do you need to run premium gas with super charger or not?
Discussion in '1st Gen. Tacomas (1995-2004)' started by keakar, Oct 23, 2015.
  1. Oct 25, 2015 at 2:48 PM
    #61
    keakar
    keakar [OP] Well-Known Member
    karl
    louisiana
    actually no, its the other way around. skinnier tires mean less tire surface contacting road which translates into less friction and resistance on the drivetrain to turn them, so it takes much less torque to turn the tires and to maintain constant speed going up inclines so its going to require less engine strain and therefore less fuel consumption.
    now if you are thinking of it only in terms of rpm vs speed then yes the rpms are higher for the same constant speed but with the reduced friction of the smaller tires you are "unloaded" so the ecm reduces the fuel injectors output since its not needed and you are not burning as much gas to maintain that speed. basically 90% of all your driving the engine will be in idle mode as far as the fuel consumption. this is why all the 5 lug trucks with the smaller tires average 2-3mpg better then the 6 lug trucks do with the exact same engines gearing and trannys, but you do lose out a little on the top end power with them.
    no, I was referring to a low mileage 100k mile salvage yard engine, pretty much whatever fits the best with the least modification needed and it has around 250 hp or more stock without and turbo or SC added. maybe a 4.7 out of 4runner or tundra.
    while neither option is cheap, im guessing something like that would cost about the same or maybe less then getting the complete SC package and what that would cost. this would be more attractive option since it would be less bothersome and could be used as-is stock and burn regular gas.
    and to be clear, im not going to do an engine swap or SC because both are far too far beyond my budget to even think about but its nice to plan for "what if"
  2. Oct 25, 2015 at 3:37 PM
    #62
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Nope.
    kigmob and Lucario Runner like this.
  3. Oct 25, 2015 at 3:40 PM
    #63
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    why take the unnecessary risk? just run the minimum of 91 octane.
  4. Oct 25, 2015 at 3:44 PM
    #64
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
  5. Oct 25, 2015 at 3:45 PM
    #65
    keakar
    karl
    louisiana
    the question was what do you "need" to run since often they will say they recommend you do things "just because" while you can do fine without it, in this case, that isn't true, and the 91 octane is a must to run a SC
  6. Oct 25, 2015 at 3:47 PM
    #66
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    U can use a lighter to see how much gas is in a container in the dark if u no have flashlight...... But I wouldn't recommend it
    Lucario Runner likes this.
  7. Oct 25, 2015 at 3:55 PM
    #67
    keakar
    karl
    louisiana
    using a lighter is just dumb, its better to drop a lit match in the can then watch it fall to see how full it is :bananadead:
    Justus[QUOTED] likes this.
  8. Oct 25, 2015 at 3:57 PM
    #68
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Does the 1st gen TRD unit come with an intercooler?
  9. Oct 25, 2015 at 3:58 PM
    #69
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    :rofl:
  10. Oct 25, 2015 at 4:14 PM
    #70
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    Rolling friction has a very small impact on overall load felt by the truck. The reason larger tires tend to get worse gas mileage is because they have a much greater rotational inertia: they require more torque to turn. This factor is heavily shadowed by what you mentioned about rpm's though. The highest gas mileage will always be experienced when you can cover a longer distance using the same rpm. The engine speed is proportional to gas consumption so we can see why if we increase distance per rpm we are increasing miles per gallon (distance divided by gas consumption). In general smaller tires are for more torque/ acceleration while larger tires are for more speed (which is proportional to mpg).
    A brand new engine vs a used one is barely a $2000 difference. 75% of the cost of a swap is going to be labor. A s/c is going to be around $1000 less than an engine of similar condition, on average, and can be installed in an afternoon by any Joe with a decent set of tools.
  11. Oct 25, 2015 at 6:16 PM
    #71
    kigmob
    kigmob Well-Known Member
    James
    New Orleans
    97 TRD S/C 4x4 V6 5spd
    ICON/TC TRD Supercharger URD 2.2 and 7th
    It does not. Would be nice if it did. I have seen a few people retrofit intercoolers to the 1st gen supercharger systems. There was actually just a 1st gen trd supercharger in the for sale section that was modified to run an intercooler.
  12. Oct 25, 2015 at 6:20 PM
    #72
    kigmob
    James
    New Orleans
    The only way to cool the boost is meth injection. The URD 7th injector slightly cools the boost since it injects the fuel directly into the SC. Not as effective at cooling as meth though.
  13. Oct 25, 2015 at 6:22 PM
    #73
    dmharvey79
    dmharvey79 Well-Known Member
    Dennis
    Northern Virginia
    Detonation is bad, m'kay.
    Willbeck likes this.
  14. Oct 25, 2015 at 6:22 PM
    #74
    Willbeck
    Willbeck Well-Known Member
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    Well obviously if i put the hammer down, i'll use more fuel. but if i don't drive like an asshole, i'll keep my in-town and cruising mpg's. The extra power will be nice offroad, and at higher elevations.
    That's the best part about forced induction, power on demand, without increased displacement.
  15. Oct 25, 2015 at 6:23 PM
    #75
    Willbeck
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    Nitrous works too.
  16. Oct 26, 2015 at 10:58 AM
    #76
    keakar
    karl
    louisiana
    well this just pretty much confirms my thoughts about SC in that its just about hp and doesn't give you any benefit in mpg or towing if its going to suck gas like crazy when actually used. I mean whats the point of having it if you aren't going to use it and I wouldn't want to use it if it ruins my mpg when the point of searching for a way to get more power is just to increase my mpg by having more power then I need to use.
  17. Oct 26, 2015 at 11:09 AM
    #77
    keakar
    karl
    louisiana
    its all about benefit vs cost and what your true intention to get from it is. im too old to be looing for more power just for the sake of having more power. im more about maxing out the most mpg I can get and if something I do in searching for that helps get more power, its a bonus
  18. Oct 26, 2015 at 3:37 PM
    #78
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Black helicopters ftw
    Torspd likes this.
  19. Oct 26, 2015 at 7:04 PM
    #79
    Willbeck
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    It won't ruin your MPG lol, there's some middle ground there. Why do you think all the OEM's are switching to smaller engines with turbo's? A supercharger is a similar way to the same end game.
  20. Oct 26, 2015 at 11:55 PM
    #80
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    Yeah clay is right on this one keakar.
    There is alot to this subject as to why a larger tire can cause bad mpg's. But in the case of downsizing tire diameter(from stock sizing), each time the diameter is downsized you will be turning more rpm to hold the same speed that used to be achieved with less rpm.
