Do TRD rims requires new lugs?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoMan1265, Jul 8, 2021.
  1. Jul 8, 2021 at 7:41 AM
    TacoMan1265
    TacoMan1265 [OP] Member
    Fredy
    Toyota Tacoma SR5 2010
    I have a 2010 Tacoma double cab with the 16” rims on it. Have a 3” front and rear lift on it and I recently purchased black OEM 17” TRD pro rims for my vehicle. I’ve seen other Tacomas with the same wheels so I know that they fit however I was wondering if I’ll need new lug nuts for these rims. I know I’ll definitely be needing new tires and that’s on my list anyway.
  2. Jul 8, 2021 at 9:25 AM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    I believe those rims will need the Lugnuts that have the quarter inch neck on them they’re a little bit longer
  3. Jul 8, 2021 at 9:28 AM
    Archangel
    Archangel Special Assistant to the Regional Manager
    Charlotte, NC
    '04 T4R SR5 4x4
    It depends. If you have steel wheels, then yes you will need new lugnuts. If you've got aluminum wheels, you should be ok. However, why wouldn't you get a new set of lugs with a new set of wheels? 11 year old lugnuts likely have some sort of surface rust, rounding, etc. Why wouldn't you get new lugs for new wheels?
  4. Jul 8, 2021 at 9:32 AM
    TacoMan1265
    Fredy
    yeah I think I’m going to go ahead and purchase some black lugs. Any recommendations? I might just go on Amazon and see which lugs people usually go with along with the TRD rims
  5. Jul 8, 2021 at 12:08 PM
    Archangel
    Charlotte, NC
    '04 T4R SR5 4x4
    You need to make sure you get the Mag Shank style of lugnuts. These will work fine. Problem will be over time the black will flake off. You're better off (In my opinion) just purchasing new regular lugnuts.
    https://smile.amazon.com/Veritek-12...7------------5&vehicleName=2010+Toyota+Tacoma
