Do you rotate in your spare?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ziggynagy, Sep 10, 2012.
  1. I rotate in my spare
    41 vote(s)
    10.0%
  2. I do not rotate in my spare, non-stock tires
    164 vote(s)
    39.8%
  3. I do not rotate in my spare, stock tires, full size spare
    195 vote(s)
    47.3%
  4. I do not rotate in my spare, stock tires, no full size spare
    12 vote(s)
    2.9%
  1. Sep 17, 2012 at 11:31 AM
    #81
    OutbackHack
    OutbackHack Well-Known Member
    Golden, CO
    2014 DCLB Heavy
    285 only tells us the tire width, diameter is the more important factor. This would be the middle number in your tire size:
    IE: 285/X/17 or 265/X/16 - find X.
  2. Sep 17, 2012 at 11:33 AM
    #82
    Wicked 2007
    Wicked 2007 Well-Known Member
    Bay Area, CA
    2007 Tacoma AT DC SB 4x4
    2007 Tacoma Double Cab SB 4WD - Auto -TRD Off Road - Icon Billet UCA - 8" ORI Front Struts - Bilstein 5100 11" RCD Shock - AllPro Expo Springs - Demello Sliders - Tom Woods 1 Piece Driveshaft - 16x8 Mojave Teflon Rims - Locker Mod - Locker Guard - 35" MT MTZ's - ARB Bumper - Warn 8000 winch w/synthetic line - All-Pro Front Skid/Transmission Skid/Rear Armor - ARB Front Locker - Nitro 4.56 gears - Marlin 4.7 crawl box - Twin Stick FJ t-case - ATO high clearance rear bumper
    i'm not disagreeing they want our money. i just don't believe there is a rotation conspiracy theory
  3. Sep 17, 2012 at 11:35 AM
    #83
    98tacoma27
    Ben
    Not Beech Creek
    You'd be fine to get from point A to B.
  4. Sep 17, 2012 at 11:41 AM
    #84
    Monkeyboy
    Monkeyboy Well-Known Member
    Grand Junction, CO
    2012 AC TRD Sport
    So, you don't have anything other than "this totally happened to me once!" ?
  5. Sep 17, 2012 at 12:35 PM
    #85
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Why can't the people in here comprehend a simple sentence?
    Do some research. I'm not stating a FACT. I said numerous times "it CAN happen".
    I also stated I know pro's and then supplied links for what they said, but I guess you missed that as well.?
    Do a search on here for more threads on this EXACT topic. Since OP didn't do a search you people are discussing the same topic that was discussed 100 other times on here. Maybe a little less BS and a little more research and you guys would understand I'm only trying to help you out. You want to do what you want then that's fine.
  6. Sep 17, 2012 at 1:47 PM
    #86
    ziggynagy
    ziggynagy [OP] All Glory To The Hypnotoad
    Stoughton, MA
    '11 Sport AC 4x4 V6 Auto Tow
    Westin step bars, led dome & map lights, tailgate hoseclamp, BluLogic, MetalMiller emblem, 35 tinted front windows, extra OEM d-rings, WeatherTech front/rear
    Agree with OutbackHack. If your spare is stock then it's 265/70R16, so the diameter is 781mm (265x70%x2+410). So if you solve in reverse (285xPx2+436=781) your current tires are the same diameter as your spare if they are 285/60R17. Even if it's not the exact same diameter, if it's close in size you should be able to get home but I wouldn't recommend driving too fast.
  7. Sep 17, 2012 at 2:40 PM
    #87
    SteveoATC
    SteveoATC Well-Known Member
    San Diego, CA
    2012 off road DC/SB
    OME 885 coils with Dakar leafs in back, 17" XD Addicts, 33" Hankook Dynapros, BAMF bolt on sliders with kickout
    Thanks! Of course this would only be an emergency only situation, but just wanted to make sure I could actually use the spare until I get my full size tire and rim to replace it.
  8. Sep 17, 2012 at 2:48 PM
    #88
    ziggynagy
    Stoughton, MA
    So what's your current tire size? 285/xxR17
    When you get your full size spare are you going to rotate all 5 or just do the 4?
