do you think my truck is pre-wired for the compass and ambient temp gauge?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by builthatch, Dec 2, 2010.
  1. Dec 2, 2010 at 11:11 PM
    builthatch
    builthatch [OP] MiG-21 superfan
    Tony Mandarich
    near the ocean, NJ
    '11 SSM SR5 6 speed 4x4
    Hella DOT wattage high performance 9003 headlight bulbs, Optilux by Hella XY h10 fog light bulbs, Suntek HP50 tint, AFE Stage II Si intake
    '11 SR% 4x4 double cab. i've read that these trucks are, for the most part, wired for most things no matter what, but to me it seems some things would be needed for this aside from simply having the plug present, such as the temp sensor in the bumper or something.
    i found a write-up for installing such but it was from '09 - i don't know if the pre-wiring has changed at all.
    i'd love to retrofit one of those into my overhead console.
  2. Dec 2, 2010 at 11:15 PM
    snowgod06
    snowgod06 UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    look up by the radiator, if theres a plug that comes off your horn harness then thats one part to do it. You'd have to get the sending unit, only like 15 bucks online. if you pull down your overhead and find the other end, well woot, you can do a swap. Ive got the hook ups and the sending unit, i just need a overhead display now.
  3. Dec 2, 2010 at 11:15 PM
    milam89
    milam89 Well-Known Member
    houston,tx
    2006 blacked tacoma
    man i would love to do the same thing, hope somebody knows!!!!!:D
  4. Dec 2, 2010 at 11:16 PM
    builthatch
    Tony Mandarich
    near the ocean, NJ
    ahh, i see now.
    i've been searching some other terms and found add'l info that points to me having all of that, but we won't know for sure until i check for myself ; )
    thanks!
  5. Dec 2, 2010 at 11:18 PM
    snowgod06
    Rob
    06 Access Cab
    haha yea, just take a look. takes about 2 minutes. GL
  6. Dec 2, 2010 at 11:20 PM
    tacobox
    tacobox Evasive Maneuvers PMKMS
    Should only take a sec to pop the cover off and see if there's a wire harness
  7. Nov 19, 2015 at 7:15 PM
    mahaloTaco
    mahaloTaco TcBob's BFFL
    Max
    Los Angeles
    13 RC 4x4 S/C'd lockers 4.88's Airflow Snorkel McNeil Glass
    anyone have the wiring?
