Do you think im making a solid choice for this lift?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacohound, Dec 20, 2012.
  1. Dec 20, 2012 at 4:44 AM
    tacohound
    tacohound [OP] Well-Known Member
    Andy
    Cape Cod
    2011 DCSB TRD Sport
    Smitty built light bar, 4 Hella 550's, Tan HLM and badges, Black sport rims
    Hey everyone, Im going to be purchasing my full suspension lift soon and just would like some feedback to make sure Im not going to miss anything or mess my truck up. Here is the list of parts I will be ordering:
    1. OME 885 coils (w/top plate spacer)
    2. front bilstein 5100 (set to highest)
    3. toytec 2" AAL
    4. OME rear nitrocharger sport shocks
    5. solid steel axle degree shims
    6. U bolts with hardeware (8.5 in)
    7. OME 5mm trim packer
    8. front swaybar relocate kit
    If anyone has any constructive critisism I would like to hear it. I really dont want to mess this up. Thanks.
  2. Dec 20, 2012 at 4:52 AM
    Taco Dan
    Taco Dan Well-Known Member
    Dan
    Tuscaloosa, AL
    07 FJ Cruiser auto 4X4
    Snorkel, Cooper ST Maxx 255/80/17, diff breather relocate, Cobra ultra III cb radio set up Warrior Products front bumper
    I would swap the front struts, billies for OME nitrocharger struts to keep it consistent. The rest is all OME, is there any reason for going with billies?
    and if this is the first and last lift you are gonna do, i would go ahead and upgrade those leafs to the dakar leaf pack.
  3. Dec 20, 2012 at 4:55 AM
    barker14
    barker14 sexual ninja
    Adam
    Nova Scotia, Canada
    05 Tacoma TRD Off Road
    Complete OME suspension with Dakar leaf pack. Clarion touch screen Sport hood Tri fold Tonneau cover
    Should be a good setup. I have the full ome kit so I don't know a whole lot about the 5100's but I have heard good things.
    First, with the 885 coils you don't need to preload the 5100's so they should be set to 0. You don't need the trim packer as it is only for ome shocks. If you have a side to side height difference after the lift is installed you can go with a larger top plate spacer on one side. This will vary from truck to truck. I run about 3/8" spacer on drivers side and 1/8" on passenger side and I sit pretty level but again it will be different truck to truck.
    For the swaybar, I took mine off when I installed the lift and I prefer the drive without it. You may still want to get the relocate kit if its cheap but you might want to try without it. I find the coils are stiff enough to take away body roll in corners. As long as you don't drive it like a race car.
  4. Dec 20, 2012 at 4:55 AM
    Sje1124
    Sje1124 Well-Known Member
    Sean
    Louisiana
    2010 DBL Cab TRD OR 4x4
    Just a few
    Well first of all, you can't pre load the 5100's if you have the 885's on there. Is go with the OME nitros up front also as they were designed to go with the coils.
  5. Dec 20, 2012 at 4:55 AM
    tacohound
    Andy
    Cape Cod
    2011 DCSB TRD Sport
    This is definatly not the ast lift I will be doing to it, Ive heard alot of good things about the billies and wasnt to sure about the OME, but you are right about it being consistant. Thanks.
  6. Dec 20, 2012 at 4:59 AM
    tacohound
    Andy
    Cape Cod
    2011 DCSB TRD Sport
    Sje1124: Thanks for the tip, this is why I posted this lol
    Barker: Im sure I will spend a couple days of driving without the sway bar just to see how it feels. Now im thinking I should go with OME front shocks instead of billies
  7. Dec 20, 2012 at 5:06 AM
    slo2sixty
    slo2sixty Well-Known Member
    Syracuse, NY
    19 cement DCSB TRD offroad
    I ordered the complete ome kit with dakar from wheelers and light racing ucas. Have yet to put it on but a ton of people run that and have no complaints.
  8. Dec 20, 2012 at 5:07 AM
    tacohound
    Andy
    Cape Cod
    2011 DCSB TRD Sport
    This is the revised list.
  9. Dec 20, 2012 at 5:08 AM
    Taco Dan
    Dan
    Tuscaloosa, AL
    there is basically 4 budgets for 4 different kinds of lifts.
    (in order of cheapest to most expensive)
    1. spacer lift
    2. Bilstein 5100 preloaded coils and struts lift(sometimes paired with aal and eibach coils)
    3. OME full lift kit (kind of what your shooting for, and the most popular on TW)
    4. LT lifts like fox, King, etc.
  10. Dec 20, 2012 at 5:08 AM
    tacohound
    Andy
    Cape Cod
    2011 DCSB TRD Sport
    I was thinking about going with the full OME kit but this is actually saving me alot of money.
  11. Dec 20, 2012 at 5:10 AM
    Taco Dan
    Dan
    Tuscaloosa, AL
    with your revised list, you should be good. I would definitely consider if i were you to upgrade the leaf pack and UCAs in the near future.
  12. Dec 20, 2012 at 5:12 AM
    tacohound
    Andy
    Cape Cod
    2011 DCSB TRD Sport
    yeah the rear lift will be temp till I can get the dakars, Im also going to be getting wheel spacers.
  13. Dec 20, 2012 at 5:47 AM
    Sje1124
    Sean
    Louisiana
    Just a few
    If you get 885's with the top plate spacers you will most likely need new UCA's. that was the first set up I had up front and I need new UCA's being that I actually got about 3.75" of lift out of it.
  14. Dec 20, 2012 at 5:51 AM
    tacohound
    Andy
    Cape Cod
    2011 DCSB TRD Sport
    Even having a double cab?
  15. Dec 20, 2012 at 5:54 AM
    Sje1124
    Sean
    Louisiana
    Just a few
    Yeah even with a DCSB
  16. Dec 20, 2012 at 5:56 AM
    tacohound
    Andy
    Cape Cod
    2011 DCSB TRD Sport
    OK. Will it help in the time being to get wheel spacers or is it another issue with the ucas I have.
  17. Dec 20, 2012 at 5:59 AM
    Sje1124
    Sean
    Louisiana
    Just a few
    Wheel spacers wouldn't help, new UCA's are a little bigger (giving more space between the UCA and coil) so the UCA and coil don't make contact.
  18. Dec 20, 2012 at 6:03 AM
    tacohound
    Andy
    Cape Cod
    2011 DCSB TRD Sport
    And this is why asking questions haha. I needed to know this. So without the top plate spacer will I still get about 3" of lift?
  19. Dec 20, 2012 at 6:05 AM
    Sje1124
    Sean
    Louisiana
    Just a few
    Yes with out the top plate spacers you SHOULD get 3" of lift. It's different on everyone's truck. Are you a 4x4?
  20. Dec 20, 2012 at 6:06 AM
    tacohound
    Andy
    Cape Cod
    2011 DCSB TRD Sport
    Yeah I got a 4x4. It just sucks cause new ucas are so expensive
