do you have a whistle sound coming from 3.4 v6 engine during acceleration?
Discussion in '1st Gen. Tacomas (1995-2004)' started by keakar, Aug 10, 2015.
  1. Aug 15, 2015 at 1:21 AM
    #41
    Soul Surfer
    Soul Surfer Jimi Was Last Seen: Roam in’ Around…
    Jimi
    West Central Florida Coast
    ‘25 TRD OR/W-UpGrade Package.
    I know that bug deflectors can create a whistle sound and sometimes it comes from the wiper blades. But in this case it's only under load. I would think vacuum leak.
  2. Aug 15, 2015 at 9:22 AM
    #42
    kigmob
    kigmob Well-Known Member
    James
    New Orleans
    97 TRD S/C 4x4 V6 5spd
    ICON/TC TRD Supercharger URD 2.2 and 7th
    I would thoroughly check the air box for small cracks. Also look closely around where it goes into the wheel well. Might be leaking there. I have seen quite a few 3.4 air boxes develop cracks on the backside where the MAF meets the box due to the engine moving and the box being mounted to the body.
  3. Aug 15, 2015 at 9:27 AM
    #43
    keakar
    keakar [OP] Well-Known Member
    karl
    louisiana
    thanks guys, it sucks because I cant do much testing sitting still so short of removing hood and riding on top the engine, its hard to track the exact location of the noise but it is under the hood somewhere
  4. Aug 15, 2015 at 10:02 AM
    #44
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Does it make it when you put truck in gear holding brake and gas at same time to put a load on engine.
  5. Aug 15, 2015 at 11:21 AM
    #45
    keakar
    karl
    louisiana
    yes I went try it and I hear it but not as loud as when Im driving but the rear wheels keep slipping and foot on the brakes don't hold them in the grass.
    if I do it on concrete with the parking brake on, I think it wont slip then but im not sure if I want to trust the parking brake to hold the truck enough to be able do this while i climb around and under the truck trying to find the noise, but it seams like a very very risky thing to do
    TacomaJunkie8691 likes this.
  6. Aug 15, 2015 at 12:02 PM
    #46
    devinzz1
    devin
    2023 aclb trd or mt
    Dont have any buddys that can help?
  7. Aug 15, 2015 at 12:06 PM
    #47
    keakar
    karl
    louisiana
    not very willing buddys, they are a lazy bunch of SOBs lol
    I will have to hook it to a tree or something to do this but at least now, thanks to your good idea, I can recreate the noise (even though not as loud) without having to be driving it, so I can follow the whistle to the source.
    I don't but, the best would be if I had access to a dino machine so I could safely replicate and trace the noise without fear of being run over and dying in the process lol.
  8. Aug 18, 2015 at 7:19 AM
    #48
    alshead
    alshead Member
    Mine was the u-joint.
  9. Nov 20, 2015 at 9:32 AM
    #49
    baggedcrewcoma
    baggedcrewcoma Well-Known Member
    bakersfield
    02 dc sc 5 lug
    (Didn't read every comment on this thread)
    Just went through something like this it was the intake manifold where the two peases come together the bolts were a little lose.
  10. Nov 20, 2015 at 10:12 AM
    #50
    keakar
    karl
    louisiana
    thanks, even if that's not it, its worth checking out knowing they "can" come loose
  11. Nov 20, 2015 at 2:31 PM
    #51
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Mine does not whistle
    Then maybe my hearing is so bad I can`t hear it
  12. May 3, 2017 at 9:07 AM
    #52
    bssquared82
    bssquared82 b-squared82
    I'm hearing that same noise in my 16 taco
  13. May 3, 2017 at 9:14 AM
    #53
    keakar
    karl
    louisiana
    I heard it when I first got it but now I don't notice it anymore, im sure its still there and I just got used to it.
    its not very loud at all and you have to have the radio off and listen for it to hear it, in the end I guess its just part of the design of the intake system that has that little sucking air whistle noise
  14. May 3, 2017 at 9:55 AM
    #54
    Glamisman
    Glamisman Well-Known Member
    My whistle was loose upper to lower intake bolts causing the metal gasket to vibrate. Get a can of carb spray and spray it around the intake to isolate. There is a large vacuum line set that is on the back of the block. It has a "Y" in it.
    Some unsolicited advice from me... take the upper intake off to gain easlier access to the back of the block and check EVERYTHING that is back there. If the heater coolant hoses are older replace them while it is easy same for the small ones that go to the warmup block under the throttle body.
  15. May 3, 2017 at 8:48 PM
    #55
    Yota31
    Yota31 Well-Known Member
    Shannon
    Lifted 2006 Trd Sport Tacoma
    Led Tailights, OEM roofrack, 3 inch lift, Halo light bar and Black Wheels
    Mine whistles also but it starting doing it when I put a k&n air filter in it. Only whistles when accelerating and under load
  16. May 3, 2017 at 9:00 PM
    #56
    charliegt35r
    charliegt35r MALL CRAWLERs
    CenCal
    2003 tacoma dc
    OME 2.5 LIFT 285/75/16
    2 years later still whistling? Or more of a whining?
  17. May 3, 2017 at 9:32 PM
    #57
    DailyDriverFresno99
    DailyDriverFresno99 Active Member
    99 SR5 V6 4WD
    2.5" OME lift. Sweet Decals. Dashboard Hula Girl.
    I had a similar issue throw a code in my ol' Dodge. I searched high and low for intake/vacuum leaks. even took half the engine apart and replace the intake/exhaust manifold gasket on that thing, just to put it back together and hear the same noise directly correlated to how hard i pushed on the accelerator. my loyal car fixin' buddy was out of ideas...says to me, "we had better call my dad on this one..."
    (checks his watch)
    "It's 3:30pm... which means he ain't sober. I'll call him in the morning then go fetch him and drive him up here."
    Sure enough, five minutes under the hood, and he berets me for keeping my truck in this condition, but also located a pinhole in a fuel line that was suckin' air and whistling every time i hit the gas hard enough.
    Different make and model truck... but same symptoms. I dunno... take a check under the hood for some crap fuel lines with a pinhole in em. Mine was under a cold box held on by 1 out of four screws that vibrated a hole in that fuel line.
    good luck.
  18. May 3, 2017 at 9:36 PM
    #58
    DailyDriverFresno99
    99 SR5 V6 4WD
    just noticed this thread started 2 years ago. meh. i still didn't see any advice to check a fuel line... might still help someone.
  19. May 4, 2017 at 7:48 PM
    #59
    02 quadcab
    02 quadcab Well-Known Member
  20. Aug 10, 2017 at 9:17 AM
    #60
    sig916
    sig916 Well-Known Member
    I notice mine is doing the same. Have u figure out the cause?
