Do you downshift with the auto trans when you brake?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ERdept, Dec 21, 2008.
  1. Dec 21, 2008 at 8:47 PM
    ERdept
    ERdept [OP] Well-Known Member
    I have a V6 Prerunner, with auto trans.
    I have noticed myself shifting down from "D" to the lesser gears when I brake. I notice it helps the truck slow down much faster than braking alone and minimizes my usage of the brake pedal.
    Two questions:
    1. Do you do this too?
    2. Is this bad for the trans to do this?
  2. Dec 21, 2008 at 8:51 PM
    montgomery_30824
    montgomery_30824 Well-Known Member
    Lee
    Guyton, Ga
    '06 prerunner 4dr
    K & N airfilter, custom built 10" sub boxes, pioneer head, mag-lite mod, Blue LED dash lights, custom painted engine cover, mud flap removal mod, alarm/remote start installed,
    I have the same truck but i dont do this. i doubt it will hurt the truck but again i am not a mechanic. When we go to the mountains i down shift to stay off the brakes so they dont get red hot when coming down the mountain but IDK.
  3. Dec 21, 2008 at 8:55 PM
    brianr
    brianr go shit in your hat
    2010 4x4
    BUILT, not bought...
    there was similar thread not too long ago, but I cant find it.
    I use the tranny to slow myself down most of the time.
  4. Dec 21, 2008 at 8:57 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I do this now and then depending on the road Im on. It has no effect on the tranny.
  5. Dec 21, 2008 at 9:09 PM
    w8n4mud
    w8n4mud I'm back.
    Albert
    Chula Vista, CA
    2019 Tacoma Off Road DCSB
    Stock. Purchased 2/17/19. Cement!
    I do it frequently. :D Down shift that is. I try to avoid using the brakes when ever possible. Most of the time, letting off the accelerator works for me! They're for it with professional drivers in order to maintain control of your vehicle. As far as problems, I haven't heard of any.
  6. Dec 21, 2008 at 9:10 PM
    sonjay
    sonjay Well-Known Member
    I also do it from time to time, depending on the hill, my truck seems to hold back pretty well on its own. Remember tho brakes are cheaper then transmissions. I never rev over 3000rpm or so when I downshift.
  7. Dec 22, 2008 at 2:23 AM
    Smurfio18
    Smurfio18 Well-Known Member
    Northridge
    06 Tacoma TRD PreRunner
    I keep it Stock but Clean!
    I do the same thing, sometimes in traffic you just need to downshift to get out of a tight spot. The only time it might be damaging to the truck is if you try and downshift when the truck is rev'ing too high. Even with a manual, downshifting like that will destroy and clutch and transmission.
  8. Dec 22, 2008 at 2:26 AM
    RedTaco2134
    RedTaco2134 Well-Known Member
    Scott
    Portland, Or
    08 Long Bed TRD Sport
    295/70/17 Cooper STT Pro, Revtek 3" lift. TSB rear and Blistein 5100's http://www.cardomain.com/ride/3097063
    Yes, I treat it like a Manual Trans. It's warrantied for 7 more years!:D When the First Auto Trans go, I am swapping in a Manual 6spd.
    I leave it in "4" all the time, never use "D" unless I am traveling on the Freeway, often use "3" as well.
  9. Dec 22, 2008 at 3:10 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    The only time I downshift - is when I'm approaching a downhill grade. I don't downshift for normal braking.
  10. Dec 22, 2008 at 5:00 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    I'm always in 4 when driving in the city and sometimes downshift when slowing down. I like the way the trans. will downshift itself on certain grades of hills when you press the brakes.
  11. Dec 22, 2008 at 5:45 AM
    TheMaster
    TheMaster Born to Ride
    Chicky Baby
    NY
    2007 DC TRD Sport
    Bug shield, window visors, skid plate, rust proofing, tonneau cover, paint & upholstery protection, side step bars, navigation system.
    Yes, almost every time except when I'm driving it like a little school girl. :eek:
  12. Dec 22, 2008 at 5:54 AM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    does this mean you put on a plaid skirt and giggle and txt msg and weave in and out of traffic and generally piss all the other drivers around you off? :D
  13. Dec 22, 2008 at 6:09 AM
    harshest
    harshest I am the Sofa King
    Michigan
    05 PreRunner SR5
    Fog Light On, Hidden Garage Door Opener, Scanguage II, Weathertech Liners, Cig lighter always on, Door buzzer removed from dash- Upcoming: 5100s for front and rear, set fronts to 2.5" and Toytec AALs.
    I don't down shift that much but when I am doing a lot of city driving I will usually run in "4" instead of "D" to keep it from shifting all the time.
  14. Dec 22, 2008 at 8:29 AM
    TheMaster
    Chicky Baby
    NY
    2007 DC TRD Sport
    Yeah, everything except the plaid skirt because I will never shave my legs. :amen:
  15. Dec 22, 2008 at 8:40 AM
    camsbored
    camsbored Well-Known Member
    Raleigh, NC
    08 PreRunner DC/Sport/LB
    Kenwood DNX8120, Homelink mirror, Valentine One hardwire
    I downshift when I see a cop and don't want to hit the brakes. :) It's probably not that effective, but it makes me feel better.
  16. Dec 22, 2008 at 7:48 PM
    4x4x4trd
    4x4x4trd My other ride weighs 200 tons
    North Texas
    08 White Access Cab TRD OR, Debadged
    AFE oil free drop in, Secondary removed, tint, front D-rings, Toyota bed mat, Undercover tonneau, TRD seat covers and floor mats, Pioneer speakers, Westin Platinum bars, Fumoto oil valve, short antena, Nifty Xtreme's, TSB leaf springs, Bilstein 5100's set at .85" in the front
    Just depends on grade and flow of traffic? I do downshift quite often when stopping while pulling the trailer.
  17. Dec 22, 2008 at 9:03 PM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    I only do it when towing my boat.
  18. Dec 22, 2008 at 10:46 PM
    P. Bauer
    P. Bauer Well-Known Member
    San Jose
    08 Tacoma 4x4 TRD Off-Road
    TRD S/C :: Intake Camburg SwayAway Magnaflow American Racing Donahoe Racing Wheelers OffRoad
    Brakes are cheaper than a transmission/torque converter/rear diff/u-joints.
    On a manual transmission, you can downshift while braking and have the ability to heel/toe (blip throttle between shifts). This allows the engine and trans. to stay at the same speed.
    Less wear and tear is always a good thing.
    =D
  19. Dec 23, 2008 at 4:15 AM
    davatk
    davatk Well-Known Member
    Northwestern Virginia
    2009 DC TRD Sport Long Bed
    Tube Steps, Hood Deflector, ScanGauage, GPS
    Hmm. No, but I find that mine often downshifts on its own, usually when going down and incline and a curve at the same time. Seems to be doing it more since the weather turned colder.
  20. Dec 24, 2008 at 9:34 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    I do it all the time. Engine never gets above 2500RPMs. I use it in stop and go traffic when I don't want to tap the brakes all the time, cause people tapping brakes really pisses me off.
