Do you hose down the Engine
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GeoTaco1, Feb 27, 2011.
  1. Feb 27, 2011 at 4:18 PM
    GeoTaco1
    GeoTaco1 [OP] Well-Known Member
    Geo
    11 Tacoma TRD Off Road
    NEW Toyo TIRES Bed Cage to hold 120 LBS of sand and fishing rod holder, window air deflectors, Bug Deflector, & finally Avid Light Bar and step rails....
    from the hood side after driving in sand? Is it safe? Should the engine be running or off?
    I noticed some electrical connectors are not completely sealed and the pins are exposed if you look from the back of the connector. I am afraid if water splashes the connector, adjacent pins will short out.
  2. Feb 27, 2011 at 4:21 PM
    S.B.
    S.B. Well-Known Member
    Sean
    Colorado Springs, CO
    08 Taco 4x4 TRD OffRoad Rugged Trail
    Fox 2.5, Built right UCAs, CBI Front bumper, NWTI Rear bumper, 35s
    I wash my engine while its off and with hose pressure, I wouldn't use a pressure washer.
    I thought all of the connectors were suposed to be sealed, especially in the engine bay.
  3. Feb 27, 2011 at 4:22 PM
    nick
    nick MURDERED_TACO
    Green mountain ,nc
    - 2003 trd
    off is fine and it wont hurt anything, jus dont get close to wires,sensors and relays, etc.
  4. Feb 27, 2011 at 4:22 PM
    rcbs204
    rcbs204 Well-Known Member Vendor
    Engine should be off, and don't use the full power of the pressure washer. I back off a few feet when i wash mine. if you have and exposed Air cleaner, aftermarket, cover it with a bag before you start. Drive it on the highway after that, and it will make all the water evaporate quickly.
  5. Feb 27, 2011 at 4:29 PM
    nick
    nick MURDERED_TACO
    Green mountain ,nc
    - 2003 trd
    rcbs204 how did you get my moms pic as you avitar?
  6. Feb 27, 2011 at 4:39 PM
    SOSHeloPilot
    SOSHeloPilot Well-Known Member
    U.S.A.
    2016 SR5, AC/LB, 4x2, V6, Auto, w/Tow, SiriusXM, Stock
    UnderCover SE, Bed Mat, Tint, Weather Techs & DashGoPro
    I have hosed off (and pressure washed) my various engines for years with no problems.
    FWIW, I do it every time I wash the vehicle and my engines have always been spotless. ... :D
    Oh, forgot, had to dry out the distributor cap on a 1965 GTO once ... that was my only problem ever.
    Just use some common sense "where" and "how fast" you shoot that water in the engine bay.
  7. Feb 27, 2011 at 5:58 PM
    crazyman
    crazyman Not bothered....
    Crystal Beach, FL
    '11 4x4 DC/SB TRD/OR V6 Auto, Magnetic Gray
    Does Plasti-Dip count as a mod ?
    I use the Simple Green , let it set for 10 min or so, then run the hose over.
    Ill. Use a rag to scrub mud off.
    I do cover the exposed electrical connections, especially the area on the firewall on the driver side.
  8. Feb 27, 2011 at 5:59 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    X2
  9. Feb 28, 2011 at 2:59 AM
    maxamillion2345
    maxamillion2345 Leaves the bay but brings all its problems
    Max
    Nevada
    80 series LC
    Tons and 40s
    I wash down the whole engine and bay every time I hit the car wash.
  10. Feb 28, 2011 at 3:17 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Debadged, GC Mesh Grill, Yellow Fogs, Color Matched Headlights w/ Retros, Diff Breather Mod; mickey thompson classic IIs, 5100s, toytec springs, Dakar Leaf pack, ss brake lines, Lots more...just check the build page.
    Yep, I spray mine w/ a degreaser, let it dwell for a few minutes, then hit it w/ a soft bristled brush before rinsing w/ water. Turn the truck on for a few minutes to help dry things out, then spray w/ CD2 engine detailer.
  11. Feb 28, 2011 at 3:52 AM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2014 Barcelona Red TRD Off-Road PreRunner
    Clazzio seat covers, KB Voodoo Powder Coated Tailgate Cap, OEM running boards, ImMrYo Rear-View Mirror Lift Bracket, 35% Tinted windows, EGR window vents, color matched door handles and tail gate lift, WeatherTech FloorLiners, OEM bed mat, sound dampening on rear wall and rear doors, on anytime foglight mod
    We all have you mom's picture ..... :cool:.
  12. Feb 28, 2011 at 6:18 AM
    GeoTaco1
    Geo
    Thats the area I see exposed pins inside the connectors. Maybe I will use some type of electrical tape that cantake the heat? or do they have something better?
    I can't believe Toyota is not using better pin insulating connectors?!?
  13. Feb 28, 2011 at 1:33 PM
    nick
    nick MURDERED_TACO
    Green mountain ,nc
    - 2003 trd
    :eek:...........:gossip:?...
  14. Feb 28, 2011 at 2:03 PM
    river rat 69
    river rat 69 Well-Known Member
    Jim
    Orlando, Fla., Green side of the grass
    007, trd, sr5, fmf.
    NO Chrome,3" NFab's steps,TRD skid,Wet okie's.011 grill, k&n,5100's,All this comes right off when the old lady says let's go get a NEW ONE!!!
    S.B. If you want to keep her long time no hose under hood!!! Not all connectors are sealed. My 99 taco 4x4 had connector brake downs at 9y o. Dealer serv. mag. told me no hose and no deep water he told me if you must clean it PAY FOR STEAM no hose..... Jim
  15. Feb 28, 2011 at 2:05 PM
    S.B.
    Sean
    Well, dam. I thought the connectors should be sealed. You know what they say about assuming. But I do like mud pits.:cool:
  16. Feb 28, 2011 at 2:07 PM
    river rat 69
    Jim
    007, trd, sr5, fmf.
    Steam only she will thank you for it in the long run!!!! I found out the hard way. River Rat
  17. Mar 1, 2011 at 1:25 AM
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    I use a pressure washer but never stick the nozzle down into the engine compartment. With a nice fan you don't run too much risk of pushing water into stuff or blowing out gaskets and its not a lot of water volume. Cleans all the dust off but doesn't power off paint etc.
