Do We Have Any Amsoil Users?
Discussion in 'Technical Chat' started by dysfunctnlretard, Dec 4, 2010.
  1. Dec 4, 2010 at 1:20 PM
    dysfunctnlretard
    dysfunctnlretard [OP] Hi
    Manny
    CA
    2021 Jeep Rubicon
    The oil change interval for the new 1GRFE engines is 10k miles with 0w-20. I was gonna settle and do 7,500 with Mobil 1 but I'm starting to think it may be easier, and perhaps better, to just do an oil change once a year and use Amsoil. Amsoil is rated to last 15k-20k miles so it should last according to them, but was wondering if anyone else had some feedback on this oil. Im only going 10k-12k miles a year on the FJ.
  2. Dec 4, 2010 at 1:26 PM
    747 function > form
    1st Gen.
    Will the filter function (i.e., "filter") for that many miles...seems like it would get gunked up?
  3. Dec 4, 2010 at 1:31 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    yes!! i use a mann filter ml1003
  4. Dec 4, 2010 at 1:35 PM
    dysfunctnlretard
    Manny
    CA
    2021 Jeep Rubicon
    Amsoil makes "extended performance filters" that last longer than 10k miles but they dont have one for the new 1GRE so theyre swearing buy a WIX filter which is also an "extended performance filter" and it's supposed to be a high quality filter as well but I'm still in the process of checking that filter out. My plan is to run the oil for a yr then do an oil analysis but I'm trying to get some basic feedback to see if it's even worth trying.
  5. Dec 4, 2010 at 2:07 PM
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    Toytec TRD PRO LIFT with 1.5 SAW in rear, 255 Coopers, Baja Rack, Southern Style Front Bumper, Warn Wireless Winch, DeMello Sliders.
    I have been using amsoil and have had two oil tests done at blackstone labs. First one at 5000, second one at 10000. They advised to not go to extended intervals yet because of the break in particles still in the samples. I am getting ready to send in my 20,000 mile sample so we will see what it says. Dont really care about going a year but nice to know I could.
  6. Dec 4, 2010 at 2:08 PM
    crf69
    Ohio
    ummm yeah
    subscribed
  7. Dec 5, 2010 at 7:45 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    Keep the air filter changed and you'll have no problems with the oil filter.
    Think about it: if the (fully broken-in) engine is MAKING particles big enough to be a problem that the oil filter needs to catch...you got a bad engine! Main purpose of the oil filter is to catch particles that are drawn in to the engine from leaky vacuum fittings, bad air filter, leaking intake plumbing and...oil changes and checking the oil level even!
    But, even so, it's commonly done to change the oil filter periodically. The oil anti-corrosion protection needs the kicker by the fresh oil added to be able to do 15-20K safely.
    An owner is rolling the dice if he runs such long intervals without doing oil analysis anyway. Amsoil makes the claim that their oil will go that long and I'm sure it will (I've seen where guys run petroleum oils 10-15k safely) if everything is working just dandy and to that end there are a ton of provisos that go with it. Good luck fighting with them if your engine seizes with 19K on the oil and no UOA's to show you knew the oil wasn't being degraded by over-rich fuel mix or a coolant leak or a dirty/bad air filter or leaky intake/vacuum plumbing.
    Just sayin'...
  8. Dec 5, 2010 at 8:36 AM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    I use Amsoil and change it once a year, and I also use a Wix oil filter and change that every 5K miles. Amsoil is guaranteed for 25K miles for normal service (back and forth to work, etc.) and 15K for severe service. It's a great Group IV oil, whereas Mobil 1 and the rest of the well known synthetics are a Group III. I have run it in all of our vehicles and never had a single problem with it. When we had some work done on our Sierra, the GMC tech. said it was one of the cleanest engines he had ever seen on a truck with 120K.
    BTW, do NOT go above the recommended change interval with regular oil (dyno), I don't care how many people say it will do it safely because it does not have the capability to do so.
  9. Dec 5, 2010 at 8:42 AM
    Anthony
    Anthony San Antonio Detailer :)
    Houston - Spring/Tomball area
    06 prerunner access cab 2.7L M5
    Nfabs Afe Pro Dry UWS linex'd toolbox
    so... even though the oil is good for 15-25k, the filter still needs to be changed out periodically in between?
  10. Dec 5, 2010 at 8:42 AM
    crf69
    Ohio
    ummm yeah
    awesome!
  11. Dec 5, 2010 at 8:42 AM
    crf69
    Ohio
    ummm yeah
    yes....i switch out a mann filter every 6 months or 7500miles
  12. Dec 5, 2010 at 9:25 AM
    buddywh1
    Philly PA
    07 DC SR5 4x4
    Interesting...in a real-world test M1 lasted longer than Amsoil which got nowhere close to that 25K service guarantee.
    http://neptune.spacebears.com/cars/stories/mobil1.html
    http://neptune.spacebears.com/cars/stories/amsoil.html
    Read them yourself.
