Do the motor mounts go bad on the Tacoma?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by saugus, Sep 10, 2011.
  1. Sep 10, 2011 at 1:15 PM
    saugus
    saugus [OP] Well-Known Member
    My corolla mounts needed replacement after about 100k miles and would vibrate the car pretty bad. I searched here and don't see much about having to replace them. Do they soften up ever?
  2. Sep 10, 2011 at 1:18 PM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    What year is your Tacoma?
    also what year was your corolla?
  3. Sep 10, 2011 at 1:41 PM
    saugus
    Tacoma- 2006
    Corolla- 1997
  4. Sep 10, 2011 at 1:52 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    The 2005s had a problem with the motor mounts.
  5. Sep 10, 2011 at 1:56 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    Nothing can last forever ya know. Its eventually going to need everything. lol
  6. Sep 10, 2011 at 2:02 PM
    saugus
    Yeah but my corolla mount replacements are part of routine maintenance for most (or all) owners. Just wondering if it is here too.
  7. Sep 10, 2011 at 2:03 PM
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    unless you beat on the truck regularly, you shouldnt need to replace them prematurely.
  8. Sep 10, 2011 at 2:04 PM
    TexasTacoma37
    It is not part of the routine maintainence for tacomas.
  9. Sep 10, 2011 at 2:10 PM
    saugus
    That's what I was hoping. The rear Corolla mount was the hardest job that I did on that vehicle. Total PITA:mad:
  10. Sep 10, 2011 at 2:21 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Motor mounts should last 100k+ miles, unless you have one of the problem years.
  11. Sep 10, 2011 at 2:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    And early 06's. Up until a build date of June, from what I have gathered.
  12. Sep 10, 2011 at 3:35 PM
    saugus
    manufactured 9/13/05:confused:
  13. Sep 10, 2011 at 3:58 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Check the point at which it is welded to the frame. Check for cracks.
  14. Sep 10, 2011 at 8:53 PM
    joes06tacoma
    Joe
    Central Coast, CA
    There seems to be two seperate issues.
    The fourth gen 4runners (03-09), 05-06 Tacomas, and possibly early 07s, also the first several years of FJ Cruisers all have an inherently weak frame mount design. There have been failures on all of these when used hard off road.
    In addition, the early 05s had a welding problem that has caused failures under normal street driving conditions. I believe we are talking about build dates in late 04 and early 05. My truck is 12/05 and appears to be okay. It has not been off roaded hard. I will not worry about mine unless I take up high speed off roading, which is not likely to happen.
