Do you think it is bad to floor it every once in a while with high mileage?
Discussion in 'Performance and Tuning' started by Logan22, Jul 17, 2012.
  1. Jul 17, 2012 at 10:30 PM
    Logan22
    Logan22 [OP] Well-Known Member
    Logan
    Kentucky
    06 Tacoma TRD 4X4
    Tonneau Cover, Tube Steps, Kenwood Excelon KDC X895, Boston Acoustics Speakers, 12 Shallow Mount Rockford Fosgate punch p3s sub, Rockford Fosgate Punch 400 watt amp 18 in. xd spy's 285 60 18 terra grapplers
    Just wondering what your opinion is about flooring my 06 Tacoma with 140,000 miles every so often. I'm not talking about anything close to like daily just literally some times. Do you think it could mess up anything engine wise very easily or do you think it's pretty safe?
  2. Jul 17, 2012 at 10:32 PM
    06TACOFIREMAN
    06TACOFIREMAN BaNgArAnG
    Caleb
    Alabama
    2002 Tacoma TRD offroad
    toytec 2in lift, 2nd gen trd offroad wheels, yakima roof rack, tool box, magnaflow muffler in the mail
    you drive a toyota. treat it well it will treat you well. thats all i have to say on the matter.
  3. Jul 18, 2012 at 6:15 AM
    Torspd
    Torspd Tor-nication
    Tor
    Houston
    MMVI 4.4L 4x4 Access Cab
    Torspd Custom Turbo kit [] Borg Warner 9180EFR Turbo [] ProEFI Pro128 EMS [] TiAL Q BOV [] TiAL V44 Wastegate @ 15psi [] CP Pistons [] CP Carrillo Rods [] ARP Head studs [] ARP Main Studs [] ARP Header - Head Studs [] Ported Heads w/ 1mm oversized valves intake/exhaust [] Brian Crower Forged Stroker Crank [] Darton M.I.D. Sleeved Block [] Kelford Camshafts [] Torspd 170* T-stat mod [] APR Large Fuel Rail [] Aeromotive Stealth 340 LPH Fuel Pump [] FueLab FPR [] APR T56 Conversion Kit [] KP RACING Built T56 [] McLeod Racing Custom Twin Disk Clutch [] One Piece Aluminum Driveshaft [] MGW Shifter [] Custom lowering kit [] Ohlins Front Coilovers [] QA1rear shocks [] Custom Ron Davis Radiator [] Dual SPAL Electric Fans []
    Put a nice thick oil in it, and it will protect it better. Especially since you have high mileage. Anything between a 10w-40 to a 20w-50. Depending on climate.
    Using a "High Mileage" style oil will also have a higher PPM of anti-wear additives than regular SAE approved engine oils. Full synthetic or not.
    Unless of course you add your own ZDDP, from a bottle of "Engine Break-in Oil".
    With your bearing tolerances at this point in engine life are wider than they used to be. So to better protect against the stresses of full throttle acceleration, is why you need a thicker oil than the oil cap recommendation. :thumbsup:
  4. Jul 18, 2012 at 6:30 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    The only reason you would want to put a thicker oil in is if it was burning excessive amounts of oil. Otherwise, you are not helping anything. You will, however, decrease your mileage and increase cold startup wear. A quality, high-mileage oil will protect your engine and help heep yours gaskets/seals intact just fine.
    Your truck was made to work. Work it!
  5. Jul 18, 2012 at 6:37 AM
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    Get it out on the highway, run it hard for a few miles, get the rev's up a bit to heat up and blow out the cat converter.
  6. Jul 18, 2012 at 6:42 AM
    Torspd
    Torspd Tor-nication
    Tor
    Houston
    I agree with the loss of a little MPG, but completely disagree with increased wear. It will be the exact opposite.
    Simple example. Engine starts getting rod knock. What do you do to keep it from getting worse, and or knocking at all? Add a thicker oil.
    If you really want to get into why the thicker oil is safer, I simply say to look through the research of Southwest Research out of San Antonio, TX. http://www.swri.org/
  7. Jul 18, 2012 at 6:49 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Airaid Short Ram Intake, 285x75R16 Mickey Thompson MTZs, 16" Konig Countersteer rims, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Seeing as the VVTI is run off of oil pressure I would say don't run oil that isn't recommended by Toyota unless you want to get worse mileage and possible ruin things.
    But there's nothing wrong with giving your truck an Italian tune up every now and then.
  8. Jul 18, 2012 at 6:54 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    You should not be driving if the engine has a rod knock. It will grenade with any grade of oil. Get it fixed cheaper before it goes.
    Please point me toward a specific article within swri. I may eventually find it by myself, but it does me no good right now.
  9. Jul 18, 2012 at 7:10 AM
    cgs2k2
    cgs2k2 Ohio Member
    Nadeem
    2006 AC 4x4 OR
    simplest answer: You'll be fine.
  10. Jul 18, 2012 at 7:26 AM
    03is300ztk
    03is300ztk Well-Known Member
    Zach
    Somewhere in the hills NC
    07 Tacoma 4X4
    Grillcraft, with front and rear bumper/bed in the works.
