Do we need new oil drain plugs every time?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Andiamo, Sep 9, 2021.
  1. Sep 11, 2021 at 7:50 AM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    same reason you wouldn't use ur own torque spec on lbjs. to each their own tho, ur vehicle is not mine
  2. Sep 11, 2021 at 7:55 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    I've never torqued down an drain plug on any vehicle. Never once had an issue. That's 27 years of non issue.
    TWJLee, Knute and Bivouac like this.
  3. Sep 11, 2021 at 8:10 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    30 ft-lbs isn't that much. Just playing with a beam wrench and a 3/8" ratchet it was pretty easy to hit.
  4. Sep 11, 2021 at 8:11 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    I second this !! though in my case closer to 45 years .
    When torquing the oil drain plug does one wait till the oil pan is completely drained to make sure the threads are completely dry as well as the drain plug oil on the threads will give you a false reading
    Although one time I did forget to put the plug back in at all only two quarts till I heard it hitting the floor.
    Though I hear stories about those quick drain valves so easy to open if some one wants to mess with your equipment.
    Knute and se7enine[QUOTED] like this.
  5. Sep 12, 2021 at 7:59 AM
    Nevin
    Nevin Well-Known Member
    Washington
    03 Tacoma 3.4 SR5 2022 TRD ORP 4Runner.
    OME 881 springs with 3/8 spacer. SCS SR8 16x8 Gunmetal 285/75/16 Yokohama G003 Nitros all 4 corners. Dakar rear leafs. Deckplate mod. Marlin Crawler 1200lb clutch. Redline hood struts. ECGS clam shell bearing. Philips LED headlights. Front Runner bed bars. Katskinz leather interior.
    Which magnetic drain plug you prefer?
  6. Sep 12, 2021 at 8:59 AM
    Nessal
    Nessal Well-Known Member
    Texas/Bay Area
    2003 V6 4X4 TRD DCAB
    Gold Plug. Only brand I use.
    Nevin[QUOTED] likes this.
