Do you guys rely on the maintenance light?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ibjames, Dec 12, 2012.
  1. Dec 13, 2012 at 6:07 AM
    #41
    Joe D
    Joe D .
    I'm with you bro. Clean cheap oil is better than dirty expense synthetic any day.
  2. Dec 13, 2012 at 9:35 AM
    #42
    ibjames
    ibjames [OP] Well-Known Member
    oh wow, I fully expected to get flamed.. I like some of the ideas using 5k increments.. on previous car I did full synthetic every 5k miles.. a little wasteful, but I always knew my car had good oil in it
  3. Dec 13, 2012 at 12:00 PM
    #43
    CVAC085
    CVAC085 Well-Known Member
    Long Island, NY
    '12 TRD 4x4 Off-Road DC
    Window Tints, BakFlip Bed Cover
    Depends on who you speak to about it. My mechanic said every 3,000-5,000 miles is fine. When I had my Rav 4 once she hit 100,000 miles I did all my own oil changes and used high mileage oil. Worked out fine for me. Only suggestion is not to let it go over 5,000. Even if you have to change it a little sooner. Better off safe than sorry!
  4. Dec 13, 2012 at 12:36 PM
    #44
    DR Da_da
    DR Da_da Infrequent Member
    Northeast FL
    '06 4x4 V6 TRD Offroad auto access cab
    ToyTec ultimate lift, LR UCAs, TRD gen 1 CAI, TRD cat-back, bull bar, anytime fog lights, lighted 4x4 switch, factory SS step tubes, factory interior lighting package, factory VIP 3200 alarm, FJ TRD center caps, rear diff breather relocate, tint, bug deflector, Weather Tech liners
  5. Dec 13, 2012 at 1:18 PM
    #45
    07 sport 4x4
    07 sport 4x4 Well-Known Member
    Blake
    Southeast
    07 Sport DCSB
    I change my oil every 2500-3000 miles, but I drive a gravel road daily and take frequent shorts trips that are often less than a mile. (Mobil 1 and an OEM filter)
  6. Dec 13, 2012 at 1:24 PM
    #46
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    And here is a paragraph out of that:
    While the car-servicing industry is clear about its reasons for believing in the 3,000-mile oil change, customers cling to it only because they're largely unaware of advances in automotive technology. Among 2010 models, the average recommended oil change interval, based on a normal service schedule, is about 7,800 miles — more than double the traditional 3,000-mile interval. The longest oil change interval is 20,000 miles, for all Porsches. The shortest oil change interval is 5,000 miles in some late-model Toyotas, but the carmaker has begun shifting its fleet to 10,000-mile oil change intervals using synthetic oil.
    Our Tacomas would be those 5k vehicles...
  7. Dec 13, 2012 at 1:40 PM
    #47
    friction
    friction Well-Known Member
    Charleston, SC
    '08 4X4 RC SR5
    meh. I go 10,xxx with Mobil 1.
  8. Dec 14, 2012 at 5:32 AM
    #48
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    I am running full syn and will not go over 5K. Even though most of the Toyota fleet has gone to 10K intervals, the Tacoma did not for some reason? I am going with Toyota's reasoning here...;)
  9. Dec 14, 2012 at 6:40 AM
    #49
    Gearheadesw
    Gearheadesw Well-Known Member
    Davenport Fl
    2016 GMC 2500hd
    some
    Trip B as stated by others
  10. Dec 14, 2012 at 8:56 AM
    #50
    MrsPib
    MrsPib Well-Known Member
    Angie
    Texas
    '09 SWB 4.0 6-speed semi-debadged
    clear DTRLs, AMO Buckshots, factory upgrades, lifted
    I would also like to point out that if you do any sort of nasty off-roading (mud, sand, beach), you should stick to more frequent oil changes (preferably, right after said-event). Our intakes suck up a lot of shit due to their placement, and while I'd like to think nothing is getting in the engine, avid off-roaders have seized their 2nd gens with only 50k-miles on them 0.0
    For folks who are running a quality SYN to it's max of 15,000-miles, I would recommend changing the filter every 3,000-5,000-miles. It helps keep particulates out of the oil. Mileage recommendations are usually based on how quickly the oil will break down, not how quickly it may get dangerously dirty.
  11. Dec 14, 2012 at 9:07 AM
    #51
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    I've never gone by the light. In the 5 1/2 years since getting the truck with the number of miles on it now the light would have come on 3 times... but i've changed the oil 15 times (truck has 19,800 miles right now.)
