Do You Consider Tire Weight When Choosing Tires?
Discussion in 'Wheels & Tires' started by Sand Shark, Apr 11, 2017.
  1. Nov 21, 2019 at 6:19 AM
    #41
    kevinlambchops
    kevinlambchops Well-Known Member
    Has anyone switched to a lighter tire/wheel combo and noticed different driving characteristics? I currently run Method NV (28lbs) and 285/70/17 Falken Wildpeak E (58.96lbs??). Total is lets say 90 lbs per wheel/tire combo. If I were to switch over to something like the rpt1 which is 18.5 lbs per rim. Only comes in a 16, so if I were to stick with 17" I know some brands are in the 22-24lb range. 285/17/17 C load bfg is 50lbs per tire. That saves ~12lbs rotational mass per corner. Mainly DD my truck and just like browsing the internet for things to buy lol
  2. Nov 21, 2019 at 6:48 AM
    #42
    Kings
    Kings Well-Known Member
    Cole
    Ontario, Canada
    2018 Tacoma TRD OR MGM
    17x8.5 SCS Ray 10s, 265/70/17 BFGoodrich KO2s, 2.5" ADS Ext. Travel coil-overs and shocks with compression adjusters, ICON tubular Delta Joint UCAs, Extended brake lines front and rear, OME medium duty Dakar leaf pack, Locked Offroad hydraulic rear bump stops
    For sure I take into consideration. There are trade offs with everything. A stronger tire is going to weigh more, but that's piece of mind for you out on the trail. But I'd always look at it before making a decision, see if it makes sense for my needs
    kevinlambchops likes this.
  3. Aug 9, 2021 at 5:07 PM
    #43
    jq1604
    jq1604 Well-Known Member
    2017 Toyota Tacoma TRD Off Road 4x4
    Kings 2.5 lift kit
    Planning to go from 315 toyo MTs to 37x12.50 toyo MT. Does this jump dramatically affect the IFS on our trucks? Would running a lesser weight of a tire help this?
