Do you keep front support brace between the headlights and grill with an AlllPro bump
Discussion in '2nd Gen. Tacomas (2005-2015)' started by damon, Mar 9, 2012.
  1. Mar 9, 2012 at 8:12 PM
    damon
    damon [OP] Active Member
    Damon
    Little Rock, AR.
    2010 Access Cab SR5
    Debaged,SockMonkey Decals,TSB,LifeHammer & Maglight console mount
    My front end was damaged, and I had the shop put on an AllPro plate bumper. The thing is when I got it back it just looked off. The headlight and grill tabs on the bottom were broken and the support brace that spans between the headlights and bottom grille assembly was gone. The whole front end was not secure. The shop told me that that center support had to be removed to allow for winch space. I had him put it back on but that brace is visible and is protruding in front of the bottom of the grille assembly and doesn't look like what I have seen on here. Can anyone confirm that I need that bar and is it likely I will need to replace grille and both headlights? My shop guy says he would ride it like it is, but I can,t trust him at this point. Thanks in advance, you guys have been a great source to get it right!
  2. Mar 12, 2012 at 9:45 PM
    CJB4LFE
    CJB4LFE All-Pro Off-Road
    Jesse
    So Cal
    02 Tacoma
    All-Pro 3-link, Currie axles, with Currie 9" centers, Detroit Front and ARB Rear.
    PM SENT
  3. Mar 13, 2012 at 9:41 AM
    damon
    Damon
    Little Rock, AR.
    2010 Access Cab SR5
    I want to thank Jessie and Kurtis for all your help! you guys were great in helping me confirm my fears that the shop had no idea what they were doing. Thanks to you guys and Tacoma World it seems I am better equipped to work on my truck that the professionals in my area, at least some.
  4. Mar 13, 2012 at 9:54 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    All-Pro's install instructions specify brace removal, but I left mine on anyway. I don't have a winch so I can't say about clearance. Yes it is exposed.
    As for the headlights and grille, if tabs are broken, they should be replaced. No need to go OEM.
