Do you prefer dry heat or humid heat?
Discussion in 'Off-Topic Discussion' started by WPDAWG11, Jul 19, 2013.
  1. Jul 19, 2013 at 7:25 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    U safe from the snakes at least...unless you go into the shade..... sit on a log....
  2. Jul 19, 2013 at 7:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    LOL!! YEah, the snakes wait till dark to come out.
  3. Jul 19, 2013 at 7:26 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Not true...rattlers are out there man! Even during the day in the heat! I've seen plenty...
  4. Jul 19, 2013 at 7:28 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You dont see them in the sun. All of the ones Ive seen during the hot months, are out in the AM or late PM. This year, Ive run over 3, relocated 7, and killed 2 (had to, as I was too close).
  5. Jul 19, 2013 at 7:30 PM
    Tacoyota
    08 4wd
    In AZ, NM and here in Oregon , I rarely seen rattlers or other snakes out in the heat of the sun over 90 or so. That's a bit of a generalization, but they do go for the shade at some point. At that point the shady stuff gets me concerned.
    I prefer the dry air n the higher cooler alpine stuff to boot. To me Portland is muggy.
  6. Jul 19, 2013 at 7:31 PM
    ColtsTRD
    Scott
    AZ
    Well not directly in the sun but under a bush and such is what I meant. I went out to Bartlett last week and there was one chillin under a tree at 5pm...I just relocated as to not piss it off haha!
  7. Jul 19, 2013 at 7:40 PM
    Tacoyota
    08 4wd
    Its that time in a thread, it has to happen....
    Chris has a trained spider-eating snake....
  8. Jul 19, 2013 at 7:42 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I had pet snakes growing up....and just so happened to feed them spiders....until they got big....then....mice.
  9. Jul 19, 2013 at 7:44 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  10. Jul 19, 2013 at 7:45 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Is this hot?
  11. Jul 19, 2013 at 7:45 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  12. Jul 19, 2013 at 7:45 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    or this?
  13. Jul 19, 2013 at 7:46 PM
    Tacoyota
    08 4wd
    yea, get a reading on some asphalt, horrible place to work, sometimes I do line layout after they pave, glad I'm in Oregon for it, not AZ.
  14. Jul 19, 2013 at 7:47 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    x2
  15. Jul 19, 2013 at 7:51 PM
    #35
    WPDAWG11
    WPDAWG11 [OP] Well-Known Member
    Murfreesboro
    2005 4x4 5spd 4cyl
    Need suggestions
    I find that it is hot but more tolerable than humid heat chris IMO. I used to keep snakes as a kid too. I once fed a wolf spider with an egg sac on its back to a cotton mouth lol
  16. Jul 19, 2013 at 7:51 PM
    #36
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    LOL!!! We have to dump water on the asphalt after its laid down, in the summer, as it wont get cool enough to roll if we don't. IIRC, it shows up at around 325*, and it takes about 1 to 2 hours to get it to a workable temp.
  17. Jul 19, 2013 at 8:04 PM
    #37
    Az4x4
    Az4x4 Az4x4Taco
    George
    White Mountains, AZ
    '03 Tacoma TRD SR5 DC 4x4
    Deck Plate Mod, Grey Wire Mod, Vision Shell, Alpine Speakers and Amp, Sway-A-Way RaceRunner Nitrogen Shocks with Coilovers up Front, Deaver 8 Pack at the Rear with Bilsteins, All-Pro Rock Sliders, Cobra 29LTD CB, 800W Inverter, Constant 12v Power Outlet Mod, Open Door Warning Disabled, Garmin GPS..
    You working on some of the seal coating and new asphalt projects Tempe has going on right now Chris?
    Do my best to avoid driving through those area while work is in progress, but sometimes you find yourself in the middle of things before you know it. Hot, sticky work and a pain in the rear for everyone involved including drivers!
  18. Jul 19, 2013 at 8:05 PM
    #38
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Hell no. My asphault days are done (I hope)
  19. Jul 19, 2013 at 8:15 PM
    #39
    mhendrixcap
    mhendrixcap Active Member
    Stafford, VA
    13 DCSB 4WD TRD Sport V6
    dry heat is more tolerable. humid heat makes it hard to breath.
  20. Jul 19, 2013 at 8:16 PM
    #40
    ColtsTRD
    Scott
    AZ
    I cracked an egg on the asphalt once (cliche) and it literally started to turn white and cool immediately!
    It was 120 that day! This was a few years or more ago
