do you have to install new uca's if you install coilovers ?
Discussion in 'Suspension' started by Joeymgd78, Dec 13, 2011.
  1. Dec 13, 2011 at 7:54 AM
    Joeymgd78
    Joeymgd78 [OP] Well-Known Member
    Joey
    at the moment Afghanistan
    2008 Tacoma SR5 TRD Offroad 4.0 V6 Double Cab
    :confused:i want to buy the Walker Evans 2.5 Non-Reservoir Coilovers 0-3.5 inches. but 1st i want to know if install these do i have to install new uca's as well? somebody told me i do but it doesnt sound right to me. is it recommend to do so or do you really need to do it for the walker evans to work. i plan on setting the coilovers to 3 inches. he told me anything over 2.5 will require new uca. is that true? if it is true how hard are uca's to install do the require any uncommon tools to install? any help would be greatly apperciated. also i am new to this so please forgive my ignorance on this subject. also it is very important to me that i do the install myself. thank you for any help you can give
  2. Dec 13, 2011 at 7:57 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    you dont HAVE to have new ucas, but once you go over 2.5 inches its hard to get your allignment right so it is highly recommended.
    they arent that hard to install, i would do it in an hour probably. take tire off, smack the ball joint out of the uca, take the bolt out, place new uca in, place ball joint back in uca (or uniball, depends what you get, never done a uniball one) tighten bolts put tire back on and repeat.
  3. Dec 13, 2011 at 8:04 AM
    Joeymgd78
    Joey
    ok sounds easy enough! any suggestions on uca's (BRANDS)
  4. Dec 13, 2011 at 8:05 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    I wouldnt go with the Walker Evens stuff. They have had issues with alot of folks in the past. Consider FOx, King, or Icon.
  5. Dec 13, 2011 at 8:11 AM
    Joeymgd78
    Joey
    oh really? thanks for telling me that. everyone keeps telling me to order spindles since i have a prerunner but i think that might be to hard for me to install myself
  6. Dec 13, 2011 at 8:13 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Spindles arent that hard at all. You can install them in about 3 hours if you take time. maybe a little longer if you havent done it before. Its always best to have someone who has a little experinace to help you.
  7. Dec 13, 2011 at 8:16 AM
    97yota4wd
    Eric
    Mesa, AZ
    spindles are the way to go if your a prerunner. should be the only way IMO.
  8. Dec 13, 2011 at 8:17 AM
    Joeymgd78
    Joey
    im trying to find a place that sells them and that will send them to a apo address which is hard for some reason nobody sends to apo. also there isnt many places that have spindles im looking for the camburgs. if i do spindles do i need new shocks too?
  9. Dec 13, 2011 at 8:18 AM
    97yota4wd
    Eric
    Mesa, AZ
    you can get camburg and keep your stock shocks, upgrading them in the future is never a bad idea though.
    TW members also get 10% off through camburg!:)
  10. Dec 13, 2011 at 10:02 AM
    Joeymgd78
    Joey
    can you put a add a leaf on top of another add a leaf for a higher back or is that bad
  11. Dec 13, 2011 at 10:03 AM
    97yota4wd
    Eric
    Mesa, AZ
    bad, i would get a whole new leaf pack... but you could always do a.... yes im gonna say it.... a..... block:/
  12. Dec 15, 2011 at 4:11 PM
    beerye
    beerye Steel Curtain!!
    Brian
    Tucson, AZ
    02 TRD 4x4 5spd
    3" suspension lift 2009 Tacoma Alloys K&N Intake
    Hey, Im kinda jumping into this thread, but I am having a lift problem that I was wondering if anyone knew the cause of.
    I put the 2.5"-3" strut lift on my 02 and now it leans to the drivers side about 1.5" lower than the pass side.
    My first thought was the upper control arms, but I hate to replace it, and that not be the issue.
    Has anyone had this issue before?
    HELP!!!
  13. Dec 16, 2011 at 9:09 AM
    beerye
    Brian
    Tucson, AZ
    02 TRD 4x4 5spd
    Bump for some help!
  14. Dec 16, 2011 at 9:31 AM
    Large
    Large Red
    Beerye. You have the "taco lean" although I'm not sure if it applied to first gens, on 2nd gens we install a 1/4" spacer on top of the strut.
  15. Dec 16, 2011 at 9:34 AM
    beerye
    Brian
    Tucson, AZ
    02 TRD 4x4 5spd
    I thought about adding a spacer just on the driver side, but it is over an inch difference! I don't want to add a huge spacer, though if there is a underlying problem that needs to be taken care of. I have heard that the driver side spring is softer to help with the ride quality, but the struts from top to bottom are the same length.
