Do you have a front spacer/rear block lift?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jwmac, Dec 5, 2017.
  1. Dec 5, 2017 at 8:58 AM
    1cleanFG
    1cleanFG DialsGarage
    DialsGarage
    PNW
    2023 Sport 4x4 DCLB
    Toytec Alumaseries Coilovers OME El111R Camburg UCAs Scs sr8 17” 285/70/17 KO2
    Hahaha <3 yessss
  2. Dec 5, 2017 at 9:02 AM
    jwmac
    jwmac [OP] Well-Known Member
    Does that kit come with a Fox Flat brim hat brah?
  3. Dec 5, 2017 at 10:20 AM
    68injunhed
    68injunhed Well-Known Member
    Jeff
    SE Kansas
    2018 SCrew F150
    A couple things
    I have a 1" above coil spacer in the front, gave me almost exactly 2". I put a cast iron 1" block from Wheeler's in the back. No issues whatsoever. Passenger side is a quarter inch higher than driver, but front and rear are within a quarter inch of level both sides.
    Got the truck up off the 265/70-17s nicely.
  4. Dec 5, 2017 at 10:41 AM
    0331
    0331 Well-Known Member
    Seattle
    16' DCSB TRD OR 6MT
    I used to... had a revtek 3 inch puck and a block in the rear... took it out cuz it rode pretty rough. Everyone’s opinion may differ I just liked the stock ride quality too much to justify losing that, now just saving for bp51s
    t0nyvalenzuela likes this.
  5. Dec 5, 2017 at 10:53 AM
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    I’ve got a cheap ass spacer lift in the front! On a 25,000 dollar truck. Zero embarrassment here. To be honest, the ratio of money in the lift vs how much the truck cost is about as relevant as Donald trumps to Elvis Presleys... and if I felt the need to flex my fab nuts and coilover dick size id point to my 01. I’ve got the toytec 1/2 spacers, got me 1” lift in the front. Did not fuck with my ride quality, did not fuck with my suspension or driveline geometry in any detrimental way. In other words, this “lift” didn’t ruin what engineers spent a lot of time working out and didn’t put a lot of components under questionable warranty...on my 25,000 new truck.
    SteelerJim, Victory, LRAYS and 4 others like this.
  6. Dec 5, 2017 at 10:55 AM
    James_Bond
    James_Bond Well-Known Member
    Southern California
    '16 TRD Sport DCLB
    All stock
    I think people are complaining on 3" hockey pucks...
    stun gun[QUOTED] likes this.
  7. Dec 5, 2017 at 10:55 AM
    stun gun
    Aaronski
    Tacomas.
    Yeah but still
  8. Dec 5, 2017 at 11:01 AM
    James_Bond
    Southern California
    '16 TRD Sport DCLB
    All stock
    and I agree with your first post. stock shocks are not bad. if you just want a quick and easy 1" lift. and don't plan to off road it more than 10% of the time, its a good option. I had 1" spacers once (4Runner) and after the shocks gave out, I replaced them with 5100s. Not to brag, but the 5100 increased the ride quality significantly. That is why so many people bag on the stock suspension, they both cost the same (within $100) new.
    I'm ridding out my shocks and plan to get 5100s and lift the front a notch.
  9. Dec 5, 2017 at 11:07 AM
    jwmac
    Yeah, I think I will avoid this. What I didn't realize is the revtek 3" kits are a split spacer design using an in coil spacer and a top spacer. In coil spacers definitely stiffin up the ride. I thought that the newer trucks maybe had different geometry allowing for a larger above coil spacer without issues the 1st gens had with over extension/ball joint issues/ball joint to coil contact/etc.
    I will avoid a 3" spacer lift do to the stiffer ride.
  10. Dec 5, 2017 at 11:09 AM
    jwmac
    Thanks for the post. i think this is the way I will go, just a small above coil spacer to level out the truck and maintain factory ride quality.
  11. Dec 5, 2017 at 11:12 AM
    stun gun
    Aaronski
    Tacomas.
    I like the stock suspension, that’s the first time I’ve ever said that about stock suspension...and I’m on the trails every other day. When they go, I’ll install something adjustable. 3” hockey pucks will destroy things if actually used off road, I just figure I’ll put that out there.
    James_Bond[QUOTED] likes this.
  12. Dec 5, 2017 at 12:12 PM
    mikestaco17
    mikestaco17 Well-Known Member
    MIKE
    BAD ASS UTILITY CAB
  13. Dec 5, 2017 at 12:33 PM
    Midknight
    Midknight Well-Known Member
    Western Canada
    2018 TRD Off-Road
    For how much it costs I would hope so :p
    stun gun likes this.
