Do the new trd offroad have ride height on the 5100S
Discussion in 'Suspension' started by 15foxrzr, May 28, 2022.
  1. May 28, 2022 at 10:57 AM
    15foxrzr
    15foxrzr [OP] New Member
    Todd
    2022 Tacoma TRD Off Road 4x4
    Do the new trd offroad have ride height on the 5100S?
    Asking for a friend ;)
  2. May 28, 2022 at 7:51 PM
    ZMan2k2
    ZMan2k2 “Hold my beer and watch this!”
    Richard
    Under a tinfoil hat
    ‘25 SS Red Sport Prem.
    I don’t have an answer for you. I think what you’re asking is, “Are the shocks on my new Off-Road ride height adjustable?” Easiest way to tell is to look above the spring perch. If there are grooves in the shock body, it is likely.
  3. May 29, 2022 at 12:10 AM
    15foxrzr
    Todd
    Yes that is what I'm asking, however I don't have the truck yet, it will be a couple more weeks. Then I will check them out.
    Thank you,
    Todd
  4. May 29, 2022 at 6:55 AM
    ZMan2k2
    Richard
    Under a tinfoil hat
    @15foxrzr Understood. Maybe someone else will chime in.
    Although, the only lift I’ve heard those coilovers giving is when they are taken off a 3rd gen and put on a 2nd gen.
  5. May 29, 2022 at 7:05 AM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    They don’t have 5100s unless you ordered it with the TRD branded lift kit. In that case the answer is yes, the front 5100s have different locations for the spring perch clip.
    ZMan2k2 likes this.
  6. May 29, 2022 at 7:08 AM
    TRD__Chris
    TRD__Chris Well-Known Member
    STL
    2016 Sport
    TRD Off-roads comes with yellow Bilstein shocks that are non adjustable. I believe they are the 4600 series?
    if you want front adjustability you’ll need to purchase 5100’s or you can look at the TRD branded Bilstein lift. There are plenty of threads on both of these shocks if you do some searching.
    ZMan2k2 likes this.
  7. May 29, 2022 at 7:23 AM
    ZMan2k2
    Richard
    Under a tinfoil hat
    Well, I’ve been informed. I’ve learned something. :thumbsup::anonymous:
  8. May 29, 2022 at 7:31 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    The stock shocks on the off-road are not Bilstein 4600s. At least one person has posted a picture of them side by side and the 4600s have a larger diameter.
    The stock off road shocks have no preload adjustment. I have a set in my garage.
    Bilstein 5100s have a finite preload adjustment via a series of slots and a clip.
    TRD__Chris likes this.
