Do tire stores like BIG O' reset tire gauge pressure system?
Discussion in 'Wheels & Tires' started by DeeKay21, Nov 16, 2008.
  1. Nov 16, 2008 at 5:45 PM
    DeeKay21
    DeeKay21 [OP] Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I got some new wheels and tires, 18x9's to be exact, for my 06' Taco and am probably going to Big O Tires to get them installed and get a 3 inch leveling kit. Now does anyone know if they also work on the pressure gauge sensor as well to match the new wheels? If they do, does that cost extra and do they have to put in new parts for it to work right? I know its easy to check my pressures but that light being on in my dash board will just bug the heck out of me so I would want it done right to where the gauge still works on my Taco.
  2. Nov 16, 2008 at 5:46 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    some wheels, the sensors will fit, some they wont. it just depends really. another option is to make a tube from pvc pipe and keep the sensors in it.....just keep it in the truck and the light will stay off. there is a link around here somewhere!!
  3. Nov 16, 2008 at 5:47 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Make sure they know you have a TPMS. They shouldnt charge any more than regular mount and ballance.
  4. Nov 18, 2008 at 12:22 AM
    FoxySandChick
    FoxySandChick Well-Known Member
    Kristin
    Henderson, NV
    07 DC 4x4 Base model V6 Impulse Red Pearl
    De-badged, limo tint, black wet okole's, weathertechs, extra d-rings, TSB bilsteins
    I got charge extra for them to be put on my new rims, I think it was like $12 total for a "TPMS kit" which had something to due with replacement valve stems I believe, probably depends on the shop though. It shouldn't be a large amount if they charge anything.
  5. Nov 19, 2008 at 4:21 PM
    Taco's for All
    Taco's for All Well-Known Member
    Lake George, NY
    2019 Tacoma TRD Off Road Double Cab
    Nothing at the moment
    Place by my charges $5 per wheel to change the TPMS. They did state they they put a new valve stem in, nothing else changes.
  6. Nov 19, 2008 at 4:37 PM
    David Tarantino
    David Tarantino Well-Known Member
    N.J.
    08 tacoma
    If your changing/replacing a tire at lest in my store
    its part of the service mounting/balancing
    My guys are trained to make sure the light
    is OUT and no their is nc
