Do you check your oil?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AnotherSilverTaco, Apr 21, 2012.
  1. Yes, every fill-up because...
    62 vote(s)
    12.6%
  2. Yes, sometimes because...
    259 vote(s)
    52.5%
  3. No, because...
    93 vote(s)
    18.9%
  4. No, but I should because...
    73 vote(s)
    14.8%
  5. Other because...
    6 vote(s)
    1.2%
  1. Apr 21, 2012 at 8:19 AM
    AnotherSilverTaco
    AnotherSilverTaco [OP] Well-Known Member
    South Texas
    2006 Double Cab 4x4
    CBI trailrider rear bumper, CBI Front Receiver, Warn M8000 Receiver Winch in Warn Multi-mount cradle
    I have 88K on my 2006 double cab offroad 4x4. I have never really checked the oil since I bought it. I do oil changes every 3-6k with Castrol full synthetic. It is due for an oil change with about 4k since the last change, so I thought I would check the dipstick. Sure enough it is still well between the marks.
    My question is how long can I push it before I need to get religious about checking the oil?
    Any of you higher mileage guys have a clue?
    What are your thoughts?
  2. Apr 21, 2012 at 8:28 AM
    F75gunslinger
    F75gunslinger Ka like a wheel
    Christian
    Rochester,NY
    SWB '10 Doublecab TRD Sport 4x4
    Cluster and Radio LED swap,Westin bull bar,2nd set of bed tie downs,URD SS,K&N filter,weathertechs
    i check mine on occasion in anything I own. Just a good idea to keep an eye on it..but that being said,It has never really done me any good or harm. I guess it's just another way to keep an eye on engine health.
  3. Apr 21, 2012 at 8:31 AM
    Executive
    Executive Conservative
    Peabody, Massachusetts
    2012 DCLB TRD Sport
    If your vehicle is a "major" investment for you, check your oil once a month or so. You will learn a pattern of oil consumption, if any, and get a feel for how it is running. When something seems wrong, check it.
    If you don't care about keeping your vehicle running at its best, don't bother checking it.
    I'd rather spend three minutes once a month making sure everything is the way its supposed to be. Cheap investment of time as an early warning insurance policy.
  4. Apr 21, 2012 at 8:48 AM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    Aim-ish country PA
    1999 Scooby Doo LGT 2008 P71
    Yes
    If the motor starts knocking I know it's low on oil. :D I'm at about 60,000 miles and have checked a few times and it never burns or leaks any oil. I will start checking more as my mileage increases.
  5. Apr 21, 2012 at 8:56 AM
    Aw9d
    Aw9d That one guy
    Az
    Ever other Saturday is car day at my house. The wife and I check all fluids and tire pressure in all of our bikes/cars/trucks. Doesn't take more than a few minutes on each vehicle to check everything out.
    Maybe it is overkill but my wife and I are really hard on our vehicles, both of us got our lead feet installed at an early age. So I want to make sure whatever we are driving is ready to get used and abused like a $20 hooker.
    *No offense to the $20 Hooker, she was very nice*
  6. Apr 21, 2012 at 10:21 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    with regular oil changes, and seeing no oil loss its hard to worry about it unless you see a puddle... but once you sense a motor starts burning oil, you begin to check it more. I always check my oil when the hood is up...:D
  7. Apr 21, 2012 at 10:22 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    Ya, I check mine. I change it every 5,000 religiously. So I normally check in half way between the change. Checking your oil can tell you alot of things just by looking at it, so I like the peace of mind.
  8. Apr 21, 2012 at 10:23 AM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Diamond Bar, CA
    08 TRD Sport
    Estock
    once a month or everything i open the hood its a quick check so might as well check it :cool:
  9. Apr 21, 2012 at 10:24 AM
    gsxrdoug
    gsxrdoug 2006 DCSB
    Douglas
    Hawaii
    06 DCSB TRD OffRoad
    My Doctor just checked the oil and said it was fine.