  9. Sep 17, 2012 at 4:18 PM
    #89
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    :boink:
    :laughing:
  10. Sep 17, 2012 at 4:29 PM
    #90
    ziggynagy
    Stoughton, MA
    :cool:
  11. Sep 17, 2012 at 9:24 PM
    #91
    ziggynagy
    Stoughton, MA
    Interesting, didn't know the LSD would be sensitive enough to pick up such minor differences in tire circumference but it does kinda make sense as it would cause them to spin at a different rate.
    Owner's Manual recommendation is attached below with no mention of spare; had this in an earlier post but it somehow got lost in the fray.
  12. Sep 19, 2012 at 6:56 AM
    #92
    Larry
    Larry CARL
    CARL
    No.
    I rarely rotate tires.
    I prefer to rotate vehicles. :laugh:
  13. Sep 23, 2012 at 12:02 AM
    #93
    jackrules
    jackrules Well-Known Member
    Jack
    San Diego
    10 PreRunner Double Cab SR5 TRD Sport LB
    it would suck if you never inflated it and the one time you needed it it was flat... just say'n
  14. Sep 24, 2012 at 7:43 PM
    #94
    ziggynagy
    Stoughton, MA
    My spare is w/out TPMS so I check the tire pressure every couple months. Tire valve extender will be my next add...
  15. May 3, 2013 at 3:45 AM
    #95
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    At least once I have bought 3 matching tires and used it. I replaced the original spare with one of used tires. More often I have replaced spare to match tire size on truck. I did that once with 33s in the old style carrier. Fortunately I had a cable and lock on it. Every once in a while it would come out and scatter traffic behind me. Imagine a luxury car hitting a 33x12.5.
  16. May 3, 2013 at 5:31 AM
    #96
    On An Island
    On An Island Assimilated
    David
    Houston-ish
    '12 Black 4x4 DC LB TRD Sport
    Bilstein 5160 reservoir rear shocks, Bilstein 5100 height-adjustable front shocks, SuperSpring SSA19 leafs, Westin bull bar, KC Apollo Pro 6" spotlights, Leer 100XQ cap, K&N air filter, AntennaX 13" Euro antenna, tailgate washers, spare tire tool guide, Console Vault, FJ silver wheel caps
    This.
  17. May 3, 2013 at 6:38 AM
    #97
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    The LSD uses a clutch. It holds the axles together until its hold is broken by torque differences between wheels. IIRC, the torque is around 100 ft LBS. Running dissimilar tires provides plenty of torque, on dry pavement. The tires turn at different speeds.
    On an open diff, the spider gears would constantly turn. It wouldn't be a problem at slow speeds, but may cause a problem at higher speeds. The speed of rotation may be to great for the lube to cling and protect it. That's why you can easily grenade a diff when doing donuts.
  18. May 3, 2013 at 10:35 AM
    #98
    TNM JJ
    TNM JJ Active Member
    JJ
    Northern VA
    09 Dlb cab TRD Sport 4X4
    Nope. I do not rotate with the spare tire. If I did that I would have to take off the spare tire from the spare wheel (which is cheap-looking). If my spare wheel was the same as my alloy wheels, then yeah I would rotate with the spare tire.
    At about 40k miles I got a flat in the rear-right. They couldn't plug it so I needed a new tire. Ran on the full size spare for about a week until the matching tire came in (Dunlop Grantrek AT20 - Sport Taco's factory tire). So I had them take off the spare tire from the spare wheel and put it on the actual wheel on the rear left, and replace the new tire on the rear-right. The old AT20 went onto the spare wheel.
  19. May 3, 2013 at 10:41 AM
    #99
    stump jumper
    Bill
    Texas
    285 is some combination of radius and width. The overall daimeter = ((285*.70*2)/25.4)+16. Or 31.7".
  20. May 3, 2013 at 10:49 AM
    #100
    stump jumper
    Bill
    Texas
    If I have a flat on the rear and have to travel a long distance I will put the spare on the front. Might be more trouble but could save you diff. I do not have to worry about it for a while since I just bought a new one. I sure wish Toyota would but 265/75s on the Baja. O well I guess I just have to wait for the 70s to wear out. If the tires I my trade had not been have worn I would have swapped.
