Do wired dome lights drain battery?
Discussion in 'Tonneau Covers, Caps and Shells' started by rlofthouse, Jun 19, 2025.
  1. Jun 19, 2025 at 10:03 AM
    rlofthouse
    rlofthouse [OP] Well-Known Member
    Robert
    Bay Area
    2024 Tacoma TRD OR
    Do wired dome lights drain your car battery over time? Any experience with this vs a conventional (ie AA) battery light? Would love a recommendation if theres a good conventional battery light, with sufficient lifespan
  2. Jun 19, 2025 at 10:06 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    I'm not sure what your talking about...Factory dome light or adding a light..
  3. Jun 19, 2025 at 10:09 AM
    Jerry311SD
    Jerry311SD Well-Known Member
    Jerry
    Ramona Ca SAN DIEGO
    2019 tacoma TRD Quicksand
    KDMaxx tune K&N drop in AFE catback Oil catch can Bill's 6112/5160 Dynomat whole inside of cab TRD skid plate
    If the light is off ,NO
    HondaGM likes this.
  4. Jun 19, 2025 at 10:27 AM
    Alex the Great
    Alex the Great Well-Known Member
    2025 OR with factory lift
  5. Jun 19, 2025 at 1:28 PM
    rlofthouse
    Robert
    Bay Area
    2024 Tacoma TRD OR
    to clarify - specifically referring to wire dome light and/or battery options for camper shells
    HondaGM likes this.
  6. Jun 19, 2025 at 1:57 PM
    4x4junkie
    4x4junkie Well-Known Member
    So Calif. (SFV)
    2018 TRD Sport ACLB MT
    If you leave the light on... Yes.
    If you leave the light off... No.
    So the question probably should be: "How long can the light be left on before the battery is drained?", which that will depend on what type of light you use (whether incandescent or LED) and how many bulbs (how much lighting) you use.
    A typical 12W incandescent light should be able to run for several hours from a healthy battery before there's any concern of not being able to start the engine.
    Using LED, can boost that up to a few days, but will also depend on how much light you're adding too (bright LED strip lights can still be pretty power-hungry whereas wedge-base LED bulbs in a light fixture tend to be more efficient). If you keep the total power draw under 6 watts or so (500mA) which should be easy to do with LED lighting, you shouldn't have any trouble unless you plan to be parked for several days (which there are solutions for that as well).