    Whatever your point is about gp IV vs gp III and III+, it makes no difference. Real world performance provides the proof that M1 is at least as good as Amsoil.
    And regardless of what you are maintain, actual real world performance supported by UOA's shows that API SN petroleum oils are performing spectacularly even in the 10-15k range. I would never recommend it...but I'd never recommend anyone using Amsoil to 25k without UOA's either, which you are suggesting it's OK to do and the real-world tests linked above demonstrate quite elegantly would be insanely stupid to follow.
  13. Dec 5, 2010 at 10:03 AM
    Incognito
    VA
    Those links are not dependable at all. They may be real world tests but there are way too many variables to be consistent with the true nature of the oil. Somebody reports a thickening of viscosity, but what they don't tell you is they live in a climate where it doesn't get about -10C during the day, in the winter. Not a reputable test at all if you ask me. How about a lab test of Mobil 1 and Amsoil in controlled conditions.
    http://www.smartsynthetics.com/articles/nothing_outperforms_mobil1.htm
    Now you are claiming no difference in the Group III and IV, but that's not what you were saying here:
    You say Group III and III+ are as good as Group IV, but then you go on to say it makes no difference. Point is, the information in these posts are contradicting.
    I am not suggesting anybody to run Amsoil to 25K, I have just stated that they guarantee it and that it's capable to do so. Mobil 1 will NOT say their oil can be changed on a 25K interval...
  14. Dec 5, 2010 at 10:15 AM
    buddywh1
    Philly PA
    07 DC SR5 4x4
    LOL...so someone's well documented tests are ignored while we should believe your total lack of proof and reams of marketing hype instead.
    OK.....this will go nowhere so this is my last post....
    I didn't say there's no difference between III/III+ and and IV...I said whatever you POINT is about the difference your POINT doesn't matter since there are real world tests illustrating that in use, whatever the differences are, they don't matter that much for actual performance.
    But you don't want to look at some facts and deal with them.
    So there's no point in this.
    Enjoy your oil.
  15. Dec 5, 2010 at 10:24 AM
    Incognito
    VA
    You're missing the point. I stated that the links you provided are not dependable due to the MANY variables (ex. different vehicles, different climates, different engines, etc. ) The links I provided show a test between Mobil 1 and Amsoil in controlled conditions, with a constant for each test instead of many different conditions. Look, I think Mobil 1 is a good oil and has it's positives, but I think Amsoil out performs it in a number of tests.
    I'll use my Amsoil, you use Mobil 1, and we'll call it a day.
  16. Dec 5, 2010 at 11:47 AM
    buddywh1
    Philly PA
    07 DC SR5 4x4
    Ok...so I lied...I had to respond...
    The very reasons you said the real world test isn't 'dependable' are the very reasons they are the most important!
    From just what little I've learned, motor oil chemsitry is incredibly complicated with a lot of interdependent factors. Some factors may look great, and none bad, but in use they don't stack up quite like you think they should.
    Real-world testing is just that: real world. Those things happen and your oil has to deal with it. The Amsoil started out that real-world test with a nice high TBN, just like the link you provided showed, and it hung in there reall good, but then it just tanked at the end and he wouldn't chance his 10K Z1 motor with it anymore.
    What didn't perform well through the test: Amsoil sheared out of grade; it was well on it's way to 50w in the engine when TBN went out and they changed it. Now THAT is a characteristic of the base oil, which is supposed to be superior PAO only. Why didn't it hold up in service? Who knows...but it didn't.
    So then, lets consider those discrete tests in your links: commenting on three: TBN, four ball test and the pour point. Amsoil is shown to perform well, but then the characteristics of a lubricant that affect performance here can be and are modified - improved - by additives. I'm sure all oil manufacturers do it and Amsoil is no different. But as I've said, oil chemistry is very complex and interdependent: you add a little here you wind up having to take something away there.
    Could any of that have played into the reasons why Amsoil didn't hang in there? Am I saying Amsoil is made inferior because they are great on those tests? NO!! All I'm saying is that with anything complex, and motor oil formulation is most definitely very much so, the whole is vastly more than the sum of it's parts! One can NOT look at discrete measurements alone and think that tells the whole story.
    The way you demonstrate how your compromises play out is with real-world demonstrations and ultimately, Amsoil did well! Just not the 25 K miles I think it should for me to suggest anyone run it out there, especially without UOA's. And nowhere close to the hype.
    Their guarantee is worthless, IMO, and it depends much on the fact that modern engines will last 100K easy run on tractor oil, as someone elsewhere put it, that's never changed.
    That's real world.
  17. Dec 23, 2010 at 8:51 AM
    trdchic
    trdchic Well-Known Member
    Erie CO
    07, TRD Sport, 4x4, SR5, V6, Access Cab
    Wow, you guys are fiesty! I think Amsoil is too expensive for meee...
  18. Dec 23, 2010 at 8:55 AM
    98tacoma27
    Ben
    Not Beech Creek
    My truck lives and runs in a variable environment.