  10. Apr 21, 2012 at 10:24 AM
    joes06tacoma
    Joe
    Central Coast, CA
    I check it every other fuel stop on everything I drive. It's been many years since I've had anything that actually required me to add oil. I just think it's good practice.
    My experience has been that if someone lets an oil change go much past 5K, there will be a noticeable amount of oil burned. We lost an engine in a truck at work because the driver never checked the oil, and let the change go to 10K miles. Apparently it burned about a gallon over the 10K miles. :eek:
    6K dollars later we have the original engine (only 70K on it total) rebuilt. It's now burning a quart every 1K miles.:( The driver really, really wishes he checked the oil, and he's very thankful to still be employed.:rolleyes:
    Like others have said, it just takes a couple of minutes. For me I have to know, that's all there is to it.
    I did have a head gasket fail once on a different truck. The first sign was burning coolant. Had I checked the fluids on a regular basis, my first clue would have been a low coolant level in the overflow tank. As it was, my first clue was a steaming truck on the side of the road. That's when I started checking fluids regularly.
  11. Apr 21, 2012 at 10:25 AM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    I do a quick once over on my truck when I fill up. I'll check the motor and trans oil, the air filters, check that all the water hoses are still tight and in good shape, check tire pressure, check spare, lug nuts are tight, etc.
  12. Apr 21, 2012 at 10:50 AM
    elmo7
    elmo7 Easily Replaceable Member
    SC
    07 DC TRD OR 4x4
    Isn't that what the oil light is for, kinda like the gas light - time to fill 'er up? When mine comes on, I get a couple of the 5 qt oil containers and top it off, but no so much so that it spills over. :homer:
  13. Apr 21, 2012 at 10:50 AM
    george3
    george3 Well-Known Member
    new jersey
    tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    You have me thinking - a accomplishment in itself. I think it would be a good idea to check the oil level when I change the oil. That way I will see if there is enough usage to warrent checking it in between oil changes. I have a 2.7 - it's a good motor. My gen 1 2.7 had 130,000 on it when the frame rusted out and didn't burn or leak any oil between changes. I now have 50,000 on my gen 2.
  14. Apr 21, 2012 at 10:51 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    :cookiemonster:
  15. Apr 21, 2012 at 10:55 AM
    AWorthyOpponent
    AWorthyOpponent Member Caught Off Road
    Dan
    Palm Beach County, Florida
    2013 MGM DCLB TRD SPORT 4x4
    TRD Catback Exhaust
    The nearest gas station to my house is Full Service, so they check it along with all the other fluids, tire pressures, and clean my windows every time I fill up there.
    Its worth the $5 tip...
  16. Apr 21, 2012 at 10:55 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    The oil light comes on when there is less than 2 qts in the pan. Are you certain your driving habits will keep oil under the suction line with only 2 qts?
    They call them idiot lights for a reason.
  17. Apr 21, 2012 at 10:57 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    I know, I know ... don't feed the trolls, but it's fun.
  18. Apr 21, 2012 at 11:00 AM
    AWorthyOpponent
    Dan
    TRD Catback Exhaust
  19. Apr 21, 2012 at 2:05 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Got into the habit of checking every fillup when I was a kid.
    Didn't used to have to, but when stations started going self-service, it became my job.
    Once I started driving my own newer vehicles, I've found it a bit of a waste to check every fillup, but I'll pop the hood and do a quick fluids and belt/hose check a couple of times a month.
    My '95 Suburban with 300k on it used to burn a quart every 3k.
    My motorcycle is unpredictable... it'll go 3000 miles and not burn a bit, then it'll suck a quart in 800 miles... but it has a sight glass so checking is easy.
  20. Apr 21, 2012 at 2:06 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    My '05 C7500 work truck has an oil level light.
    10qt capacity, when the light comes on it's 2 quarts low.
