do you remove the skid plate to change oil?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mattvivsound, Dec 3, 2009.
  1. Dec 3, 2009 at 1:20 PM
    mattvivsound
    mattvivsound [OP] Well-Known Member
    Southern MD
    '01 Tacoma TRD, 4x4, V6
    On the 05+ do you have to remove your skid plates to change your Oil Filter?
    If not what do you have?
    I think every toyota I have owned I had to remove the front skid plate to get to the Oil Filter and I have owned: '88 22RE 4Runner, '94 3.0v6 4Runner, '98 2.7 Tacoma and '04 4.7v8 4Runner.
  2. Dec 3, 2009 at 1:21 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    The stock, non-TRD skid plate (The silver one that comes up front a bit) has an access hole. Not sure about the TRD ones, or any of the aftermarkets (BUD, ect).
  3. Dec 3, 2009 at 1:22 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    oil filter is on top of the engine, so no
  4. Dec 3, 2009 at 1:26 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    x2
  5. Dec 3, 2009 at 1:28 PM
    tacoman101
    tacoman101 Well-Known Member
    scott
    vermont
    2001 Tacoma sr5 xtra cab 4wd
    blue led headlights, 285/75/16 grabber AT2's, custom pedals, custom shifter, flowmaster 40 series muffler, bedlinered fender flares, 2.5" lift kit via shackles and spacers, custom exhaust out the back, chrome exhaust tip, and Herculined bed, Weathertech floormats, Cabelas Trail Gear Camo Seat Covers ... Nice thing was I got the truck for $4000
    no need to remove the skid, there should be a hole in it where the drain plug is
  6. Dec 3, 2009 at 1:29 PM
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2020 Pro
    In my first gen, you unsnap some clips in the driver-side wheel well and pull back some rubber flap to reach the filter.
    On my second gen, you access it on top of the engine. Greatest design I have ever seen! And the removable plug to drain the overflow basin around the filter is the 'cherry on top'. I added a fumoto drain valve and can change my oil without a single drop spilling on the driveway.
  7. Dec 3, 2009 at 1:34 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Like everyone else said, there is a hole to access the drain plug.
    I'm sure some other people do this too but I put a plastic SOLO cup underneath the little drain hole on the oil filter housing so that when I remove it I don't have to clean up any oil, then just wipe the remaining residue out of the housing with a paper towel.
  8. Dec 3, 2009 at 1:38 PM
    NWtacoma
    NWtacoma Well-Known Member
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
    the oil filter is on the top of the engine bro
  9. Dec 3, 2009 at 1:41 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    Lmao, wow I skimmed that one haha...
    Yea... on top...
  10. Dec 3, 2009 at 1:42 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
  11. Dec 3, 2009 at 1:47 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I attached a hose permanently to the drain hole under the filter and ran it down through a hole in the skid plate....works great!
  12. Dec 3, 2009 at 1:49 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    I like your Tacoma! Looks awesome and not overdone! I miss my '98.
  13. Dec 3, 2009 at 2:21 PM
    mattvivsound
    Southern MD
    With 4 responses like this... is that for the I4 or V6 or both?
  14. Dec 3, 2009 at 2:28 PM
    jonny
    jonny Betty White Edition Heep ZJ
    05+ v6
  15. Dec 3, 2009 at 2:29 PM
    rob1
    rob1 Well-Known Member
    Robert
    South Texas
    Indigo Blue DblCab 4X4 Long Bed TRD Sport SR5
    Tail gate mod, locking gas cap, locking spare tire, rear spring tsb,Weathertech Digital fit's
    V6 forture, don't know about 4 cyl??
  16. Dec 3, 2009 at 2:30 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    haha i was about to say my 05+ 4 cyl definetly doesnt have it on top
    for us its on the pass side of the block. you might even be able to get to it through the pass wheel well
  17. Dec 3, 2009 at 2:50 PM
    uood8
    uood8 If You Search...You Shall Find.
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    4 cyl is accessed from the bottom, no need to remove anything.
  18. Dec 3, 2009 at 3:55 PM
    spp
    spp OC, Kalifornia
    OC California
    The only other truck I had with a top mounted filter was back in 1974 with a Mazda Rotary Pickup.
    I just took a screwdriver and punched a hole in the top and oil would drain out before I removed it with no mess.;)
  19. Dec 3, 2009 at 4:09 PM
    06WHITETRD
    06WHITETRD Gotta Love my Taco!!!!
    So Cal
    06 Toyota Tacoma OFF-ROAD
    Tinted windows, window visors, XDI True Flow intake, White Devil Emblem, sport white grill, stubbie 6' antenna, TRD license plate frame,TRD Exhaust, weathertech floor front & rear, LED map/dome & license plate lights,Black Grille,T-Rex eyebrows,black Skid Plate,Lower bumper cover,Black emblems,white TRD Emblem,lamin-x yellow,Slotted & Cross Drilled rotors,Redline shocks(hood),HID 6k,more to come
    No, you dont..
  20. Dec 3, 2009 at 4:37 PM
    macgyver
    Brad
    Canton, GA
    Did that cause your apex seals to go out prematurely? lol...rotary joke
