Do you drive in 'D" or "4" around town?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jimsc, Apr 4, 2011.
  1. Apr 4, 2011 at 4:43 PM
    Jimsc
    Jimsc [OP] Well-Known Member
    Jim
    Greenville, SC
    10 PreRunner Double Cab
    Aries Nerf Bars, Cargo Seperator
    I know the manuel says "D" but I notice that at 35-40 the engine rpm's are only about 1,200. That almost seems like your bogging the engine? Seems to me 1,800 is a better when in "4". Any thoughts on this?
  2. Apr 4, 2011 at 4:45 PM
    YFZ_TRD
    YFZ_TRD 4Runner Pilot
    Lee
    Beaverton, OR
    2014 4Runner SR5
    Mine has plenty of low end grunt to still accelerate without downshifting at 35-40. As long as the torque converter isn't locked (which it won't be at these low speeds), bogging the engine isn't a concern IMO.
    EDIT: To answer your question, I always run mine in D unless I'm towing for long distance on highway.
  3. Apr 4, 2011 at 4:47 PM
    Tacomanator
    Tacomanator Boiling denim and bangin whores
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    i use D on highway and 4 in town.
  4. Apr 4, 2011 at 4:47 PM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    D. 4 is for towing or intentionally draining your gas tank faster
  5. Apr 4, 2011 at 4:48 PM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    If your towing or hauling, otherwise keep it in D. You'll get worse gas mileage by keeping it revved higher.
  6. Apr 4, 2011 at 4:50 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    This ^^^^
    As long as your revs are below 2000 , your gas mileage will not change .
  7. Apr 4, 2011 at 4:50 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    there's actually a thread on here that shows 4 actually improves mpg when driving around town, but not ny much
  8. Apr 4, 2011 at 5:00 PM
    Pugga
    Massachusetts
    Tried it and had the opposite affect... I did it for 3 tanks consistantly and averaged worse mileage on my daily commute (commuting in and out of Boston).
  9. Apr 4, 2011 at 5:01 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    1 in front of busses,2 on sidewalks,3 in parking lots,4 in the swap meet....and its 5 not D on manuals dang you all, pfft.
  10. Apr 4, 2011 at 5:01 PM
    RedTaco2134
    RedTaco2134 Well-Known Member
    Scott
    Portland, Or
    08 Long Bed TRD Sport
    285/70/17 Goodyear BFG KM2's, Revtek 3" lift. TSB rear and Blistein 5100's http://www.cardomain.com/ride/3097063
    I use 4. Lower gearing than 5, especially for starts. Like said above, I am sure the gain in MPG if any is marginal. I use it because of the 33's, and 3", just my preference.
  11. Apr 4, 2011 at 5:04 PM
    JKD
    JKD Well-Known Member
    The engine isn't bogging. If the engine begins to see load, the transmission will downshift to an appropriate gear.
  12. Apr 4, 2011 at 5:05 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
  13. Apr 4, 2011 at 5:07 PM
    DTFtacoma
    DTFtacoma Dezert Toy Fabrication
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    I keep it on "L"
    Get all the bitches watchin!
  14. Apr 4, 2011 at 5:08 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    :rofl:
  15. Apr 4, 2011 at 5:10 PM
    supralight
    supralight Well-Known Member
    Dan
    Earth
    2013 4Runner limited
    Any of you saying that 4 is more economic than D around town, get a scangauge.
    I have one, and keep it on D no question.
  16. Apr 4, 2011 at 5:13 PM
    DTFtacoma
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    But in all seriousness don't try driving in low you engine, trans, and face WILL EXPLODE!
  17. Apr 4, 2011 at 5:17 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    I thought it was supposed to be in R for Revs?
  18. Apr 4, 2011 at 5:42 PM
    OZ-T
    Peter North
    British Columbia
    I wonder why they bother giving us all those other silly optional gears like L , 2nd , 3rd , and 4th
    Should just be P , R , N , D
  19. Apr 4, 2011 at 7:00 PM
    supralight
    Dan
    Earth
    Because it's there primary for security reason. If you no longer have brakes, you can engine brake the truck. I think it's even written in the manual.
  20. Apr 4, 2011 at 7:08 PM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2014 Barcelona Red TRD Off-Road PreRunner
    Clazzio seat covers, KB Voodoo Powder Coated Tailgate Cap, OEM running boards, ImMrYo Rear-View Mirror Lift Bracket, 35% Tinted windows, EGR window vents, color matched door handles and tail gate lift, WeatherTech FloorLiners, OEM bed mat, sound dampening on rear wall and rear doors, on anytime foglight mod
    Drive ...... the tranny will take care of itself.
