Do you put weight in back of your truck?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by harshest, Dec 19, 2008.
Do you put weight in the bed
  1. Yes
    40.4%
  2. No
    20.2%
  3. No need I have 4x4.
    39.4%
  1. Dec 20, 2008 at 6:54 AM
    #41
    007Tacoma
    007Tacoma I dub thee malicious!
    Mark
    San Antonio, TX
    2015 4Runner Trail Edition Premium
    Cloaking Device
    I put weight in the bed, but only when I am going to be dealing with snow/ice. I will have ~45lbs of tools and 150lbs of sand bags in my bed for the trip out to Kentucky.
  2. Dec 20, 2008 at 9:31 AM
    #42
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
    OK, so I bought 3 50# bags of rock salt today at Lowes. I wanted to verify placement in the bed. From what I understand, it needs to be above the axle. So in my short bed DC, they should *almost* be at the front of the bed, correct?
    I think the truck rides better with the weight back there. (maybe i'm crazy)
  3. Dec 20, 2008 at 11:47 AM
    #43
    stratton
    stratton Well-Known Member
    Yeah salt is a killer on cars and trucks here in ny. They use a crap load of it on the roads to the point that the roads are white once the melted snow evaporates.
  4. Dec 20, 2008 at 11:47 AM
    #44
    Delmarva
    Tucson, AZ
    12 Tundra TRDRW
    thanks for the heads up -- I've got a tonneau cover, so hopefully most moisture stays out. I plan on bagging the bags of salt for extra protection.
  5. Dec 20, 2008 at 11:48 AM
    #45
    stratton
    Oh and plus if you ever do get stuck on ice you can open the bags of salt or sand and use it for traction.
  6. Dec 20, 2008 at 11:49 AM
    #46
    Delmarva
    Tucson, AZ
    12 Tundra TRDRW
    ya that's what I was thinking... plus I was standing next to the salt at Lowes and the Sand was on the other side of the store... my laziness made the decision for me... lol
  7. Dec 20, 2008 at 3:23 PM
    #47
    Delmarva
    Tucson, AZ
    12 Tundra TRDRW
    thanks!
  8. Dec 20, 2008 at 4:34 PM
    #48
    shootermcgavinyo
    shootermcgavinyo Well-Known Member
    Rockford, IL
    '08 double cab 4x4 v6 trd off road
    I put 5 60# bags of tube sand in the back after the first snow here, it definitely made a difference.
  9. Dec 20, 2008 at 4:37 PM
    #49
    Bakemono
    Bakemono Wrath of the runbird
    Southern Wisconsin, USA
    '09 Toyota Tacoma regular cab 4x2
    I dont put weight in the back because I have a 4x4. If the roads and snowy/icy, I click it into 4x4 and Im good to go. If I had a 4x2 Id definetly be putting weight in the back though.
  10. Dec 20, 2008 at 4:52 PM
    #50
    211Mike
    211Mike Member
    Ontario, Canada
    I have 2 40 kg bags of salt sitting over the rear axle.
    I built a box today using pressure treated wood and used cargo straps to hold it in place. The box is nice because it keeps stuff that I put in there from sliding to the front of the trukck box.
    Even with 4x4 having the weight over the rear axle is nice and I have found it does make a difference.
  11. Dec 20, 2008 at 6:44 PM
    #51
    pittim
    pittim mittip
    Respect your elder gen.
    Pink slider.
    Nothing in the bed except snow. If the weather is bad I'll just put it in 4x4.
  12. Dec 22, 2008 at 10:38 AM
    #52
    Blue Hooligan
    Blue Hooligan Well-Known Member
    Winnipeg
    2007 PRERUNNER
    I knew I'd have issues in the winter without a 4 X 4 here in Manitoba, but it's not too bad.
    I tried driving after the first snow fall when the roads were pretty much pure ice. Not as bad as I thought, but there was one stop sign at the bottom of a hill where I took awhile to make it up. Good thing there's not many hills around here!
