Do you need the cat converter heat shields?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dessertsand05, Sep 10, 2012.
  1. Sep 10, 2012 at 12:01 PM
    dessertsand05
    dessertsand05 [OP] Well-Known Member
    Boston
    05 Tacoma DC SR5 4x4
    Working on it
    Was driving when suddenly I heard a chank and something drop from my truck. Turns out I dropped a heat shield and the other one was loose. Both seemed tack welded on.
    Do I need these things?
    A few people told me just to take them off, but not sure if they help keep road salt of the exhaust system.
  2. Sep 10, 2012 at 12:05 PM
    OffroadToy
    OffroadToy kokanee smoker
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Those cats put out a hell of alot of heat and the shields are there for a reason. If it's a bottom one missing there's a good chance of starting a fire out wheeling...i'd get it replaced asap.
  3. Sep 10, 2012 at 12:28 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    You're talking about the cages that are around the downstream ones? I only have one of them..pretty sure I only ever had one, no marks to suggest otherwise.
  4. Sep 11, 2012 at 3:44 AM
    dessertsand05
    Boston
    Working on it
    Looked at a friends tacoma, guess the piece that fell off was the top one. Looks like $40 for a new one and a few bucks for a clamp. Not to bad, seems worth putting it back on.
  5. Sep 11, 2012 at 10:36 AM
    dessertsand05
    Boston
    Working on it
    Ended up ordering the upper part of the shield and clamp online for $50, seems like an easy DIY fix. Just decided to try and put it back on.
  6. Sep 11, 2012 at 10:41 AM
    Taco Dan
    Taco Dan Well-Known Member
    Dan
    Tuscaloosa, AL
    07 FJ Cruiser auto 4X4
    Snorkel, Cooper ST Maxx 255/80/17, diff breather relocate, Cobra ultra III cb radio set up Warrior Products front bumper
    just use tin foil
