Do you have DRLs, and have they damaged your headlights?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by iroc409, Nov 19, 2010.
Have your DRLs melted your headlights?
Poll closed Dec 19, 2010.
  1. I have factory DRLs and they have melted my lenses
    16 vote(s)
    12.8%
  2. I have factory DRLs and they have not melted my lenses
    58 vote(s)
    46.4%
  3. I just want to see poll results
    51 vote(s)
    40.8%
  1. Nov 19, 2010 at 7:50 AM
    iroc409
    iroc409 [OP] Well-Known Member
    Washington
    A red one
    So, I am curious. I don't think I've seen a count, but I've seen a lot of complaints about melted headlights from DRLs. I want to add DRLs to my truck, but am a little skeptical because of this.
    So, how many of you have DRLs installed for a meaningful amount of time, and how many have actually had problems?
    If there is a real issue here, then Toyota needs to fix it!
  2. Nov 19, 2010 at 7:55 AM
    Jester243
    Jester243 rabble rabble rabble
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    I have DTRL and have had no problems
  3. Nov 19, 2010 at 7:59 AM
    jivewalker
    jivewalker me gusta pechos firmes
    Jack MeHoff
    Chucktown
    2012 4RUNNER TE w/KDSS
    No problems at 4500 miles, but watching very closely.
  4. Nov 19, 2010 at 8:02 AM
    00taco
    00taco Well-Known Member
    Casey
    cali
    black 00 tacoma v6
    wheels, tires, sound system, hid headlights, 1st gen fog light mod, tinted tails hella 500s on custom light bar, dust light, led white guages/dash lights, color matched grille, exhuast, blacked bumper and accents....
    if you are worried just use led bulbs and then youll be fine
  5. Nov 19, 2010 at 8:05 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I've had my DTRL's for about 18 months now and everythings good so far. But then again I have ebay BHLM's with aftermarket yellow bulbs.
  6. Nov 19, 2010 at 8:06 AM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah he can go that route but he might also need a resistor as well in order for the blinkers to work right.:cool:
  7. Nov 19, 2010 at 8:24 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    My factory DRL's melted the turn signal lenses. Several others have also had this issue.
  8. Nov 19, 2010 at 8:28 AM
    cactuscorn
    cactuscorn Another FNG
    El Paso, TX
    2016 BBR TRD OR AT DCLB w/JBL
    OEM bedmat, Weather Tech mats, JDM ASTAR 800 lumen LED reverse bulbs, blue LED dome light and every cubbyhole filled with crap.
    not exactly true from what ive read on here. the lower heat of the hid doesnt seem to overcome the close proximity of bulb to lens in either hid or halogen. but what do i know? mines a month old.
  9. Nov 19, 2010 at 8:30 AM
    Hydrabyte
    Hydrabyte Well-Known Member
    Florida
    2012 Tacoma & 1987 4Runner (newest addition)
    My 09 has them by default, just had both headlights replaced under warranty due to melting and cracking.
    .02
  10. Nov 19, 2010 at 8:35 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    I just looked at mine, I have had this 09 since Aug of 08. My inside lense covering the lamp of the DRL has a "reflector" in the center of the lense, and just above the reflector it seems to be a "melted spot" on the lense. Is this what everyone is experiencing that has this issue?
  11. Nov 19, 2010 at 8:46 AM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    I haven't seen any melting issues in the 3 years I've had my truck.
  12. Nov 19, 2010 at 8:48 AM
    Hydrabyte
    Florida
  13. Nov 19, 2010 at 8:54 AM
    xsvtoyz
    xsvtoyz Well-Known Member
    AL
    Oklahoma
    03 Pre-Runner Inprogress
    HID (ACA)/ Web cams/ Header/Full Custom exhaust/ K&N FIPK II/SuperCharger
    I had regular drls and never a melting issue I have HID drl and no melting issues either
  14. Nov 19, 2010 at 8:55 AM
    00taco
    Casey
    cali
    black 00 tacoma v6
    an led bulb doesnt get hot. LED is not the same as an HID bulb. hid is a headlight type of bulb
  15. Nov 19, 2010 at 9:07 AM
    KPT
    09 Prerunner
    Sounds the same as mine.
  16. Nov 19, 2010 at 9:10 AM
    toku58
    toku58 Well-Known Member
    HAWAII
    4x4 Beast!
    6" Fabtech Stage II, 17x9" Centerline Eclipse rims, with 12.5x35x17" BFG KM2's. On board air system,Toyota skid plate, spidertrax wheel spacers, TRD CAI w/AFE ProDry filter (21-90045),Flowmaster Dual exhaust, GrillCraft grill w/custom emblem, Custom Shifter, BushWacker fender flares, Hood struts, Underhood lights, TW driveshaft, Wet Okole seat covers, Dashlight mod, Many other little things to make the truck complete!
    Mine are starting to show signs of melting.:mad:
  17. Nov 19, 2010 at 9:26 AM
    warpwr
    warpwr Junior Senior Member
    Vaughn
    S.F. Bay Area
    09 Sport Access Cab
    DRL mod with switch, rear spring TSB, trans TSB, tailgate mod, snug-top shell.
    I don't have factory DRL but I did the (amber turn signal) DRL mod about 4000 miles ago and I haven't seen any melting yet.
    This is not the headlights-on DRL like on my 2000 4Runner.
    I think we are only talking about the turn signal mod here.
    I tried several different LED bulbs and couldn't get them to work at all (in some cases) or they just were not bright enough for me. You would also need (2) big, hot resistors and figure out where to mount them so THEY didn't melt something.
    The factory bulb is a dual filament bulb and both filaments light up when the DRL is on. I don't know if the factory DRL uses the bulb in single and/or dual filament combinations, like one for DRL and both for turn? That would require another wire from somewhere and was not part of the mod at least.
    I haven't tried yet, but I think you could possibly get a single filament bulb to work.
  18. Nov 19, 2010 at 10:16 AM
    jrobson
    jrobson Well-Known Member
    Mobile, Alabama
    09 DC 4x4
    Ultimate lift kit, LR UCA's, Bi-xenon 8000K headlights, Xenon 8000K foglites, (4) KC slimlites on N-Fab light bar, Extang trifecta toneau cover
    Just had mine replaced last week from this. Covered under warrenty of course.
  19. Nov 19, 2010 at 1:25 PM
    iroc409
    Washington
    A red one
    Thanks for the information, everyone!
    I actually may have a solution to the problem... but I will have to do a write-up and do not have time at the moment. I will try and post it tonight.
  20. Nov 19, 2010 at 5:28 PM
    cactuscorn
    El Paso, TX
    is this where i say i blew it again? i meant hid, not led. thanx for settin me straight man. anywho...
    im no lectric gawd nor does my new taco have this problem but theres plenty of talk about this hid senario on here. youll have to dig through the stock bulb folks for the hid guys who are havin issues but theres enough in these 3 pages to show ya theres a valid concirn.
    oh, and yould be hard pressed to find any light source that doesnt generate heat. they all get hot, within a enclosed/sealed space specially, just a matter of how high the temp gets and its relationship to other parts. this seems to be the major malfunction with ours. those turn signals/dtrl bulbs are just too damn close to the lens. so it goes. do i smell a TSB rollin down the road? for now, plenty are gettin it covered under warranty.
    as for leds not gettin hot, ive got plenty of led bike lights and they do get warm but mostly if left on in a stagnet state. once ya get rollin they do stay very cool and way cooler than hid or any other type no matter if theres air flow or not.