    I'm pretty cheap so I don't want to put too much weight in and compromise fuel economy, so I have about 100 lbs. over the rear axel right now. It should probably be more, but I'm getting around just fine. Just have to be careful out there, especially while starting from a stand-still when there's other vehicles coming towards me.
  13. Dec 22, 2008 at 11:38 AM
    #53
    sjt
    sjt New Member
    Ann Arbor, MI
    '08 standard cab, 4 X 4
    Seems to me you'd want the bags as far back in the bed as possible to have the greatest effect. I have 4 bags of tube sand and it seems to work better then none at all.
  14. Dec 22, 2008 at 12:06 PM
    #54
    007Tacoma
    Mark
    San Antonio, TX
    Cloaking Device
    That can be detrimental for two reasons:
    1) Since the weight is at the rear of the vehicle, you end up with a pendulum effect on the horizontal plane in a turn with the brakes applied on ice, gravel, oil, or any other wet or loose surface. It is the same feeling as if you were holding down the throttle through a turn and start doing donuts, but your wheels are still trying to slow down without traction. This can cause the rear end to violently swing around.
    2) You can have the same effect on the vertical plane, but it isn't necessarily exclusive to winter driving or low traction situations. If all the weight is in the rear of the bed, the frame begins to act as a spring board (think of a diving board). Every bump you hit causes a bouncing effect that isn't controlled by the suspension but rather by the frame itself.
    Any payload in a vehicle should have the weight distributed evenly over the axle(s) to maximize handling, ride stability, and control. The first thing you need for traction (even before weight in the bed) is a good set of tires that match the conditions that you will be driving your truck in.
  15. Dec 22, 2008 at 5:47 PM
    #55
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    After seeing this thread, I will definitely be throwing some sandbags in the bed when I make trips up to the mountains in the winter time.
  16. Dec 22, 2008 at 6:03 PM
    #56
    Tacoma02TRD
    Tacoma02TRD Well-Known Member
    Walla Walla WA/ Klamath Falls OR
    02 Tacoma TRD
    3inch Revtech lift,Flowmaster Muffler, K&N cold air intake, 33x12.5 Maxxis Bighorns, TRD stock locker, Hella 500 Fog lights, Scanguage II, 6k HIDs, Painted Black Rims
    I leave my truck in 4 wheel drive and play it smart, no sand or weight.
  17. Dec 23, 2008 at 8:47 AM
    #57
    sjt
    sjt New Member
    Ann Arbor, MI
    How does the truck distinguish a heavy weight in the bed and over the rear axle from a lighter weight further back that creates a similar moment?
  18. Dec 23, 2008 at 8:52 AM
    #58
    BioMed80
    BioMed80 Well-Known Member
    Colorado Springs, CO
    09 Regular Cab
    3" ReadyLift Kit, 31x10.5x15 General Grabber AT2s, AFE Drop-In, Bull Bar, Hella 500FF, Secondary Filter Removed
    4 bags @ 60lbs a piece. It helps, but there's no substitution for smart driving.
  19. Dec 23, 2008 at 9:11 AM
    #59
    lsocoee
    lsocoee My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    We don't have snow down here and rarely have any appreciable ice, but we get our share of rain. I started keeping about 8 concrete blocks in the bed and I like the way she drives now much better. I am much less likely to start hydroplaning in a heavy rain now.
  20. Dec 23, 2008 at 11:05 AM
    #60
    007Tacoma
    Mark
    San Antonio, TX
    Cloaking Device
    When driving straight forward on even ground, it does not make a big enough difference where the weight is placed. In many cases, as long as there is sufficient weight in the bed it will provide sufficient downward force on the tires to assist in traction.
    However, the two situations that I described are different from driving straight down a smooth road. Situation #1 can happen in a turn (horizontal change in direction). Situation #2 can happen when going down a bumpy road (vertical change in direction). In either case, if the weight is too far to rear, that weight "swings" (situation #1) or "bounces" (situation #2) causing unsafe driving conditions.
    The reason you put the weight over the axle instead of all the way forward: it distributes the weight evenly on the bed, the frame, and the suspension. This causes the downward force to be over the tires where the traction is needed.