    Agreed I look through for a good 20 mins, and see nothing pointing towards thicker oil on high mileage engine is better.
    In fact if you look anything up regarding oil viscosity it can be understood that you ALWAYS want to stick to manufacture specifications regarding the viscosity rating for there engines.
    The viscosity rating is oil's resistance to flow at a specific temperature tested. So in fact a thicker oil is IS WORSE for a higher mileage vehicle because that oil is more RESISTANT to flowing ie not lubricating the parts that need it when its needed.
    Lets put it this way, if you needed to change oil weights at a specific mileage it would be in the book, on the cap and well advertised.
    Look at any high mileage oil in the stores, notice they carry most weights? Thats because its about whats in the oil thats important to high mileage engines not how thick the oil is.
    Just one link to help understand viscosity and what it Really means.
    http://www.upmpg.com/tech_articles/motoroil_viscosity/
  11. Jul 18, 2012 at 7:27 AM
    03is300ztk
    Zach
    07 Tacoma 4X4
    Just tell yourself what I do,
    "ehh just gotta clear some carbon buildup!!!" lol
  12. Jul 18, 2012 at 7:49 AM
    Lucario Runner
    Lucario Runner Resident SUV racer
    Robert
    San Antonio, TX
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Ok heres the deal. Does engine oil (or any other fluid) get thicker or thinner with a rise in a increase in temperature? Gets thinner is the right answer. Does pressure increase or decrease with a rise in temp? It deceases. Thing is all manufactures have what is called acceptable loses they want you to buy a new car again, sooner rather than later, but would like to have a good rep towards component parts in terms of longevity. EPA also has rules regulating the amount of anti-wear content as it isn't friendly to the cats and other emission control bs. Take the 2nd generation of the 1grfe as an example. It is put on an SAE 20 grade as a factory fill, 1st gen uses 30, as with most new cars to gain more mpg by decreasing drag on the internals. However the oil is thinner, pressure is lower and the engine runs quite a bit hotter. Traditionally thicker oils do contain more ZDDP on a ppm level, however alot of the thinner oils are putting in more detergents and antiwear additives to compensate. When I ran a 10w40 weight my pressure was only increased by 3-4 pounds but my engine temp was down a good ten degrees fahrenheit. A question to ask ones self is what do racers and people that tow and haul alot run? They run thicker oils from a stock engine or a fully built one. Now environment is something to consider, but for the most part you'll be fine.
  13. Jul 18, 2012 at 8:05 AM
    Torspd
    Torspd Tor-nication
    Tor
    Houston
  14. Jul 18, 2012 at 8:15 AM
    03is300ztk
    Zach
    07 Tacoma 4X4
    Agreed in part, mainly towards the racers. Think of NASCAR running the new G-oil Car. I have to ask do you know how much oil a nascar engine uses?
    5 GALLONS!?!?!?!?!?!?! HUGE DIFFERENCE compared to our measly 5qts. Just saying that may be a factor in how they justify running what they do. I just dont think anyone compare, haulers/racers to DD Tacos. That is for oil use anyways.
  15. Jul 18, 2012 at 9:26 AM
    Lucario Runner
    Robert
    San Antonio, TX
    06 Toyota 4Runner
    Volume is different of course however the same principle applies, even more so under high load situations.
  16. Jul 18, 2012 at 9:51 AM
    03is300ztk
    Zach
    07 Tacoma 4X4
    Yes agreed, I just think that helps alot when keeping the temperature down, and use bet driven pumps to keep up with the load.
  17. Jul 19, 2012 at 6:51 AM
    Night
    Night Well-Known Member
    Canada
    '11 TRD OR AC MagGrey
    Banks Monster Exhaust, aFe ProGuard 7, 3M Film, UnderCoating, alpine 920 headunit, alpine 6.5 components, 20% tint all around, JL Stealthbox, PDX-V9 Amp, Avid Lightbar, Avid Sliders, Full Metal JackRabbit Tonneau, TRD S/C
    There is a difference between flooring it and redLining no?
  18. Jul 19, 2012 at 7:54 AM
    subwayaz
    subwayaz Well-Known Member
    Tucson,Az
    2012 Accesscab; TRD
    Super Charger, Catback Exhaust,Side Wind Shades, & Carbon Fiber Dash Kit
    Toyota's are pretty tough vehicles so I wouldn't think it would hurt it. But what is your point in doing so?
  19. Jul 20, 2012 at 9:35 PM
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    I floor it at least once a day for good measure!
  20. Jul 21, 2012 at 9:31 AM
    cintocrunch
    cintocrunch Special Substitute Guest Member
    MD
    2012 DCSB TRD Sport MGM 6MT
    Anytime fogs, Leer Tonneau
    I typically fill up at the same couple gas stations that are all off of 50 or 55 mph roads, so immediately after filling up I run through the first 2 or 3 gears at redline...done it with every vehicle I've owned and never had any issues related to engine rpm...
