Do you carry spare axle/hub parts for your TT?
Discussion in 'Towing' started by LFOD, Sep 12, 2023.
  1. Sep 12, 2023 at 5:38 AM
    LFOD
    LFOD [OP] Well-Known Member
    2021 SR5 DCSB
    New to pulling a travel trailer but not new to towing. We have a single-axle camper. Does anyone carry spare axle parts, spindle, bearings, hub, Etc?
    If you do, what do you keep in the truck?
  2. Sep 25, 2023 at 7:52 PM
    AZ Pete
    AZ Pete Well-Known Member
    Arizona
    I don't. In 20+ years of towing a TT I have never needed any of that.
    mosccat and LFOD[OP] like this.
  3. Sep 25, 2023 at 8:07 PM
    Bishop84
    Bishop84 Well-Known Member
    What I do is replace the bearings if they are old and chuck the old ones in my travel kit. Same with wipers belts etc.
    Maintenance trumps spares though, repack and servicing bearings makes them last forever.
    lock, LFOD[OP] and TnShooter like this.
  4. Sep 25, 2023 at 8:17 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    Not my travel trailer but for my boat trailer I carry a spare set of bearings and a grease gun. For the travel trailer you just need to do maintenance on them. Depending on the yearly mileage I inspect and repack the bearings every 2 years. If your travel trailer is used then you should pull , inspect, and repack the bearings just to be sure they are ok.
    LFOD[OP] likes this.
  5. Sep 25, 2023 at 8:48 PM
    545 Well-Known Member
    2015 Access Cab
    Yep, always carry a loaded hub for single axle trailers
    Cheap and nice to have. Tandems can go a ways on three tires
  6. Sep 27, 2023 at 10:44 AM
    Ed_Force_1
    Ed_Force_1 Up the Irons!
    Jeff
    Battle Creek, MI
    2023 Limited Nightshade
    Interior LED lights, hood struts, Weather Tech floor mats, Toyota bed mat, screen protectors, sill protectors, Pop & Lock power tailgate lock, McGard tailgate anti-theft lock, gas cap holder, iArmor drop step running boards.
    I don't carry any of those, but it's not a bad idea if you have the cargo capacity.....I have to watch every pound.
  7. Sep 27, 2023 at 11:17 AM
    Sprig
    Ken
    Heres a suggestion that I think few people think of. When towing a boat or travel trailer I carry an infrared thermometer.
    When I stop for gas or some other reason I check the temperature of the hubs. If the hubs are running hot you have a problem. Also if only one hub is running hot you may as well take care of it soon cause it is going to fail. Just remember if the sun is shining on one side, that hub may run quite a bit hotter than the one on the other side. You can get an accurate infrared thermometer for under $20 at various places including Harbor Freight. They are simple to use, just aim it and pull the trigger/switch. In about 2 seconds you get a digital temperature reading.
  8. Sep 27, 2023 at 11:18 AM
    Ed_Force_1
    Jeff
    Battle Creek, MI
    I have one of those in my camper......never thought of using it for that.
    LFOD[OP] and Sprig[QUOTED] like this.
  9. Sep 28, 2023 at 6:06 AM
    LFOD
    2021 SR5 DCSB
    Thanks everyone for the great advice.
    The trailer is new so the bearings should be good to go for 2 years. I'm running a TPMS with pressure and temp. monitoring but the IR gun is a great idea. I have one so worth keeping to the toolkit.
    Full service and repack every 2 years with inspection in between.
    mosccat and Sprig[QUOTED] like this.
  10. Nov 4, 2023 at 3:44 PM
    mosccat
    mosccat Well-Known Member
    Mark
    Currently in Bend, OR
    2020 OR
    I have a tpms system that keeps an eye on temps, very handy for peace of mind.
    https://www.amazon.com/gp/aw/d/B085C2HMQP?ref=ppx_pop_mob_b_asin_title
  11. Nov 4, 2023 at 3:48 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    In the olden days I did But I found out no matter what I had along a parts run was needed to be up and running.
    Where it get scary is when things are old enough parts can be hard to find.
    Best of Luck!
    LFOD[QUOTED][OP] likes this.