  14. Dec 5, 2017 at 1:28 PM
    HeadStrong Off-Road
    HeadStrong Off-Road Well-Known Member Vendor
    2011 Toyota Tacoma and 2019 4Runner
    Welcome to TW @jwmac If there is anything that we can assist you with please feel free to PM us :cheers:
    Thank you so much @Unchained 5150 :D:D:D
    eccracer104 likes this.
  15. Dec 8, 2017 at 5:59 AM
    #35
    rdjr17
    rdjr17 Well-Known Member
    Ron
    Nepa
    2019 voodoo blue Trd pro
    Got a quote on 5100's , and 1 inch block (rear) for $600 installed with alignment. Is that a good price?
    stealthmode, 1cleanFG and geekhouse23 like this.
  16. Dec 8, 2017 at 6:02 AM
    #36
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    When I initially got my kit installed, it was $500 including alignment. My thought; good price.
  17. Dec 8, 2017 at 6:14 AM
    #37
    mercerc
    mercerc Well-Known Member
    Carl
    Palmyra NY
    2017 4x4 Sport long bed
    6112 shocks and dakar springs 2.5 in lift
    I am a proud owner of front spacer rear block lift.
    I had them put on my (at the time) 80,000 DCLB. Soon after, I noticed that my needle bearing went bad.... I had the needle bearing replaced at the dealership (under extended warranty). mine is 2.5 front and 1.5 rear. I was not happy with the loss of rake and added Firestone RideRite airbags in the rear. that got me back to 2.5/2.5.
    Other than the needle bearing issue I have had not problems. I had vibrations but they were due to the tire/rim combo and fixed with a road force balance.
    if you are doing a lift/tires/rims you might want to do them in pieces so that you can troubleshoot vibrations... do the lift and alignment and drive it for a week. if you have any vibrations or issues you know it is the lift. Once you are happy, add the tires/rims and deal with that. Just a thought.
    Carl
    stealthmode likes this.
  18. Dec 8, 2017 at 6:23 AM
    #38
    1cleanFG
    DialsGarage
    PNW
    2023 Sport 4x4 DCLB
    Is that all 4 shocks? Yes good price
  19. Dec 8, 2017 at 6:36 AM
    #39
    rdjr17
    Ron
    Nepa
    I only want to go 2 inch up front at most , but want to keep rack because I tow a boat so that's why h9
    4 shocks , alignment, rear block installed .. deciding how much to go up front between 1.5 -2 inch im gonna go with duratracs or art pros 265/70/17
  20. Dec 8, 2017 at 6:40 AM
    #40
    Johnders
    Johnders Spacer Lift Survivor
    2010 Black Access Cab Tacoma Base
    2" Lift , 265/75R16 tires, K& N filter, MBRP Exhaust
    I have a spacer lift/block and have no issues with it. I don’t go off road much and if I do I’m just a bit careful about it as I know my lift isn’t very functional for any real off road capability, but I enjoy the look over stock and 98% of the time I’m going down the highway to work and back. Is the ride a little stiff sure. But it gets the job done.
    This may not make me popular but if there is one thing I notice about the Tacoma community is that there is a very strong opinion that unless you have a 2000$ + lift you’re not a real man or something. Not everyone has the budget and a lot of people don’t have any need for a fancy coilover suspension with reservoirs and all that. Maybe I’m just jealous because I could never responsibly afford something that nice and justify it. We get it, spacer lifts are not ideal and yeah they probably don’t ride that great.. For an average user who just wants a little lift and some meaty tires that’s all you will ever need. If you want a Cadillac ride then don’t buy a truck.. Don’t get me wrong I admire the people who are passionate about their trucks and invest in nice things and enjoy off-roading, more power to you, your trucks are a work of art and I enjoy reading about them and can appreciate it, I am not hating on people with nice things and who want the very best for there truck and love to off-road.. But sometimes it’s like listening to a bunch of snobs on this forum looking down on people who don’t have an expensive lift. Many people who honestly don’t have any need for one... I guess if I had a real nice lift id want to brag about how great it is to. I know there are some better options for not much more $ without going all out, but still spacer lifts are not the devil everyone makes them out to be you just have to know that its a cheap way to lift and doesn't offer any real extra capability off-road and will ride a bit stiff (like a truck should imo). Sorry for the rant..
