Do these rims FIT?? HELP
Discussion in 'Wheels & Tires' started by JOHNNYSTACO, Mar 27, 2012.
  1. Mar 27, 2012 at 7:46 PM
    JOHNNYSTACO
    JOHNNYSTACO [OP] Well-Known Member
    Johnny
    Toronto
    2011 4 door black Prerunner SR5
    Front Billet grille Tinted tail lights, Tinted windows, 35%-back & 20%-front, Blacked out symbols, Removed mud flaps, Retrax tonneau cover 49" LED tail brake & signial taillight
  2. Mar 27, 2012 at 8:02 PM
    1GR
    1GR Toyota Dealer Technician
    Scott
    BC, Canada
    2012 Tacoma DCLB TRD Sport
  3. Mar 27, 2012 at 8:13 PM
    JOHNNYSTACO
    Johnny
    Toronto
  4. Mar 27, 2012 at 8:24 PM
    1GR
    Scott
    BC, Canada
    Let me put it this way. Your wheels must have :
    6x5.5" lug pattern (6x139)
    Backspacing of 5" (4.5" if going with a wider then stock rim/tire combination)
  5. Mar 27, 2012 at 8:28 PM
    1GR
    Scott
    BC, Canada
    For example. If you want 20" rims. I would recommend 20x9 with a 4.5" backspacing. 6x139 lug pattern. Tire size I would recommend (so you don't have to trim) would be: 265/55R20 (slightly smaller then stock) or 265/60R20 (slightly larger then stock)
  6. Mar 27, 2012 at 8:30 PM
    JOHNNYSTACO
    Johnny
    Toronto
    ok dude thanks for the help
  7. Mar 27, 2012 at 8:33 PM
    1GR
    Scott
    BC, Canada
    No problem. If you want bigger tires then stock, you're going to need to start trimming and modifying.
  8. Mar 29, 2012 at 5:18 PM
    JOHNNYSTACO
    Johnny
    Toronto
    well i wants 20s and i know anything bigger then that should lift the truck or go smaller rim bigger tire..
  9. Mar 29, 2012 at 5:51 PM
    1GR
    Scott
    BC, Canada
    You can go as big a rim as you want, as long as they make a tire the same width and overall height, just expect a much harsher ride. You can have tiny, or large rims with a big tire, just depends how much modification you want to do to your truck for it to fit without rubbing.
