9:11 PM
    #36
    brianv3ntura
    brianv3ntura Well-Known Member
    Jacksonville FL
    MGM'12 Taco TRD Sport 4x4 DCLB 4.0L 5spd Auto
    Stock for now.
    Didn't even know this. learn something new everyday.
    The truck hasn't even seen anything else but pavement yet.
  17. Jul 29, 2012 at 9:25 PM
    #37
    kyleTRDtaco12
    kyleTRDtaco12 Well-Known Member
    Kyle
    New Jersey
    2012 Toyota Tacoma Base DCSB 4x4 V6 6MT (202)
    TRD Cat-Back Exhaust TRD Sport Package Springs & Shocks (Front Linear Coil Springs, Rear TSB Leafs) Front & Rear Toyota/Bilstein 40mm Shocks) Silver Toyota 16" SR5 Wheels with 265/70/16 BFGoodrich Rugged Trail T/A Tires w/ Locks OEM Black-Chrome Housed Headlights (SR package) OEM TRDpro Grille Insert RokBlokz Rally MudFlaps w/ Stamped Logo OEM 'TRD Sport' Bedside Graphics TRD QuickShifter w/ TRD Shift Knob Hawk HPS Front Brake Pads w/ Brembo Blank Rotors OEM Front Aluminum Skid-Plate eBay TRD seat covers Rear Diff. Breather Mod A/C Drain Extension Mod OEM Fog Light Kit OEM Intermittent Wiper Switch OEM Bed D-Rings OEM Bed Mat OEM Door Sill Protectors Blacked-Out Badges (from Xrunner 205 Black Sand Pearl) Pop & Lock Tailgate Handle TruXedo TruXsport Roll-Up Tonneau Cover AVS BugFlector II Front Bug Guard AVS In-Channel Window Vent Visors TRD High Pressure Radiator Cap Stubby Radio Antenna Ultra-Gauge EM v1.2 w/ Windshield Mount BullaCulla 7-Pin Relocation Bracket Misc. Stickers
    but what if you just want to engage the 4wd on pavement just to make the fluids circulate and do this monthly exercise?? i dont want to bring my truck off road to do that.. and im sure as hek not going to drive on the highway at highway speeds to do that either, so what is wrong with going down a straight paved road that is near me than at no faster than 20 or 25 mph to do the exercise, is that ok?
  18. Jul 29, 2012 at 9:25 PM
    #38
    kyleTRDtaco12
    Kyle
    New Jersey
    im with you, i had no effin clue, im in the same exact boat
  19. Jul 30, 2012 at 2:43 AM
    #39
    brianv3ntura
    Jacksonville FL
    Stock for now.
    Well I knee about 4x4 and pavement = no no or it okay if youre not turning. I just didn't know 19mi/month was in the manual
  20. Jul 30, 2012 at 6:20 AM
    #40
    ScreamingTaco
    ScreamingTaco Huge Member
    2012 TRD Off-Road AC
    Goodyear Duratracs, TRD cat-back exhaust, bed tool box, bed extender.
    I do up to around 120kph in 4wd during the winter. 5 years with no issues.
    The truck has a 100kph lockout (will beep at you and flash the 4WD light if you try to go into 4H at 101+), but that's only for on the fly engagement. Once you're in you're good to go.
